POV-Ray : Newsgroups : povray.binaries.animations : Jelly Trip Experience (HD) Server Time
14 Jun 2024 10:52:48 EDT (-0400)
  Jelly Trip Experience (HD) (Message 1 to 10 of 10)
Subject: Jelly Trip Experience (HD)
Date: 17 Oct 2009 12:25:00
Message: <web.4ad9ef43afac4cc08824496a0@news.povray.org>
Hi! I just uploaded this 10-minutes isosurface animation:
http://www.youtube.com/watch?v=btVGCqpIoyk&fmt=22
18210 frames, 854x480 resolution, 30fps.
Rendering time: 3 weeks (on a quad core system).
Cheers,
Burkhard
Subject: Re: Jelly Trip Experience (HD)
Date: 17 Oct 2009 13:44:25
Message: <4ada0279$1@news.povray.org>
> Cheers,
> Burkhard
The music is not to my taste but it does go well with your beautiful
animation. :D
Best Regards,
Date: 17 Oct 2009 14:55:00
Message: <web.4ada12f01b5d6f7dcac4259f0@news.povray.org>
Nice!  Did you use multiple instances of v3.6 or were you using b3.7?
Date: 17 Oct 2009 15:55:01
Message: <web.4ada20891b5d6f7d8824496a0@news.povray.org>
Four instances of 3.6. That's where a multi-core CPU comes in really handy :)
Date: 17 Oct 2009 21:15:00
Message: <web.4ada6b441b5d6f7d2fa217c50@news.povray.org>
> Cheers,
> Burkhard
Beautiful!
The music fits very well, too.
Simone
Date: 17 Oct 2009 23:35:00
Message: <web.4ada8c631b5d6f7dc0d5b1230@news.povray.org>
"mone" <mon### [at] alienenterprisesde> wrote:
> Beautiful!
> Regards,
> Simone
Sine then I always wanted to use it as background music for some video. Well now
I made the video for it :o)
Cheers, Burkhard
Date: 18 Oct 2009 02:55:01
Message: <web.4adab9ae1b5d6f7dcac4259f0@news.povray.org>
Cool. That's what I do too. Often my parse time is way longer than the render
time so multiple instances even of 3.7 is what I'll probably end up doing in the
future.
Charles
PS, I had a certain special appreciation for your video after spending some
20-something days rendering something sort-of related.  ("psychedelic scrambler"
if curious.)
Date: 18 Oct 2009 03:00:01
Message: <web.4adabbef1b5d6f7dcac4259f0@news.povray.org>
future.
Charles
if curious.)
Date: 18 Oct 2009 09:36:02
Message: <4adb19c2$1@news.povray.org>
It's beautiful, but also a bit repetetive to watch it
actively for a full 10 minutes. But in the right chill
out setting it's probably appropriate ;)
Also, it seemed to freeze sometimes although data
was still buffered in the player, so I wondered if this
was part of the actual animation.
Date: 18 Oct 2009 09:48:26
Message: <4adb1caa$1@news.povray.org>
I also had this problem recently when animating the galaxy data
from the 6df survey. I ended up hacking 3.7b to allow variables
which persist their values between individual renders. It wasn't
a clean solution (more like a designed memory leak) and would
require much additional work to make it a real feature (if
the pov team even wished to include such a feature).
But I'd be interested to hear if long parse times are a common
problem for animations, and if those parse times could be reduced
by reusing a variable, such as a large array or a complex CSG
object, from the previous frame.
