POV-Ray : Newsgroups : povray.beta-test : Real Time Ray Tracing Loop Server Time
15 Jan 2026 09:32:22 EST (-0500)
  Real Time Ray Tracing Loop (Message 1 to 6 of 6)
Subject: Real Time Ray Tracing Loop
Date: 20 Jun 2012 22:25:01
Message: <web.4fe285dc3da7c871182b97660@news.povray.org>
Is it possible to tell POV-ray to stop the real time ray tracing loop once it's
reached a certain frame?
Felix
Subject: Re: Real Time Ray Tracing Loop
Date: 25 Jun 2012 02:50:00
Message: <web.4fe8095e8956ebcc182b97660@news.povray.org>
"felipk101" <nomail@nomail> wrote:
> Hi,
> Cheers
> Felix
Or to stop it via a code in the .POV file?
Date: 25 Jun 2012 13:01:36
Message: <4fe89970$1@news.povray.org>
> Hi,
> Cheers
> Felix
Short: No.
Long:
When doing real time ray trace, there is no such thing as a frame count.
The frame_number and clock variables are not used at all.
As you can't possibly know how many frames have been rendered, you can't
stop after, say, 10, 100 or 1000 frames.
Date: 26 Jun 2012 15:04:31
Message: <4fea07bf$1@news.povray.org>
Could access the system's time and stop after n real seconds?  Is the
real time ray trace set to any particular rate or does it just go as
fast as the CPU will let it?
Tim Cook
http://empyrean.sjcook.com
Date: 27 Jun 2012 03:20:01
Message: <web.4feab3888956ebcc182b97660@news.povray.org>
> Tim Cook
I see... uhmm I'm starting to see a way!!!!
I'm using realtime ray tracing to pre calculate radiosity files per scene.
I have at least 20 scenes to run so I guess I can write a script to stop after
blah hours and then run next scene.
Thanks!!
Date: 27 Jun 2012 19:58:36
Message: <4feb9e2c$1@news.povray.org>
It goes as fast as the CPU can do the job.
>> Tim Cook
> Thanks!!
"Use realtime ray tracing to precalculate radiosity"?
How do you intend to retreive those data? When doing realtime ray
tracing, there is NO file output.
Realtime ray tracing is only available using version 3.7. It don't allow
you to save_file from the scene file. I don't think that it can save the
radiosity data using the command line options, or each frame will
overwite the previous one, remember no frame number means can't create
unique file names...
If you have 20 scenes that you want to run in sequence, you can use an
ini file that will launch those 20 scenes.
That ini file will set the radiosity data save parameters and can set
the resolution to use.
