Subject: Re: Problem with new focal blur noise pattern and animations
Date: 11 Nov 2010 14:39:40
Message: <4cdc467c$1@news.povray.org>
Am 11.11.2010 16:10, schrieb Tek:
> After some testing I'm getting the impression that the bokeh filter isn't
> strictly applied. I'm getting square shapes when using a bokeh which is mostly
> black, as if the algorithm gives up after a few tries and just uses the sample
> anyway. Indeed, using a completely black bokeh filter doesn't cause any error
> and I still have blur.
This is indeed the case; the design of the algorithm was subject to the
following constraints:
* allow the use of an arbitrary user-specified bokeh (as opposed to a
set of hard-coded bokehs)
* allow the use of POV-Ray's pattern mechanism (as opposed to requiring
an image file)
* produce the same output image brightness regardless of the bokeh
pattern's average brightness (for instance a circular black-and-white
"mask" would typically have an overall brightness of pi/4, while a
regular hexagonal one might have an overall brightness of 3*sqrt(3)/8)
* use importance sampling to get more quality out of a given number of
samples
All in all this calls for a monte-carlo approach at choosing sampling
points, with some variation to make it robust against pathological cases
- not only the (impossible-to-detect) case of an all-black bokeh
pattern, but also e.g. an almost-all-black pattern where the combined
choice of sample-candidate stream (in this case 2D Halton) and monte
carlo pseudo-RNG happens to never find a suitable sample.
The current solution to the robustness issue is to monitor how well the
algorithm is getting along at choosing samples, and adaptively brighten
up the pattern a bit.
> This is an understandable limitation of the bokeh filter implementation, but it
> limits my ability to use it to randomize blur samples.
Not really: Any pattern utilizing high-frequency random noise with an
overall brightness around 0.5 (in the regions that should be part of the
bokeh) should do the trick; for instance, randomly-chosen slices of a
scaled-down "bumps" pattern should do (modulated of course by the
pattern you really want to achieve).
I tried that first, the problem was that 50% of the samples would work. I want
to generate (at least) 10 unique variations of the sampling pattern, but if I
have a noise pattern that's 50% white and 50% black then there's a 50/50 chance
that any given sample will succeed first time (and a 25% chance it will succeed
2nd time, and so on until we hit the limit of the number of attempts it makes).
So over the frames I want to blur together 50% of the samples will be the
identical 1st attempt, which creates extremely visible noise no matter how
random the remaining 50% are.
Quite simply, I have no way to guarantee, or even to make it likely, that pixels
on the next frame will use a different blur sample to this frame.
All of which can be fixed by a random seed I can set myself.
Date: 12 Nov 2010 08:46:16
Message: <4cdd4528$1@news.povray.org>
If you use a deterministic pattern (whatever it be, with high contrast
area in <0,0><1,1>...) then from frame to frame, you can rotate and
translate it as your seed wants to govern it. you might for instance use
a checkered b&w, scaled to 1/10 (so that's potentially 50 spots out of
100), rotated on the plane by a random value (your choice of seed),
translated randomly...
I'm pretty sure that's what I just said.
e.g. I sample the bokeh filter for a pixel this frame and it hits a white bit,
so the sample goes through in that position. On the next frame I try to sample
the exact same position (because the halton sequence is the same), but I've
animated the bokeh pattern so there's a 50% chance it will hit white again. If
it does then the sample is in the same position, not animated.
So 50% of the noise from one frame to the next will be identical, not random. Am
I missing something?
So basically you want a pattern with ~50% average brightness that's guaranteed
to be black in spots that haven't been sampled in the last N frames?
That's... possible, but ugly. You'd need to look at the source to determine
the primes being used for the Halton sequence in question, then design your
pattern around that.
