POV-Ray : Newsgroups : povray.binaries.animations : Sierpinsky changing ... Server Time
28 Mar 2026 19:39:48 EDT (-0400)
  Sierpinsky changing ... (Message 1 to 10 of 11)
Subject: Sierpinsky changing ...
Date: 21 Feb 2007 03:15:08
Message: <web.45dbfe304826d74569322de90@news.povray.org>
Hi people,
after some playing around with simple puppets (see all those "pigs" here and
in p.b.i. ) I revisited the realm of fractals. Here the Sierpinsky triangle
is rotating through disconnected stages into something vaguely resembling a
snowflake - though NOT Koch's snowflake, obviously. I don't know what the
final fractal is called - searching the net for "Sierpinsky" gives too many
hits :-)
I apologize for the quality - fractals don't compress so well ...
comments welcome (or else I woudn't post it here)
Karl
Download 'sierpins.mpg' (593 KB)
Subject: Re: Sierpinsky changing ...
Date: 21 Feb 2007 03:56:57
Message: <45dc0959$1@news.povray.org>
> Hi people,
> hits :-)
> Karl
Nice ! But really too short or too quick: one has barely the time to see
what happens. Can you make a slower version ?
tuabiht
Date: 21 Feb 2007 07:05:00
Message: <web.45dc34122d375289dca0ceae0@news.povray.org>
> tuabiht
Hello Thibaut,
Thank you. My main interest in this thing is the final shape. Since this
thing parses awfully slowly on my old Mac (about two minutes per frame) and
I would like go back to different things in my sparse spare time, I propose
you do that for yourself. Since the source is quite short, I hope it will
be ok  if I append it here:
//----- cut here for sierpinsky.pov
//#include "VectorStuff.inc"
#include "transforms.inc"
#macro UnitV_XY( Phi ) // from my VectorStuff.inc; UnitVector in xy-plane
   < cos( radians( Phi ) ), sin( radians( Phi ) ), 0  >
#end //#macro UnitV_XY( phi )
#declare TransForms = array[3] ;
#declare cc = 0;
#while( cc < 3 )
 #declare TransForms[cc] =
 transform{
  scale 0.5
  rotate 60*clock*z
// angles outside 0..60 give same pictures, partially mirrored
  translate UnitV_XY( cc*120-30 )
 #declare cc = cc+1;
#end // #while( cc < 3 )
#declare ptnum = 20000; // more would be better, but traces SLOWLY
#declare skip = 10;
#declare ptnum = ptnum+skip;
#declare Points = array[ptnum];
#declare MyStream = seed( 0 );
#declare cc = 0;
#declare Points[cc] = < 0,0,0 >;
#declare Points[cc] = < 2*rand(MyStream)-1, 2*rand(MyStream)-1, 0 >;
#while( cc < skip-1 )
   #declare cc = cc+1;
      vtransform( Points[cc-1], TransForms[3*rand(MyStream)] );
#end //#while( cc < skip-1 )
#while( cc < ptnum-1 )
   #declare cc = cc+1;
   sphere{ Points[cc]+4*z 0.005 pigment{ color 0 } }
#end //#while( cc < ptnum-1 )
 up y right x*image_width/image_height
background{ color 1 }
//----- end of sierpinsky.pov
some comments:
- "ptnum" gives the number of spheres finally traced; 20000 is MINIMUM !
- render with square picture and lowest quality settings; the spheres are
used as pixels, no reflections or shading required
- make an animation; clock going from 0...1 as usual, with as many pictures
as you want (or care to watch tracing)
This is just a quick hack, you probably don't need to put all the points
into an array, but I'm not going to work on it for the time being because
of other projects I'm dreaming of ...
Thank you for your comments
Karl
Date: 21 Feb 2007 15:00:27
Message: <45dca4db@news.povray.org>
ok, I' ll dot it. With a recent machine, parse/render is not really a
problem (for me, with ptnum=100000, parse time is 32 sec. and render
time is 5 sec. at 800x800)
I will post the animation as soon as possible
Thibaut
Date: 22 Feb 2007 11:50:00
Message: <web.45ddc97f2d375289e4daf5f50@news.povray.org>
> Thibaut
Sounds like a plan :-)
I have about 30 secs parse time with ptnum=5000 (five thousand), so you may
understand why I don't want to detail that any further. There is always the
possibility of rendering over night, of course ...
I'm looking forward to a refined version of this.
Greetings
Karl
Date: 25 Feb 2007 05:58:25
Message: <45e16bd1@news.povray.org>
The anim should now be visible at :
http://big.chez-alice.fr/tuabiht/sierpinski01.gif
(animated gif, size ~ 1.8 Mo)
To see more clearly the inital and final states, I have put small pauses
at these points.
tuabiht
Date: 25 Feb 2007 10:30:00
Message: <web.45e1aa602d375289e755c5e50@news.povray.org>
> at these points.
> tuabiht
Looks great - and BIG :-)
Thank you for your efforts and your cpu time.
I am still searching for the name of the snowflake-like thingie which is
(not quite) in the middle of your animation and at the end of mine. I can't
imagine that something so regular has not been found before. Until now I
have not found another picture of it on the net, but the search continues
Greetings
Karl
Date: 25 Feb 2007 15:24:34
Message: <45e1f082$1@news.povray.org>
You are welcome. This was very little work in fact (the most difficult
bit was to put it on the internet :-).
My next plan, which will require more work, is to read and understand
your code !
Thibaut
Date: 26 Feb 2007 01:30:01
Message: <web.45e27e2b2d3752891c7e56870@news.povray.org>
> your code !
Hi Thibaut,
I COULD go into lengthy explanations here, but RealLife(TM) is interfering
in form of my little daughter (aged 6), who has caught quite a cold!
But here are some keywords for mathematical background:
"iterated function systems" and "chaos game"; you might have a look at
http://mathworld.wolfram.com/ for some (very short) explanations.
Greetings
Karl
Date: 26 Feb 2007 03:20:00
Message: <web.45e297392d375289f1cb1e660@news.povray.org>
> your code !
> Thibaut
Some people who are interested in Sierpinsky fractals also use Fractint. :-)
http://spanky.triumf.ca/www/fractint/fractint.html
