POV-Ray : Newsgroups : povray.binaries.images : Modeler test (2 jpgs, 27kb each) Server Time
1 Jan 2026 18:04:37 EST (-0500)
  Modeler test (2 jpgs, 27kb each) (Message 1 to 10 of 11)
Subject: Modeler test (2 jpgs, 27kb each)
Date: 6 Nov 2003 16:01:09
Message: <3FAAB67B.606@hotmail.com>
This was done in just a few hours time last night.  before.jpg is the
hull mesh and after.jpg is with three levels of subdivision plus normal
smoothing.
My modeler can now apply texturing to individual faces.  All I need now
is to add uv-mapping.
John
Download 'before.jpg' (27 KB) Download 'after.jpg' (27 KB)
Preview of image 'before.jpg'
Preview of image 'after.jpg'
Subject: Re: Modeler test (2 jpgs, 27kb each)
Date: 6 Nov 2003 17:26:14
Message: <3faaca86$1@news.povray.org>
> smoothing.
> Regards,
> John
Very, very impressive!
Date: 6 Nov 2003 17:50:26
Message: <3FAACFC8.D83AD3EA@onwijs.com>
> smoothing.
> Regards,
> John
>  [Image]  [Image]
Impressive.
Is there any predictable relationship between the original mesh and the
final result?
It now looks a bit like what you have when working with blobs: it needs
a lot of experimenting to get everything the right size.
Can you for instance be sure about the length or width of a paw or ear?
Again, I think it's very impressive and it looks very, very useful,
predictable or not.
Remco
Date: 6 Nov 2003 19:03:35
Message: <3faae157$1@news.povray.org>
I agree.  Great job!
Date: 7 Nov 2003 02:53:03
Message: <3fab4f5f$1@news.povray.org>
> smoothing.
That looks nice. Can you see the control mesh after subdivisions and
modify it on the fly in your editor? It would make editing a whole lot
easier (but needs a lot of computational muscles).
What scheme are you using for subdivisions? You might find this paper
interesting:  http://tom.cs.byu.edu/~tom/papers/nurss.pdf. It's one way
of preserving sharpe features. I don't know if it's the best option, but
not too much work if you have a working Catmull-Clark.
  Ari-Matti
Date: 8 Nov 2003 01:38:45
Message: <3FAC8F73.8070609@hotmail.com>
>> smoothing.
No.  The modeler doesn't do the subdivisions.  The modeler exports the
basic mesh to a POV script file.  I have a set of macros here
   http://enphilistor.users4.50megs.com/nsss.htm
which take the polygon hull and turn it into the smooth form.
Right now I use a modified Loop scheme (extended to include
quadrilateral faces).
John
Date: 8 Nov 2003 01:44:06
Message: <3FAC90B4.3060208@hotmail.com>
Remco de Korte wrote:
> Impressive.
Thanks.
> final result?
The final mesh is always confined to the convex hull of the original
vertices.  I know that isn't saying much.
However, if I make a box and subdivide it, the resulting ball (close to
spherical) will be just slightly smaller than the box.  Another part of
this thread brought up the question of interactive display of the
refined mesh; I might add that later.
The amount of shrinkage away from the mesh depends on how sharp the
angles are between the original mesh faces.  A tetrahedron shrinks a
lot, a cube shrinks less, an icosahedron shrinks a lot less.
> predictable or not.
Yep.  The people who claim to be tired of Rusty may get their wish.
John
Date: 8 Nov 2003 17:16:29
Message: <3fad6b3d$1@news.povray.org>
Very interesting.
Could one do some "sloppy" modelling first with povray primitives and then
have it go to mesh and then to ssd mesh?
Date: 9 Nov 2003 08:52:01
Message: <3fae4681$1@news.povray.org>
I just wrote some macros which output POV-Primitives as Mesh. Using
those you could propably do it. I will post them when I have found
time to improve them a little and to write some short documentation.
But your idea is great and I will check if it's possible right now :)
Greetings,
Florian
//=================[web: http://www.torfbold.com]==================\\
#local a=-5;#while(a<5)sphere{<sin(a*pi)*5a*10pow(a,5)*.01>sin(a*a*a*
.1)+1pigment{rgb 9*z}}#local a=a+.01;#end camera{look_at-y*10location
<8,-3,-8>*10}// [www.povray.org]     [www.imp.org]     [www.irtc.org]
Date: 9 Nov 2003 10:41:24
Message: <3FAE5FB2.BE3C921C@onwijs.com>
Coorect me if I'm wrong, but what I understand of it is that you have
made a modeller to create a mesh which you feed to POV-macros to get the
subdivided mesh. If so, I understand how you came to this (the macros
came first) but wouldn't it be far more efficient to do the subdividing
in the modeller as well? That way you can get (sort of) a preview and
it's probably a lot faster then the POV parsing.
Remco
