POV-Ray : Newsgroups : povray.binaries.animations : Virtual 3D Lenticular Print in POV-Ray Server Time
17 Jun 2024 01:53:14 EDT (-0400)
  Virtual 3D Lenticular Print in POV-Ray (Message 1 to 10 of 10)
Subject: Virtual 3D Lenticular Print in POV-Ray
Date: 19 Apr 2009 19:45:00
Message: <web.49ebb6b22f4af1965f2fc4ec0@news.povray.org>
http://www.youtube.com/watch?v=gJDsju0pSqQ
I did this lenticular image in POV-Ray, but I didn't have any lenticular sheets
yet to print it out just yet. I was anxious to see what it might look like, so
I figured out a way of doing it virtually in POV-Ray. I took the image that was
to be my lenticular print out and applied it as a texture map on a square. Then
I put a model of an array of half-cylinder lenses in front of the square in
POV-Ray to "play back" the lenticular image. I wasn't sure if this would work,
but it did. When I get the sheets, I'll print it out for real.
Subject: Re: Virtual 3D Lenticular Print in POV-Ray
Date: 19 Apr 2009 21:25:00
Message: <web.49ebcec73073367c1a1b9caf0@news.povray.org>
My, this is...!
Amazing!
Date: 20 Apr 2009 02:30:01
Message: <web.49ec161d3073367ccac4259f0@news.povray.org>
I want one :)
Date: 20 Apr 2009 03:50:00
Message: <web.49ec28803073367cdf44ecbb0@news.povray.org>
I had never thought on this particular effect.
Cool!
Carlo
Date: 20 Apr 2009 15:40:01
Message: <web.49eccf153073367cf50167bc0@news.povray.org>
That's just plain fascinating! What a great experiment to try. I've been
thinking lately of the lenticular process as well (although not in relation to
reproducing the effect *IN* POV-Ray--that never occurred to me!) An excellent
way to pre-visualize the technique. Thanks for the inspiration;
And since lenticular effects depend on the viewer-to-print distance, POV-Ray can
even be used to test *that*.
Question 1:
What camera 'angle' are you using that best matches our eyeballs?
Question 2:
What IOR are you using for the lenticular 'screen'?
Question 3:
Do such screens use 'cylinders' (half-cylinders?) for lenses, or triangular
prism-like shapes? I guess I need to bone up on the actual process; haven't
explored this in detail for a long time.
KW
Date: 20 Apr 2009 23:20:01
Message: <web.49ed3aaf3073367c1aea4e430@news.povray.org>
Thanks for the replies.
Here's the camera set-up I was using:
  cylinder 4
  location <0,0,-4>
  right 2*x
  up 4*y
  look_at  <0,0,0>
  angle 37.4
Since the horizontal perspective of the image is being provided by the lenses, I
needed to use a camera that was orthagraphic in the horizontal direction and had
perspective in the vertical direction.  The cylinder camera provided the
solution I was after.
The ior I was using was 1.49 for acrylic, but I might have to tweak that when I
know better exatly what material I'm working with.
The objects in my scene extend from 0.0 pov-ray units to 0.6 pov-ray units to
the back of the view and 1 pov-ray unit horizontally and 1 pov-ray unit
vertically.
Most suppliers of lenticular sheets make them with cylindrical lenses. I'm not
sure if there are any that make them with the triangular lenses.
Date: 20 Apr 2009 23:45:00
Message: <web.49ed40443073367cf50167bc0@news.povray.org>
> camera {
>   cylinder 4
>   location <0,0,-4>
>   right 2*x
>   up 4*y
>   look_at  <0,0,0>
>   angle 37.4
Hmm, I may be confused here. I guess there are TWO cameras involved--one for
making the 'print,' and one for looking at the final result.  (Do I have that
right?) Or actually three cameras--two for making the stereo pairs, and one for
viewing it. Is your cylindrical camera for 'making' the print(s), or for viewing
the final lenticular object in the animation?
KW
Date: 21 Apr 2009 10:40:01
Message: <web.49edd9d53073367caddfbead0@news.povray.org>
> I did this lenticular image in POV-Ray, [...]
I like, very much, as it replicates the off-axis visual artefacts too!
If presented with this challenge, I would have been tempted to cheat and use
trace() to make a portal into another scene from the 'print'.
Can you do holograms? ;oP
Message: <web.49edda7e3073367caddfbead0@news.povray.org>
> I did this lenticular image in POV-Ray.
Could this principle be extended to two axes, using hemi-spherical lenticular
elements (and in real life, strong back-lighting, because POV-Ray doesn't do
refracted intensity)?
Date: 21 Apr 2009 23:45:00
Message: <web.49ee91df3073367ce2c361040@news.povray.org>
I used the cylindrical camera to render the image that was applied to the
square.
I did the animation in another pov-ray file with a regular perspective camera.
Yes, this can be extended to use hemispherical lenses, which I've already done
in a previous project, seen below.
http://holographyforum.org/phpBB2/viewtopic.php?f=6&t=4427&p=35781&hilit=integrams#p35781
I'm not sure what you mean about the strong backlighting.
