terminal output:
Making install in source
make[1]: Entering directory `/home/abaye/povray-3.7.0.beta.41/source'
Making install in backend
make[2]: Entering directory `/home/abaye/povray-3.7.0.beta.41/source/backend'
g++ -DHAVE_CONFIG_H -I. -I../.. -I../.. -I../../source -I../../source
-I../../source/base -I../../unix -I../../vfe -I../../vfe/unix -I/usr/include/SDL
-D_GNU_SOURCE=1 -D_REENTRANT -pthread -I/usr/include -I/usr/include -pipe
-Wno-multichar -Wno-write-strings -fno-enforce-eh-specs -s -O3 -ffast-math
-malign-double -march=native -pthread -MT fnpovfpu.o -MD -MP -MF
..deps/fnpovfpu.Tpo -c -o fnpovfpu.o `test -f 'vm/fnpovfpu.cpp' || echo
'./'`vm/fnpovfpu.cpp
In file included from ../../source/backend/control/renderbackend.h:101,
from ../../source/backend/control/messagefactory.h:100,
from ../../source/backend/frame.h:117,
from vm/fnpovfpu.cpp:296:
token
make[2]: *** [fnpovfpu.o] Error 1
make[2]: Leaving directory `/home/abaye/povray-3.7.0.beta.41/source/backend'
make[1]: *** [install-recursive] Error 1
make[1]: Leaving directory `/home/abaye/povray-3.7.0.beta.41/source'
make: *** [install-recursive] Error 1
abaye@localhost:povray-3.7.0.beta.41$
there seems to be an error in line 114 of povray.h, I found an unclosed
parentheses, but it still won't build.
Any help would be appreciated, I can't do anything until I get the new beta.
A.D.B.
"Anthony D. Baye" <Sha### [at] spamnomore hotmail com> wrote:
> terminal output:
> token
> A.D.B.
Well, I thought it was an unclosed parentheses...
I compared the current version with the two previous, and it seems that the
function definition for povray_init has changed from
void povray_init(POVMSAddress *addr = NULL);
to
boost::thread *povray_init(const boost::function0<void>& threadExit,
I have to admit I'm a little out of my depth here, I know hardly anything about
the boost libraries, and nothing at all about using threads.
At any rate, this would not appear to be a problem my skills can debug, so I
leave it to the experts.
Regards, and Happy New Year
A.D.B.
> to
It's a mac's story...
Have you installed libboost-thread-dev package ?
Attached is my boost matching packages.
I compiled beta 41 fine a few days ago.
(And it has expired now, as we are 2011-01-01).
Download 'capture.png' (50 KB)
Preview of image 'capture.png'
> > to
I'm running Ubuntu 10.04 on a Fujitsu Lifebook T5010 with an Intel Core2 Duo
processor. I will try updating to 10.10.
The latest boost repositories available to me (according to package manager) are
1.40 not 1.42
A.D.B.
> 1.40 not 1.42
FYI: I've been building against 1.42 for a bit now WAS using 1.39 before
that ... never used 1.40
> > 1.40 not 1.42
Boost seems to install libraries differently for different versions.
On Slackware-13.0 with boost 1.38 I use:
../configure \
--with-boost-thread=boost_thread-mt \
COMPILED_BY="Beta41 (expires 2020)"
and on Slackware-Current with boost-1.45
../configure \
--with-boost-thread=boost_thread \
Cheers,
Peter
> token
I had a similar error message. Seems an include line in source/backend/povray.h
is missing:
#include <boost/function.hpp>
Reinhard
This is still an issue in RC2. Adding the include seems to fix it.
> > token
> is missing:
> Reinhard
Not sure why it happens on some systems and not others (builds fine on our
test system), but in any case I've updated the source archive with the
appropriate change.
-- Chris
Confirmed here, too.
