POV-Ray : Newsgroups : povray.beta-test : Bug in PovRay 3.7 RC7 ?! Server Time
25 Apr 2026 14:22:51 EDT (-0400)
  Bug in PovRay 3.7 RC7 ?! (Message 11 to 19 of 19)
Subject: Re: Bug in PovRay 3.7 RC7 ?!
Date: 24 Feb 2013 06:09:27
Message: <5129f4e7@news.povray.org>
Le 24/02/2013 11:56, Dave Downing nous fit lire :
> I too am running this on the linux RC7 version to try to narrow down the
> issue.
I want to reproduce it before trying something from Christoph Lipka
(clipka).
> Still running after over 20 hours, but no errors so far.
> 160 frames generated of what looks like to be a wonderful animation.
> Is the bug limited to the Windows version?
Nope, but tied to the system memory management if the symptoms are
correct (rare condition), and if I got it correctly from the explanations.
Date: 24 Feb 2013 06:23:18
Message: <1kysq76.vrj0f019xy08cN%yvo.s@cancel_This_gmx.net>
Happens always after the first frame on Mac.
It takes a lot of time before all memory is released after a frame,
maybe too long?
Yvo
MegaPOV at:  http://megapov.inetart.net
MacMegaPOV at:  http://users.skynet.be/smellenbergh
E-mail: yvo(DOT)s(AT)gmx.net
Date: 24 Feb 2013 06:38:15
Message: <5129fba7$1@news.povray.org>
Am 24.02.2013 12:23, schrieb Yvo Smellenbergh:
Congrats, you've just volunteered to be our guinea pig for a solution :-)
I've shelved a few files in change #5817 (Workspace cli-pc-7) that
should fix the issue if our assumptions about the root cause are
correct; as far as I understand you should be able to access those
files, so if you wouldn't mind test-driving them...?
Date: 25 Feb 2013 16:50:00
Message: <web.512bdba5f3182cf6db8ca50@news.povray.org>
> Am 23.02.2013 21:46, schrieb clipka:
> >> Any suggestions on how to tackle this problem?
> > Yup: Please add a comment to http://bugs.povray.org/task/257; it sounds
> > to me like the issue hasn't been fixed for good yet.
> One more thing: Please make a backup of the scene in its current state;
> we currently don't know how common the issue is, so we might need your
> scene (and you and your computer) as guinea pig once we come up with a
> solution candidate.
Sure - no problem! FYI - I also tested it on another PC (128 GB RAM with 24
threads)... same issue there.
> If you can trim down the scene a bit while still reproducing the error,
> that would be a great help as well.
So this is the weird thing: including only one or a few of the *.inc files and
then, there is no error anymore! So it seems the size of the scene matters...
Date: 25 Feb 2013 16:55:01
Message: <web.512bdda0f3182cf6db8ca50@news.povray.org>
Dave Downing <cis### [at] hotmailcom> wrote:
> issue. In my case:
> CPU: Intel i7-3770K Quad Core Overclocked to 4.5GHz (I love saying that!)
> RAM: 16GB
> OS:  Fedora 18 x86_64
> > Should I presume +KFI0 +KFF360 +KI0 +KF1 ?
> > (361 frames, initial clock 0, final clock 1) ?
> Line 625 is the start of a series of #if's for each frame starting at 1.
> The clock variable is not referred to at all.
> I used:
> povray +w1920 +h1080 +KFI1 +KFF360 Scene_def.pov
> > (PS: 124 hard-coded paths of include, arghh... <3 I also got a warning
> > on each inc, about a null normal vector)
> I had the same warnings as you.
> I did a search and replace to make the path to the include files
> relative, no other changes to the source.
I'm somewhat having a deadline... would you be able to send me the 360 frames
rendered at 1920 x 1080 (AA 0.3)?
> Dave Downing,  Somerset U.K.
> No bytes were harmed in the making of this message.
Date: 25 Feb 2013 17:08:12
Message: <512be0cc$1@news.povray.org>
Am 25.02.2013 22:46, schrieb Alex:
Yvo was able to help investigating this issue, and it seems that yes,
memory consumption is the key after all: The backend seems to take
longer to free the allocated memory than the frontend is willing to wait.
Date: 25 Feb 2013 17:30:00
Message: <web.512be4f5f3182cf6db8ca50@news.povray.org>
Great news - when do you think this will be resolved? In other words, when will
I be able to download a version without this bug? Just worried I'll miss the
deadline :-(!
Date: 25 Feb 2013 19:15:36
Message: <512bfea8$1@news.povray.org>
>> files and
>> matters...
I haven't been following this thread closely so maybe this won't be any
help, but nevertheless I feel compelled to mention the six resource leak
bugs uncovered by Coverity ... CID's #967298-#967303 ... these were
found in either parse.cpp or parsestr.cpp
Date: 25 Feb 2013 19:20:40
Message: <512bffd8@news.povray.org>
>>> files and
>>> matters...
correction ... five bugs starting at CID #967299 /instead of/ #967298
