POV-Ray : Newsgroups : povray.binaries.animations : balls 4x4x4 grid (249+198k) Server Time
1 Jun 2024 13:19:28 EDT (-0400)
  balls 4x4x4 grid (249+198k) (Message 11 to 13 of 13)
Subject: Re: balls 4x4x4 grid (249+198k)
Date: 2 Jun 2002 15:06:47
Message: <Xns9221D6C7D3ED3gergelyvamoraviaitco@204.213.191.226>
Christoph Hormann <chr### [at] gmxde> wrote in
news:3CF### [at] gmxde:
> I tried some larger grids of masses with my simulation system.  It of
> course takes much longer, several hours on an Athlon 1 GHz.
Hmm, my 5x5x5 piece renders significantly faster. But it does look good.
I believe the cause of this might be the way your system handles
connections, but I can't be sure until I see the source. :)
Cheers,
Gergely
Date: 2 Jun 2002 15:39:22
Message: <3cfa746a@news.povray.org>
> #10 won't look so good with a mesh. If you look closely you'll see
> that the most contorted part of the cube becomes inverted (inside-
> out).
Hm. You're right. But if we knew where the outline/border of the box is, it
could be used for self collision detection.
Date: 2 Jun 2002 16:19:25
Message: <3CFA7DC9.AF6D2933@gmx.de>
Thanks.
The main influence factor is the number of integration steps.  I used 30
per frame with a Heun integration method (i.e. 2 evaluations per step).
Last updated 02 Jun. 2002 _____./\/^>_*_<^\/\.______
