POV-Ray : Newsgroups : povray.binaries.animations : B-29 bomber--animation Server Time
17 May 2024 04:01:11 EDT (-0400)
  B-29 bomber--animation (Message 6 to 15 of 15)
<<< Previous 5 Messages Goto Initial 10 Messages
Subject: Re: B-29 bomber--animation
Date: 25 Mar 2010 11:41:17
Message: <4bab841d@news.povray.org>
On 25/03/2010 3:14 PM, Kenneth wrote:
> clipka<ano### [at] anonymousorg>  wrote:
>> Stephen schrieb:
>>> I hope that they got home safely
>> Looks like they bailed out already; I can't make out anyone sitting in
>> the pilots' seats...
> Ah yes, you have guessed correctly.  ;-)
> The cockpit has instrument panels, seats--but no crew.  Just didn't get around
> to making any. (Actually, what I *want* to do is take a video of some friends
> against a bluescreen or white background, dress 'em in ersatz bomber gear, and
> composite them into the cockpit--with correctly-changing perspective. The *idea*
> is worked out--now I just need to do it!)
IIRC Poser has the facility to change a models face using a pair of
front and side photographs
Best Regards,
Date: 25 Mar 2010 11:42:24
Message: <4bab8460$1@news.povray.org>
On 25/03/2010 3:05 PM, Kenneth wrote:
> Hmm, I wonder...
> Early B-29's had *notorious* engine problems. I read somewhere that part of the
> inner engine was made of magnesium--and when that caught fire, it literally
> burned right through the wing. Makes for a bad day...
I bet :)
Best Regards,
Date: 27 Mar 2010 15:23:25
Message: <4bae5b2d$1@news.povray.org>
Kenneth wrote:
> 800 X 600, about 16 seconds long.  Compressed using the Xvid open-source codec.
> (It had to be rather heavily compressed to fit here; sorry.)
  That's one of the best POV-Ray animations I have ever seen.
Date: 27 Mar 2010 20:50:00
Message: <web.4baea6a6d0e9e2de65f302820@news.povray.org>
Thank you, Warp.  Very much appreciated.
Ken
Date: 1 Apr 2010 09:31:30
Message: <4bb4a032$1@news.povray.org>
I agree.  Fantastic!!!
Date: 3 Apr 2010 23:47:42
Message: <4bb80bde$1@news.povray.org>
Aside from the hard work that went into the plane model (and its
texturing and the flame effects), some methods that aren't at all hard
helped things out.
* First, he shook the camera a bit.  Part of the reason that a lot of
the animation work seen on this server is not all that interesting is
because the camera work makes it bland.  A bit of randomness in the
camera really ups the level of realism.
* Second, any problems with the detail in the ground are solved by the
clouds, which make it hard to get a good look at the ground.
Admittedly, a real task force flying a combat mission would be flying
under the clouds (if over friendly territory) or over them (if over
enemy territory), and not flying *in* them...
It's an excellent piece of work.
John
Date: 4 Apr 2010 21:04:39
Message: <4bb93727$1@news.povray.org>
John VanSickle wrote:
> Admittedly,
> a real task force flying a combat mission would be flying under the
> clouds (if over friendly territory) or over them (if over enemy
Although I note on further viewing that only the wounded craft is flying
in the clouds.
John
Date: 5 Apr 2010 14:20:00
Message: <web.4bba297ed0e9e2de65f302820@news.povray.org>
> in the clouds.
Thanks for all the nice comments. Yeah, I thought about this cloud thing for
quite awhile; honestly, it just looked more *interesting* for the main B-29 to
be flying within the clouds, passing through them. It also helped create a
'speedier' feeling in the scene--the clouds are really the only visual clue as
to speed. (Well, the contrails too--but they end up being hidden to a fair
degree.) And I did purposely put the other two bombers up above the clouds, for
the reasons you mentioned. It's just that the disabled bomber is having a hard
time maintaining altitude. ;-)  In the final analysis, though, it was all done
to get a more-or-less balanced visual composition; reality took a back seat.
Ken
Date: 8 May 2010 12:40:00
Message: <web.4be592b9d0e9e2de34d207310@news.povray.org>
Amazing technique.
Your plane however is missing the Sally Jupiter logo on it. :(
Date: 17 Jun 2011 08:10:01
Message: <web.4dfb4352d0e9e2de22556d3f0@news.povray.org>
> I posted some notes (and a still image) over at p.b.images ("Limping Back
> Home"); please post any comments there. Thanks!
> I hope you enjoy it!
> Ken
Wow!
The same comment as above,
the best POV animation I never seen.
Used to see only some cubes and checkers reflection.
Have you somewhere a step by step to follow
how you worked and your setup.
Is the scene completely modeled
within POV?
Again, nice work.
