POV-Ray : Newsgroups : povray.binaries.animations : A sunrise with media and radiosity Server Time
21 Apr 2026 20:04:39 EDT (-0400)
  A sunrise with media and radiosity (Message 11 to 15 of 15)
Subject: Re: A sunrise with media and radiosity
Date: 23 Oct 2008 16:45:01
Message: <web.4900e1fc657b8a95bc82ce420@news.povray.org>
Alain <ele### [at] netscapenet> wrote:
> Rarius nous illumina en ce 2008-10-23 04:45 -->
> > "ajtribick" <nomail@nomail> wrote in message
> > news:web.48fb31f9ed540e8abc82ce420@news.povray.org...
> >> Test animation of a sunrise using media and radiosity. The atmosphere is
> >> created
> >> using Rayleigh scattering media which has a density that falls off
> >> exponentially
> >> with height. The test is only partially successful: it seems that the
> >> media
> >> atmosphere is not giving any contribution to the radiosity lighting. Still
> >> have
> >> to figure out if there's any way to increase the contribution of the
> >> scattering
> >> media to the radiosity while still allowing the colour of the sky to
> >> remain
> >> visible.
> > Just a thought... As you are having a problem getting the media to
> > contribute to the radiosity of objects within the object containing the
> > media, why not excavate a volume for the objects from that object as
> > follows:
> > union
> >     difference
> >         sphere{0, 100000}
> >         sphere{0, 1000}
> >         interior{media{...}}
> >     union
> >         //Other objects all within the inner sphere above
> > Rarius
> Similar to, but more complicated than:
> sphere{0,1000 interion{media...}}hollow texture{...}}
> No need to use the union.
> Alain
> If you pick up a starving dog and make him prosperous, he will not bite you;
> that is the principal difference between a dog and a man.
> Mark Twain
Thanks for the help everyone, I ended up using
difference {
 sphere { ... }
 sphere { ... }
 hollow
 interior { ... }
.... rest of scene ...
and the radiosity has worked. Here's the new version of the animation.
Download 'mediaatmosphere2.mpg' (314 KB)
Date: 23 Oct 2008 22:20:01
Message: <web.4901309f657b8a9578dcad930@news.povray.org>
> Filling an inverted sphere out of view is akind of filling the whole scene with
> uncontained media. You don't need the sphere, just the media definition.
Yes, that finally occurred to me--after posting my message, of course. :-S
But I still can't get that simple idea to work correctly. I'm just doing
something wrong, probably very obvious.
KW
Date: 23 Oct 2008 22:25:00
Message: <web.4901315b657b8a9578dcad930@news.povray.org>
> follows...
I actually never thought of doing that. Nice idea, very much appreciated!
Thanks.
Ken W.
Date: 5 Nov 2008 23:05:00
Message: <web.4912682c657b8a9578dcad930@news.povray.org>
"Kenneth" <kdw### [at] earthlinknet> wrote:
> >  Try this: Make a small sphere, out of camera view, fill it with
> > media, then INVERSE the sphere. [And add a scene-filling object in the
> > background, for the media to appear against.]
> > According to my notes, that 'fills the universe' with media, and the scene
> > no longer shows those radiosity problems!
> Well...I can't seem to reproduce that result now. I don't
> remember how I came up with that idea, but it doesn't work (although
> my old notes say it does.) Can't trust those old notes. :-$
> Sorry for sending you on a wild goose chase! I'll continue to try and figure
> out my error...
For what it's worth, I did finally figure out how to reproduce this. Strangely,
it depends on the Bounding_Threshold value in the .ini file (or on the command
line.) By setting the threshold to one MORE than the total number of objects in
the scene, the inverse trick works, and the media appears everywhere outside the
sphere. (Lights don't count in this total.) If the threshold value is <= the
total number of objects, inverse has no effect, and the media still appears
inside the media object. Bounding_Threshold shouldn't behave that way, AFAIK.
I also found something else strange (if my eyes are not deceiving me): Using
inverse, the new 'universe-filling' media is not contributing anything to the
rad lighting. Only the INVISIBLE media in the sphere is (!), and again in the
same incorrect way. But there shouldn't be any media in the sphere now.
Perhaps there are hidden clues here to rad's odd behavior with object media.
Ken W.
Date: 6 Nov 2008 10:22:55
Message: <49130bcf$1@news.povray.org>
Kenneth nous illumina en ce 2008-11-05 23:00 -->
>> out my error...
> Ken W.
If there is nothing between you and the background, you get "infinite" paths.
Media is not eveluated along an infinite path. If you have a beam of light,
then, things change, the samples are taken within the beam.
Where you have your inverted sphere, the path is no longer infinite, it stops at
the sphere.
Adult, n.: One old enough to know better.
