POV-Ray : Newsgroups : povray.binaries.animations : Holorec-room animation Server Time
21 Apr 2026 18:17:01 EDT (-0400)
  Holorec-room animation (Message 1 to 7 of 7)
Subject: Holorec-room animation
Date: 18 Aug 2007 12:40:01
Message: <web.46c72046c88e60ed8d92e1a00@news.povray.org>
Thanks to John VanSickle, I finally found a rather efficient way to make a
fade in animation of my holo-rec room.  I attatched a video which shows the
results of my first tests. It is a bit damadged, but that was an mpeg
compression artifact.
The holo-rec room is a new model I made a couple weeks ago, and the room it
turns into is the old model of the USS Starrider bridge, from my
'technology' round animation entry.
Please leave suggestions for improvement.  I want to perfect this method
before the IRTC becomes active again.
Download 'test 1.m1v.mpg' (586 KB)
Subject: Re: Holorec-room animation
Date: 18 Aug 2007 15:50:02
Message: <46c74d6a@news.povray.org>
"Nimish Ajmani" <nomail@nomail> wrote in message
news:web.46c72046c88e60ed8d92e1a00@news.povray.org...
> the
> it
     That's working well with my <poor> eyes.
     You think it will become active again? I do too at some stage. But
when, nobody knows.
        ~Steve~
Date: 18 Aug 2007 19:40:00
Message: <web.46c781e669d26ab58d92e1a00@news.povray.org>
> > the
> > it
> when, nobody knows.
>         ~Steve~
Thanks for the comments.
Does anyone have any other comments?
  --Nimish
Date: 19 Aug 2007 06:13:47
Message: <46c817db@news.povray.org>
> method before the IRTC becomes active again.
Generally it looks nice.
But has the moving thing been left out from the mask? It looks like the
transition on the wall behind it overlaps with it, which looks a little odd.
Rune
http://runevision.com
Date: 19 Aug 2007 09:05:01
Message: <web.46c83f7869d26ab5b4a03ea00@news.povray.org>
Yes.  I noticed that too just last night.  I worked overnight to create a
mask object for the character, which reflecets on an equal basis of the
real thing, for a better look.  It's taking some time to create the mask,
because I never anticipated I would need a plain black-and-white texture,
so it took a while.
I plan to post an improved test shot when I have solved the mask problem.
So far, that is the only solution I have found, but it seems to be working
ok.
Thanks for the comment.
  --Nimish
> Rune
Date: 21 Aug 2007 19:09:15
Message: <46cb709b@news.povray.org>
The effect is cooler if the shape of the start and end rooms are
different.  I know that in my shot this was not so apparent, which is
why I put the rolling tumbleweeds in there.
John
Date: 22 Aug 2007 09:15:00
Message: <web.46cc367669d26ab5b4a03ea00@news.povray.org>
Well, this was a first test.  Thanks for that tip on the effect.
I am working on a test 3 shot.  Test two was just finished.
Sincerely
  --Nimish
> Regards,
> John
