http://www.youtube.com/watch?v=gJDsju0pSqQ
I did this lenticular image in POV-Ray, but I didn't have any lenticular sheets
yet to print it out just yet. I was anxious to see what it might look like, so
I figured out a way of doing it virtually in POV-Ray. I took the image that was
to be my lenticular print out and applied it as a texture map on a square. Then
I put a model of an array of half-cylinder lenses in front of the square in
POV-Ray to "play back" the lenticular image. I wasn't sure if this would work,
but it did. When I get the sheets, I'll print it out for real.
My, this is...!
Amazing!
I want one :)
I had never thought on this particular effect.
Cool!
Carlo
That's just plain fascinating! What a great experiment to try. I've been
thinking lately of the lenticular process as well (although not in relation to
reproducing the effect *IN* POV-Ray--that never occurred to me!) An excellent
way to pre-visualize the technique. Thanks for the inspiration;
And since lenticular effects depend on the viewer-to-print distance, POV-Ray can
even be used to test *that*.
Question 1:
What camera 'angle' are you using that best matches our eyeballs?
Question 2:
What IOR are you using for the lenticular 'screen'?
Question 3:
Do such screens use 'cylinders' (half-cylinders?) for lenses, or triangular
prism-like shapes? I guess I need to bone up on the actual process; haven't
explored this in detail for a long time.
KW
Thanks for the replies.
Here's the camera set-up I was using:
  cylinder 4
  location <0,0,-4>
  right 2*x
  up 4*y
  look_at  <0,0,0>
  angle 37.4
Since the horizontal perspective of the image is being provided by the lenses, I
needed to use a camera that was orthagraphic in the horizontal direction and had
perspective in the vertical direction.  The cylinder camera provided the
solution I was after.
The ior I was using was 1.49 for acrylic, but I might have to tweak that when I
know better exatly what material I'm working with.
The objects in my scene extend from 0.0 pov-ray units to 0.6 pov-ray units to
the back of the view and 1 pov-ray unit horizontally and 1 pov-ray unit
vertically.
Most suppliers of lenticular sheets make them with cylindrical lenses. I'm not
sure if there are any that make them with the triangular lenses.
> camera {
>   cylinder 4
>   location <0,0,-4>
>   right 2*x
>   up 4*y
>   look_at  <0,0,0>
>   angle 37.4
Hmm, I may be confused here. I guess there are TWO cameras involved--one for
making the 'print,' and one for looking at the final result.  (Do I have that
right?) Or actually three cameras--two for making the stereo pairs, and one for
viewing it. Is your cylindrical camera for 'making' the print(s), or for viewing
the final lenticular object in the animation?
KW
> I did this lenticular image in POV-Ray, [...]
I like, very much, as it replicates the off-axis visual artefacts too!
If presented with this challenge, I would have been tempted to cheat and use
trace() to make a portal into another scene from the 'print'.
Can you do holograms? ;oP
> I did this lenticular image in POV-Ray.
Could this principle be extended to two axes, using hemi-spherical lenticular
elements (and in real life, strong back-lighting, because POV-Ray doesn't do
refracted intensity)?
I used the cylindrical camera to render the image that was applied to the
square.
I did the animation in another pov-ray file with a regular perspective camera.
Yes, this can be extended to use hemispherical lenses, which I've already done
in a previous project, seen below.
http://holographyforum.org/phpBB2/viewtopic.php?f=6&t=4427&p=35781&hilit=integrams#p35781
I'm not sure what you mean about the strong backlighting.
