POV-Ray : Newsgroups : povray.beta-test : Newbie cannot make +D to work Server Time
15 Jan 2026 09:33:36 EST (-0500)
  Newbie cannot make +D to work (Message 1 to 7 of 7)
Subject: Newbie cannot make +D to work
Date: 2 Oct 2012 20:10:00
Message: <web.506b822fd235256c4a296dd40@news.povray.org>
I am rendering a scene (which is incredibly fast with 3.7 BTW) and would like to
use +D to display the image while it renders.  Is this broken?  I see in the
output that "Graphic Display" is set to "On" but no image appears while
rendering.    Here's what I'm doing:
 povray scene.pov +W2048 +H1024 +A  +SP16 -P +K0.0 Declare=TIMESTEP=0
Declare=USE_MMA=0 Declare=USE_CCS=0 Declare=USE_CCSM4_TIMESTEPS=0
Declare=STARS=1 Declare=GRADIENT=0 Declare=ROTATE_EARTH=80
Declare=DASHED_ORBIT=0 Declare=FULL_ORBIT=0 Declare=view_lat=40.0
Declare=DATAGRID=0 Declare=SATELLITE=0 Declare=view_dist=20.0 Declare=LOOKAT_X=0
Declare=LOOKAT_Y=0 Declare=LOOKAT_Z=2   +D
With 3.6.1, I get an image (even without +D) in 13 seconds.
With 3.7.0, the rendering is less than 1 second !! but I do not get my preview
window.
Any help?  Thanks.
Subject: Re: Newbie cannot make +D to work
Date: 2 Oct 2012 21:45:01
Message: <web.506b98286ba0fd709726a3c10@news.povray.org>
> window.
> Any help?  Thanks.
Have you tried +P so it pauses long enough to see it?
Date: 3 Oct 2012 03:06:13
Message: <506be3e5$1@news.povray.org>
> window.
> Any help?  Thanks.
Can you try it with the benchmark scene ? (copy benchmark.pov in your
directory from /usr/local/share/povray-3.7/scenes/advanced )
It should take enough time to see the window.
With your 1 second render, was the image-file created ?
Date: 3 Oct 2012 09:01:44
Message: <506c3738@news.povray.org>
> rendering.
It would help if you told us what your operating system is and how you
got povray on it (iow. did you compile it yourself or did you download
a precompiled binary, and if yes, where from?)
If you are compiling it yourself you need to install the SDL libraries
or else the preview won't work. Pay attention to what the configure
script prints.
Date: 12 Jul 2013 14:41:42
Message: <51e04de6$1@news.povray.org>
> script prints.
FWIW, this particular issue has caught me several times, and is annoying
every single time.  It's very easy to configure and build without
realizing that configure didn't find the SDL libraries, and if you miss
that one little message (or if you weren't even the one who compiled it in
the first place), there's no way to tell that this is actually the problem
you're encountering.
Firstly, IMHO, povray should not say "Graphic display......On" if it has
not been compiled with support for that function.  That is just plain
wrong and misleading.  In my opinion, in such cases it should default to
"Off" (or maybe even say something like "Disabled" instead of "Off"), and
if you try to specify "+D", it should error out with a message something
like "This version of POV-Ray was compiled without support for the Display
option"..
Date: 12 Jul 2013 16:16:33
Message: <51e06421$1@news.povray.org>
Le 12/07/2013 20:41, Alex Stewart nous fit lire :
>> script prints.
> option"..
you could at least look at the output of "povray --version".
Try it, you will be delighted.
Date: 12 Jul 2013 19:50:16
Message: <51e09638$1@news.povray.org>
Ok, I will admit that I didn't realize it printed that information when
you did "povray --version" (which is nice to know, thanks for the tip)..
I think my point still stands, though, that the current behavior when
compiled without SDL is still wrong and confusing..
