Cute! I'm not sure what I'd use it for, but I like it!
Why not web it?
dan B hentschel wrote:
> I wrote a Perl script that takes a .mid file as an input, and creates a .inc
> file as output. I have tried it with several different MIDI files with
> varying success. Sometimes the timing is a bit off. Is it worth my time to
> clean this up and make it available? Would anyone like to use it?
I like it. Would you care to share it on the wiki?
http://povray.tirnalong.com
Cool!
How does your perl script work?
Paolo
> Why not web it?
Ok, so I spent a few working on it, and I feel that it's pretty well
documented, and pretty extensible at this point. Whip together a
shake-n-bake web page, and here you go:
http://www.hentschels.com/povray.htm
- dan B hentschel
You're welcome to list it there if you like. See my previous post for web
location of source files.
- dan B hentschel
"Paolo Gibellini" <p.g### [at] teinos com> wrote:
> Cool!
> Paolo
Well, the best way to see that would be to look at the script, itself, now
located on my web page. Here's a quick rundown:
1) Make use of code someone else wrote, in this case, the MIDI Perl module
written by Sean M. Burke, and available from CPAN.
2) Calculate note on-off events in terms of seconds, rather than the "ticks"
unit used in MIDI files.
3) Add enough bugs such that the calculation in step 2 is frustratingly
close to correct, but very slightly off.
4) Output note on-off events to a large POVRay include file with multiple
arrays, and arrays of arrays.
5) Write a handful of macros to parse these arrays to glean meaningful
information.
6) Fudge with the framerate/duration of the resulting animation such that
the bugs mentioned in step 3 are not a problem any more.
There you go. :-) Obviously, I don't really like steps 3/6, so if anyone
wants to take a look at it and recommend a fix for me, that would be great.
I may revisit it agian in the future if I get the motivation, but for now
I'm itching for a new project.
- dan B hentschel
I use Mimic to do that, what programs do you use?
Jaime Medina
Have you seen my animation?
http://jaimemedina.com/TV/
Your comments will be appreciated
"dan B hentschel" <dan### [at] alum rit edu> wrote in message
news:web.41d95965acb6c853a3fcf12a0@news.povray.org...
Well, here's what I did with my Christmas vacation. I got to thinking
that
it wouldn't be too difficult to parse a MIDI file into a POV .inc and
then
use the note on-off events to synchronize an animation to the music. I
ended up using the technique to produce a background movie for the DVD
menu
system I created for the Japanese Anime, "Piano". Here is a small
portion
of that movie.
a .inc
time to
clean this up and make it available? Would anyone like to use it? For
now,
I've gotten what I wanted from it. So if there's no interest, I'll
probably
move on to another project.
Let me know what you think!
- dan B hentschel
Video is in DivX format. My apologies to those who are not able to see
it.
Download 'iso-8859-1' (3 KB)
Hmm.. I did a search, and wasn't able to come up with anything in the POV
newsgroups for Mimic. Is that a different render suite? Or is it a POV
utility? As for what programs I use:
1) Perl (scripting language)
2) POVRay
Maybe I don't understand your queston?
- dan B hentschel
"dan B hentschel" <dan### [at] alum rit edu> wrote:
> Well, here's what I did with my Christmas vacation. I got to thinking that
> it wouldn't be too difficult to parse a MIDI file into a POV .inc and then
> ended up using the technique to produce a background movie for the DVD menu
> system I created for the Japanese Anime, "Piano". Here is a small portion
> of that movie.
> clean this up and make it available? Would anyone like to use it? For now,
> I've gotten what I wanted from it. So if there's no interest, I'll probably
> - dan B hentschel
> Video is in DivX format. My apologies to those who are not able to see it.
I'm sitting waiting for my daughter to get out of ballet class, and thought,
hmmm, I've really wanted to be able to do an animation from MIDI - brief
hunt
on the internet and BINGO! ;) And you basically just did it! I'm going to
try to re-write it into POV script and add handling for continuous
controllers.
I'll post it when I'm done!
> > of that movie.
> > - dan B hentschel
> hunt
> controllers.
Foo. So now I know why you used something like Perl - no binary I/O in
PovScript. Guess I need to learn perl :)
This is a really good start. I'll try to find your timing error too.
