POV-Ray : Newsgroups : povray.beta-test : Povray 3.7 RC7, something strange with parametric surfaces? Server Time
16 Nov 2025 19:42:07 EST (-0500)
  Povray 3.7 RC7, something strange with parametric surfaces? (Message 1 to 6 of 6)
Subject: Povray 3.7 RC7, something strange with parametric surfaces?
Date: 27 Feb 2013 14:10:01
Message: <web.512e5917524bb9ec1343b2e50@news.povray.org>
Greetings,
I'm a long-time PoVRay user and I'm encountering a problem with PovRay 3.7 RC7,
when it comes to parametric surfaces.
I have a small scene that renders fine when the surface is *not* in it, but with
the surface, the scene renders to 99% complete (rather quickly, using 8 cores),
but then it just sits there, with only 1 core running (via system monitor) at
100%.    It almost appears as if PovRay is failing to collect a "rogue thread"
but I can't really tell what's happening.   The scene is very small so I've
copied it below.
Are there any known issues with parametric surfaces and the PovRay beta?  I've
seen a post concerning textures but my surface is not textured -- it's just
partially transparent.
Thanks for any information.  The scene is copied below.
#version 3.7;
// #include "chars.inc"
#declare fontdir = "/usr/share/fonts/truetype/lyx/cmr10.ttf";
#declare flat_fin = finish { ambient 0.0 diffuse 1.0 reflection 0.05 };
#declare out_fin = finish { ambient 0.0 diffuse 1.0 reflection 0.0 };
#declare c1 = <1,0,0>; // tet vertices on sphere
#declare c2 = <0,1,0>;
#declare c3 = <0,0,1>;
#declare sr = 0.019; // sphere radius
#declare sc = rgb< 0.8, 0.8, 0.8 >; // sphere color 1
#declare cr = 0.01; // cylinder radius
#declare cc = rgb <1, 1, 1>; // cyl color 1
#declare dc0 = MediumSpringGreen; // dual 0-cell color
#declare dr0 = 0.022; // dual 0-cell radius
#declare dc1 = MediumSpringGreen; // dual 1-cell color
#declare dr1t = 0.013; // dual 1-cell tip radius
#declare dc1t = MediumSpringGreen; // dual 1-cell tip color
#declare dr1 = 0.012; // dual 1-cell radius
#declare textcolour = IndianRed;
#declare dc2a = rgbf <0.1, 0.9, 0.3, 0.6>; // slight green
#declare dc2b = rgbf <0.1, 0.3, 1, 0.6>;   // slight blue
#declare dc2c = rgbf <1, 0.2, 0.2, 0.6>;   // slight red
#declare dc2d = rgbf <0.8, 0.8, 0.1, 0.6>; // slight yellow
#declare tsurfc = rgbf < 0.8, 0.8, 0.8, 0.6 >; // trans surf
#declare dr2 = 0.004; // dual 2-cell outline radius
#declare TTh = 0.2; // text thickness
#declare tc1 = rgbf <0.8, 1, 0.8, 0>; // tetrahedron color 1
#declare tc2 = rgbf <1, 0.4, 0.4, 0>; // tetrahedron color 2
// our hyperboloid coordinate system
#declare C1 = function(r,A,l) { 1.0 - (r*sin(A)/sqrt(sinh(l)*sinh(l) +
cosh(l)*cosh(l))) }
#declare C2 = function(r,A) { r*cos(A) }
#declare Tx = function(r,A,l,T) { sinh(l)*cos(T)*C1(r,A,l) - C2(r,A)*sin(T) }
#declare Ty = function(r,A,l,T) { sinh(l)*sin(T)*C1(r,A,l) + C2(r,A)*cos(T) }
#declare Tz = function(r,A,l,T) { cosh(l)*C1(r,A,l) }
global_settings {
    radiosity {
      pretrace_start 0.08
      pretrace_end   0.04
      count 50
      nearest_count 5
      error_bound 0.2
      recursion_limit 4
      low_error_factor 0.4
      gray_threshold 0.0
      minimum_reuse 0.01
      brightness 1
      adc_bailout 0.01/2
         location <-6, 0, 0.5>
         look_at <0,0,0.75>
         angle 50
         sky z
plane
 <1,0,0>, 0
 pigment { checker color White, color White }
 finish { ambient 0 diffuse 1 reflection 0.05 }
 translate <2,0,0>
// true type fonts located in /usr/share/fonts/truetype/jsmath  maybe
jsMath-cmr10.ttf is good?
