POV-Ray : Newsgroups : povray.binaries.animations : sweep through animated door Server Time
21 Apr 2026 23:19:36 EDT (-0400)
  sweep through animated door (Message 11 to 12 of 12)
Subject: Re: sweep through animated door
Date: 10 Feb 2007 07:14:39
Message: <6pdrs21lgtp7ta4sknqcld2uum99muakhv@4ax.com>
On Fri,  9 Feb 2007 12:44:59 EST, "quickfur" <qui### [at] quickfurathcx> wrote:
>Maybe you should also check to make sure no light sources are
>lying exactly on the surface of some object
That's interesting, something I've never thought about. Probably because I use a
modeller and can see where my objects are.
I still think the culprit is the materials and of course we never use jitter or
crand. I would have posted the mpg I did but the only flicker was in the ground
and that's not what I was testing.
Regards
Date: 12 Feb 2007 14:45:00
Message: <web.45d0c2f151af3f9d47d3ae5e0@news.povray.org>
"Charles C" <nomail@nomail> wrote:
> "RusHHouR" <gee### [at] mailnu> wrote:
> > > Nice animation especially the timing. Your materials are not particularly
> > > suitable for animations, though. But then you must know this from your post
> > > Stephen
> > Hehehe. Thanks, and yeah, the door's flicker doesnt go by unnoticed... XD
> > About the flickering flick; more fps, sturm off(!) and high AA actually got
> > rid of most of it. Scaling up texture and experimenting with different
> > bitrates settings also playes a part.
> > So I learnt a lot there! None of that shows in this clip though! ;)
> Two other things:  If you don't already have jitter off in your ini file,
> definitely turn it off.  Then also if you don't mind rendering X times as
> many more frames, you could do a little motion blur instead of a higher
> fps. You can set up another .pov scene to average every Y number frames for
> some subtle motion blur. It should be subtle if X >= Y.
> BTW, nice brick/stone-work.  I can't wait to see what's upstairs!
> Charles
Hehe thx Charles!
I have to stress that this render wsa only a test for the movement of camera
+ door. But the jitter discussion is always interesting. Motion blur, gotta
look into that!
However, I think Ill have to disappoint you on the upstairs... The stairs
are gone or let's say moved. This is what the scene is now. Will probably
just end up as a still...
Download 'castle_gard.jpg' (230 KB)
Preview of image 'castle_gard.jpg'
