POV-Ray : Newsgroups : povray.beta-test : probem with renderinq window on linux whit povray-3.7.0.RC3 Server Time
3 Mar 2026 15:15:32 EST (-0500)
  probem with renderinq window on linux whit povray-3.7.0.RC3 (Message 1 to 5 of 5)
Subject: probem with renderinq window on linux whit povray-3.7.0.RC3
Date: 17 Apr 2011 13:05:01
Message: <web.4dab1cfdb2ea9db2e161d0420@news.povray.org>
hello
I can't open a rendring window when calculating image.
Do you know how to resolve that?
i'm using linux 2.6.32-30 generic (lucid 10.04) under Amd64 dual core.
Beny
Subject: Re: probem with renderinq window on linux whit povray-3.7.0.RC3
Date: 17 Apr 2011 13:11:42
Message: <4dab1f4e$1@news.povray.org>
On 04/17/2011 02:01 PM, beny wrote:
> hello
> Beny
from the command-line do: povray -version
Built-in features:
   I/O restrictions:          enabled
   X Window display:          enabled (using SDL)
   Supported image formats:   gif tga iff ppm pgm hdr png jpeg tiff openexr
   Unsupported image formats: -
you're looking for the X Window display information ... if you don't get
that you need to check out the read me with the source build
instructions and rebuild with lib sdl package installed. If you're
getting the proper info (like above) ... are you using +d comman line
option?
jim
Date: 17 Apr 2011 13:50:00
Message: <web.4dab27faae520e29e161d0420@news.povray.org>
> > hello
> > Beny
> Built-in features:
> option?
> jim
the command-line : "povray-version" return
Built-in features:
  X Window display:          disabled
  Unsupported image formats: openexr
Compilation settings:
  Build architecture:  x86_64-unknown-linux-gnu
  Built/Optimized for: x86_64-unknown-linux-gnu (using -march=native)
  Compiler vendor:     gnu
  Compiler version:    g++ 4.4.3
  Compiler flags:      -pipe -Wno-multichar -Wno-write-strings
-fno-enforce-eh-specs -s -O3 -ffast-math -march=native -pthread
beny
Date: 17 Apr 2011 14:05:59
Message: <4dab2c07$1@news.povray.org>
On 04/17/2011 02:48 PM, beny wrote:
>>> hello
>>> Beny
>> Built-in features:
>> option?
>> jim
> Built-in features:
> beny
so that means that you do /NOT/ have libsdl package installed ...
there's a link in read me to get those files or maybe your linux app
repository has a package for download ... at any rate you'll need to get
that installed somehow and do a rebuild ... configure /should/ detect a
proper libsdl installation
good luck
jim
Date: 17 Apr 2011 15:36:51
Message: <4dab4153@news.povray.org>
Le 17/04/2011 20:05, Jim Holsenback nous fit lire :
>> Built-in features:
>> beny
Lucid is ubuntu LTS.
It does work on LTS.
As Jim quoted, you need to install libsdl (and that means the
libsdl*-dev version, at least to configure & compile)
If you want openexr as well, it's something like libopenexr-dev ;-)