light_source
 <-5, -2, 1 >
 color White
 area_light <0.6,0,0>,<0,0.6,0>,16,16
union
    quadric
     <1,1,-1>, <0,0,0>, <0,0,0>, 1
     clipped_by { sphere { <0,0,1>, 2 } }
     texture { pigment { color tsurfc } }
     finish { out_fin }
    quadric
     clipped_by { plane { <0,0,-1>, -2 } }
     clipped_by { plane { <0,0,1>, 2.14 } }
     finish { out_fin }
    torus
     sqrt(3), 0.02
     rotate <90, 0, 0>
     translate <0,0,2>
     texture { pigment { color dc2d } }
// #declare Tx = function(r,A,l,T)
   parametric
    { // to draw hyperbolas on surface...
     function { Tx(0.1,v,u,0) },
     function { Ty(0.1,v,u,0) },
     function { Tz(0.1,v,u,0) }
     <-1,0>, <1, 2*pi >
   plane
    <0,0,1>, 0
    texture { pigment { color sc } }
    finish { out_fin }
    clipped_by { sphere { <0,0,0>, 1 } }
    sphere
    <0,0,-1>, 0.04
    finish { out_fin }
Subject: Re: Povray 3.7 RC7, something strange with parametric surfaces?
Date: 27 Feb 2013 18:33:11
Message: <512e97b7$1@news.povray.org>
Le 27/02/2013 20:05, Ryan Budney nous fit lire :
> Greetings,
> copied it below.
Thanks.
in 3.7, image is rendered in small square chunk. What you see is the
last chunk being very long (very very .... very ... very long) to trace.
> cosh(l)*cosh(l))) }
You could speed up a bit by replacing sinh^2(l)+cosh^2(l) with cosh(2l)
(+Q3 went from 28 seconds to 22 seconds with that change)
Ray->Shape Intersection          Tests       Succeeded  Percentage
Parametric                      119326             477      0.40
Parametric Bound                119326          119326    100.00
Function VM calls:        100309541
  Trace Time:       0 hours  0 minutes 22 seconds (22.167 seconds)
  Trace Time:       0 hours  0 minutes 28 seconds (28.655 seconds)
Double clipped_by ? not sure it does what you expect
Use a single box instead. (but does it only appear at all ? as the
quadric is a duplicate of the previous one, clipped by a sphere)
The parametric can enjoy being clipped_by  sphere { <0,0,1>, 0.4 } }
Parametric                        8776             477      5.44
Parametric Bound                  9500            8776     92.38
You are also using radiosity with a parametric surface and a large area
light (16 x 16!). That's slow. (something like 256 slower)
Last: simplify your formula, C2(r,A)*sin(T) when T=0 is a waste of time
for Tx.
Same for Ty, the sinh(l)*sin(T)*C1(r,A,l) is also 0.
Just dropping these 2 zero rendered in 15 seconds at +Q3. (instead of 22)
And if you comment the cos(T) in Tx & Ty (because cos(0)=1), it drops to
12 seconds (with +Q3).
+Q4 push me at 51 seconds, and going +Q5 is far too long for something
that look like a small sphere at the bottom of the parabola.
Date: 27 Feb 2013 19:22:21
Message: <512ea33d@news.povray.org>
Am 27.02.2013 20:05, schrieb Ryan Budney:
> light_source
>   <-5, -2, 1 >
>   color White
When using area lights, /always/ make them adaptive. Size should be
2^N+1 for that, so for example:
   area_light <0.6,0,0>,<0,0.6,0>,17,17
   adaptive 1
I usually also use "circular orient".
Date: 28 Feb 2013 20:05:03
Message: <web.512ffe244ef32a7785b1e6b80@news.povray.org>
Thanks for the comments Forgeron and Clipka.  I didn't think there would be such
a massive change in render times!  Without the parametric surface the scene
renders on my laptop in a couple seconds.
I lowered the quality and got a quick render-time again.
The surface isn't supposed to be that blob, it's supposed to be a small tube
around a hyperbola... It looks like I don't understand how PovRay "functions"
work... but that's something that I should be able to sort out.
Date: 28 Feb 2013 20:20:00
Message: <web.513001214ef32a7785b1e6b80@news.povray.org>
Ah! Figured it out.  I hadn't realized parametric objects have a default
contained_by.   My PovRay world is back in order.
Date: 28 Feb 2013 22:23:10
Message: <51301f1e$1@news.povray.org>
>> light_source
>>   <-5, -2, 1 >
>>   color White
>    adaptive 1
For a test render, I usualy use adaptive 0, then, if needed, up this to
adaptive 1 or 2.
