POV-Ray : Newsgroups : povray.binaries.images : Flood of Blood Server Time
23 Jul 2026 05:31:23 EDT (-0400)
  Flood of Blood (Message 5 to 14 of 14)
<<< Previous 4 Messages Goto Initial 10 Messages
Subject: Re: Flood of Blood
Date: 10 Oct 2001 19:20:59
Message: <3bc4d7db$1@news.povray.org>
It reminds of the way liquid behaves in a zero G environment.  It holds a
globular shape as opposed to a flattened stream with gravity.  Paint in
Space?
Skip
JRG <jrg### [at] hotmailcom> wrote in message news:3bc4b0a2@news.povray.org...
> ...well, not really, just red paint.
> This is a quick test with a particles system I'm writing these days. This
> still doesn't look that good, but I'm going to post the animated version
> ASAP (tough you can find my previous test in p.b-a).
> Comments and suggestions are welcome.
> Jonathan.
Date: 10 Oct 2001 22:16:15
Message: <3BC50119.B3EFE157@unforgettable.com>
Make a version with blood! :D
-Xplo
Date: 11 Oct 2001 02:09:47
Message: <3bc537ab@news.povray.org>
Blood is more translucent though. Something like that glass of milk...
- Nekar
"JRG" <jrg### [at] hotmailcom> wrote in message news:3bc4b0a2@news.povray.org...
> Jonathan.
Version: 6.0.282 / Virus Database: 150 - Release Date: 2001/09/25
Date: 11 Oct 2001 16:33:17
Message: <3BC6029E.319BF1F5@iro.umontreal.ca>
JRG wrote:
> To say the true the particles are really small. Look at the smallest
> particles on the ground and consider that all the particles have same
> size...
> The problem here could be that I used only 100 iterations, with 40 particles
> per iteration... just 2 minutes of parsing.
I'm intrigued. How does your system work ?
I've done some thinking but all solution I came up
with are computational monsters. Especially with
Povray, the language isn't quite as powerful as one
could wish to do real computations and animations...
Best,
    S.
> Jonathan
> "Steven Pigeon" <pig### [at] iroumontrealca> ha scritto nel messaggio
> news:3BC4B40F.221A70C1@iro.umontreal.ca...
> This
> > > Jonathan.
> > >  [Image]
> > hmmm...
> > ....chunky....
> > More small particles? ... like a LOT more ?
> > Best,
> >     S.
> > Steven Pigeon                     Ph. D. candidate
> > University of Montreal.
> > pig### [at] iroumontrealca           Topic: data compression
> >          http://www.iro.umontreal.ca/~pigeon
Date: 11 Oct 2001 16:50:46
Message: <3bc60626@news.povray.org>
Computational monsters? It's not the case.
I'm not a programmer neither a physicist, so I have no idea how particles
systems are usually done... ;)
Mine uses a simple 30-40 lines code to do all the calculations. It took me
just 30 minutes to write it down one or two weeks ago. No fancy features, no
inter-particle interaction. Yet it seems to work well in animations. And SDL
is required for trace(). I will post this scene animated tomorrow.
Jonathan.
news:3BC6029E.319BF1F5@iro.umontreal.ca...
> > size...
particles
> Best,
>     S.
> > Jonathan
> > This
version
> > > > Jonathan.
> > > >  [Image]
> > > hmmm...
> > > ....chunky....
> > > Best,
> > >     S.
Date: 11 Oct 2001 17:00:35
Message: <3BC60904.39272E10@iro.umontreal.ca>
Neither am I. But, I don't know... I would have particle glue together under
a certain treshold of energy difference, repulse each other when compressed...
Glue to objects, etc.
That type of physical constraints.
ok... I'm eager to see it
Best,
    S.
> Jonathan.
> > > size...
> particles
> > Best,
> >     S.
> > > Jonathan
> > > This
> version
> > > > > Jonathan.
> > > > >  [Image]
> > > > hmmm...
> > > > ....chunky....
> > > > Best,
> > > >     S.
Date: 11 Oct 2001 17:09:31
Message: <3bc60a8b@news.povray.org>
news:3BC60904.39272E10@iro.umontreal.ca...
particles
under
compressed...
That would be easy to implement but really slow in animation... (a loop
which checks the distances between every particle would do the trick).
This is *simulated* with little random amounts here.
Jonathan
Date: 11 Oct 2001 18:32:33
Message: <3bc61e01@news.povray.org>
"Mahalis" <don### [at] fakeycom> ha scritto nel messaggio
news:3bc4cf1a@news.povray.org...
> Eeeew... Cool though. Source? :-)
When the work is finished I'll post the code. Now it really needs to be
cleaned up.
Jonathan.
Date: 11 Oct 2001 22:00:25
Message: <3BC64F91.36149A67@faricy.net>
Just wash the ax off when you're done.  Oh, and you forgot to lock the
door, so look out for Lizaveta.
Date: 14 Oct 2001 02:04:01
Message: <3BC92B81.E78AE64@qwest.net>
wow. very iconic image to me- and good title- who's to
say it *isn't* blood?
http://www.users.qwest.net/~dearmad
Why bother?  I'm not interesting.
But... maybe "Ballet pour ma fille" will be.
