Hi! I just uploaded this 10-minutes isosurface animation:
http://www.youtube.com/watch?v=btVGCqpIoyk&fmt=22
18210 frames, 854x480 resolution, 30fps.
Rendering time: 3 weeks (on a quad core system).
Cheers,
Burkhard
> Cheers,
> Burkhard
The music is not to my taste but it does go well with your beautiful
animation. :D
Best Regards,
Nice!  Did you use multiple instances of v3.6 or were you using b3.7?
Four instances of 3.6. That's where a multi-core CPU comes in really handy :)
> Cheers,
> Burkhard
Beautiful!
The music fits very well, too.
Simone
"mone" <mon### [at] alienenterprises de> wrote:
> Beautiful!
> Regards,
> Simone
Sine then I always wanted to use it as background music for some video. Well now
I made the video for it :o)
Cheers, Burkhard
Cool. That's what I do too. Often my parse time is way longer than the render
time so multiple instances even of 3.7 is what I'll probably end up doing in the
future.
Charles
PS, I had a certain special appreciation for your video after spending some
20-something days rendering something sort-of related.  ("psychedelic scrambler"
if curious.)
future.
Charles
if curious.)
It's beautiful, but also a bit repetetive to watch it
actively for a full 10 minutes. But in the right chill
out setting it's probably appropriate ;)
Also, it seemed to freeze sometimes although data
was still buffered in the player, so I wondered if this
was part of the actual animation.
I also had this problem recently when animating the galaxy data
from the 6df survey. I ended up hacking 3.7b to allow variables
which persist their values between individual renders. It wasn't
a clean solution (more like a designed memory leak) and would
require much additional work to make it a real feature (if
the pov team even wished to include such a feature).
But I'd be interested to hear if long parse times are a common
problem for animations, and if those parse times could be reduced
by reusing a variable, such as a large array or a complex CSG
object, from the previous frame.
