POV-Ray : Newsgroups : povray.binaries.animations : can someone please point me to ... Server Time
30 Mar 2026 15:31:26 EDT (-0400)
  can someone please point me to ... (Message 1 to 6 of 6)
Subject: can someone please point me to ...
Date: 17 Jan 2001 18:14:38
Message: <3a66275e@news.povray.org>
the post where someone had a fancy ball flying around and some kind of
"guns" followed him ...
I know it was here a VERY long time ago, and I don't know from whom it was,
but he must have used a macro that takes an location and a target as vectors
and gives back some rotations ...
If someone knows what I mean, please tell me, where I have to look at ...
I have to admit, that I'm currently to lazy to figure this out myself ...
AFAIK it goes like a conversion of cartesian coordinates to polar
coordinates ...
it was something with atan, but IIRC there have been some special cases to
handle when something like x/y was zero ...
I'd prefer to find a macro (of course, I'm sure there is one) ....
ThanX ... Jan
Jan Walzer
Subject: Re: can someone please point me to ...
Date: 17 Jan 2001 18:40:25
Message: <chrishuff-D794A1.18412817012001@news.povray.org>
Paul Daniel Jones <pdj### [at] psuedu>    auto-tracking [594 Kb]  11303
10/4/00 7:26 AM
Message-ID: <39DB2206.198A1493@psu.edu>
The message didn't mention anything about the source code though...it
just mentioned that it was going to be used in a scene.
Christopher James Huff
Date: 18 Jan 2001 02:13:04
Message: <3a669780@news.povray.org>
Jan Walzer wrote in message <3a66275e@news.povray.org>...
vectors
I wrote a couple of macros to do that:
#macro Bearing(__Location, __Target)
 degrees(atan2((__Location.z-__Target.z),-(__Location.x-__Target.x)))
#macro Elevation(__Location, __Target)
degrees(atan2((__Target.y-__Location.y),sqrt(sqr(__Location.x-__Target.x)+sq
r(__Location.z-__Target.z))))
Bearing() gives you the rotation around the y axis for the gun turret, and
Elevation() gives you the rotation about the z axis for the gun.  Example:
Your gun turret is at <1,2,3>, and you are shooting at a target at <-5,4,7>:
union{
    object{GunBarrel rotate z*Elevation(<1,2,3>,<-5,4,7>)}
    object{GunTurret}
    rotate y*Bearing(<1,2,3>,<-5,4,7>)
    translate <1,2,3>
Mark
Date: 18 Jan 2001 04:19:12
Message: <3a66b510$1@news.povray.org>
Thanx a lot ...
Jan
Subject: macro putto
Date: 22 Jan 2001 06:05:52
Message: <3a6c1410@news.povray.org>
I recently rewrite a macro to easily place an object maybe it can help you
or inspire you
The syntax is like :
object { Yourobject transform
putto(refA,refB,norm1,newA,newB,norm2,option) }
refA and ref B  : two points used as starting position
norm1 : if the object need to be oriented this vector is orthogonal to
vector(ptB-ptA)
newA , new B ,norm2  : final position
option : scling type ( 0 uniform scaling )
example :
"fleche" is an arrow build between the points -1*x, 1*x
to place it between two points A and B write :
object { fleche transform putto(-1*x,1*x,0,A,B,0,0) material { example }}
"normal vector" are 0 because fleche don't need orientaion : it is an object
of revolution
I use this macro a lot to copy a same object between multiple position.
I hope this could help
Sorry for my english
Download 'img0.jpg' (3 KB) Download 'img1.jpg' (3 KB) Download 'img2.jpg' (5 KB) Download 'macroputto.inc.txt' (7 KB) Download 'mopspatch.inc.txt' (15 KB) Download 'putto_ex.pov.txt' (4 KB)
Preview of image 'img0.jpg'
Preview of image 'img1.jpg'
Preview of image 'img2.jpg'
Subject: Re: macro putto
Date: 22 Jan 2001 11:32:47
Message: <3a6c60af$1@news.povray.org>
Hi m.o.p.s.
Could you please cancel your post here at povray.binaries.animations?  The
message would be better placed at povray.binaries.scene-files group instead of
here.  I see that Thorsten Froehlich has already moved your other message post
to povray.general but it really belongs at povray.binaries.scene-files in
whole.  Separate images going to povray.binaries.images with a mention of the
p.b.s-f. message might be another thing to do.
Thanks.
Bob H.
