On 25/03/2010 3:14 PM, Kenneth wrote:
> clipka<ano### [at] anonymous org> wrote:
>> Stephen schrieb:
>>> I hope that they got home safely
>> Looks like they bailed out already; I can't make out anyone sitting in
>> the pilots' seats...
> Ah yes, you have guessed correctly. ;-)
> The cockpit has instrument panels, seats--but no crew. Just didn't get around
> to making any. (Actually, what I *want* to do is take a video of some friends
> against a bluescreen or white background, dress 'em in ersatz bomber gear, and
> composite them into the cockpit--with correctly-changing perspective. The *idea*
> is worked out--now I just need to do it!)
IIRC Poser has the facility to change a models face using a pair of
front and side photographs
Best Regards,
On 25/03/2010 3:05 PM, Kenneth wrote:
> Hmm, I wonder...
> Early B-29's had *notorious* engine problems. I read somewhere that part of the
> inner engine was made of magnesium--and when that caught fire, it literally
> burned right through the wing. Makes for a bad day...
I bet :)
Best Regards,
Kenneth wrote:
> 800 X 600, about 16 seconds long. Compressed using the Xvid open-source codec.
> (It had to be rather heavily compressed to fit here; sorry.)
That's one of the best POV-Ray animations I have ever seen.
Thank you, Warp. Very much appreciated.
Ken
I agree. Fantastic!!!
Aside from the hard work that went into the plane model (and its
texturing and the flame effects), some methods that aren't at all hard
helped things out.
* First, he shook the camera a bit. Part of the reason that a lot of
the animation work seen on this server is not all that interesting is
because the camera work makes it bland. A bit of randomness in the
camera really ups the level of realism.
* Second, any problems with the detail in the ground are solved by the
clouds, which make it hard to get a good look at the ground.
Admittedly, a real task force flying a combat mission would be flying
under the clouds (if over friendly territory) or over them (if over
enemy territory), and not flying *in* them...
It's an excellent piece of work.
John
John VanSickle wrote:
> Admittedly,
> a real task force flying a combat mission would be flying under the
> clouds (if over friendly territory) or over them (if over enemy
Although I note on further viewing that only the wounded craft is flying
in the clouds.
John
> in the clouds.
Thanks for all the nice comments. Yeah, I thought about this cloud thing for
quite awhile; honestly, it just looked more *interesting* for the main B-29 to
be flying within the clouds, passing through them. It also helped create a
'speedier' feeling in the scene--the clouds are really the only visual clue as
to speed. (Well, the contrails too--but they end up being hidden to a fair
degree.) And I did purposely put the other two bombers up above the clouds, for
the reasons you mentioned. It's just that the disabled bomber is having a hard
time maintaining altitude. ;-) In the final analysis, though, it was all done
to get a more-or-less balanced visual composition; reality took a back seat.
Ken
Amazing technique.
Your plane however is missing the Sally Jupiter logo on it. :(
> I posted some notes (and a still image) over at p.b.images ("Limping Back
> Home"); please post any comments there. Thanks!
> I hope you enjoy it!
> Ken
Wow!
The same comment as above,
the best POV animation I never seen.
Used to see only some cubes and checkers reflection.
Have you somewhere a step by step to follow
how you worked and your setup.
Is the scene completely modeled
within POV?
Again, nice work.
