POV-Ray : Newsgroups : povray.beta-test : skyspheres transmit of color maps not computed last Server Time
10 May 2025 08:40:30 EDT (-0400)
  skyspheres transmit of color maps not computed last (Message 1 to 10 of 17)
Subject: skyspheres transmit of color maps not computed last
Date: 26 Oct 2010 17:40:01
Message: <web.4cc749d261bca8a082b320a90@news.povray.org>
Hi There is something that I try to understand every once in a while with
povray:
I am trying to have a sky sphere with gradient but still with an alpha layer
fully transparent in the end image. How do you do that?
I try using two rgbt colors, both with a transmit value of 1 as entries to the
colormap.
If I do that,  only the last entry of color map of my gradient will be used as
if the the first entry had never existed. so it seems like the transparency is
baked into the color for each entry. could there be an option to make it so that
if the first entry has transmit 1 its color is still retained and all
transparencies
only applied in the alpha layer?
Subject: Re: skyspheres transmit of color maps not computed last
Date: 26 Oct 2010 17:48:28
Message: <4cc74cac$1@news.povray.org>
Le 26/10/2010 23:38, Mr nous fit lire :
> povray:
> colormap.
> transparencies
Could we have a minimal demo scene ? please.
Date: 26 Oct 2010 17:50:00
Message: <web.4cc74cf654c4afac82b320a90@news.povray.org>
> transparencies
Actually it's not the color of the last entry, it happened to be the color of my
background too. If I remove the background, I get a completely black skysphere!
So what is happening, Are spy sphere totally ignoring the separation between
colors and alpha?
Date: 27 Oct 2010 05:20:01
Message: <web.4cc7edc454c4afac82b320a90@news.povray.org>
> > povray:
> > colormap.
> > transparencies
Here it is:
#declare shader_Material = finish {
 brilliance 1.8
 phong 0.5
 phong_size 25.2
 diffuse 0.8 0
 ambient 1
 emission 0
 conserve_energy
#declare camLocation  = <7.481132, -6.507640, 5.343665>;
#declare camLookAt = <63.559295, 0.619768, 46.691945>;
 location  <0, 0, 0>
 look_at  <0, 0, -1>
 right <-1.77777777778, 0, 0>
 up <0, 1, 0>
 angle  49.134343
 rotate  <63.559295, 0.619768, 46.691945>
 translate <7.481132, -6.507640, 5.343665>
light_source {
 < 0,0,0 >
 color rgb<2, 2, 2>
 fade_distance 5.999997
 fade_power 2
 matrix <-0.290865, 0.955171, -0.055189,  -0.771101, -0.199883, 0.604525,
0.566393, 0.218391, 0.794672,  4.076245, 1.005454, 5.903862>
mesh2 {
 vertex_vectors {
  8,
  <1.000000, 1.000000, -1.000000>,
  <1.000000, -1.000000, -1.000000>,
  <-1.000000, -1.000000, -1.000000>,
  <-1.000000, 1.000000, -1.000000>,
  <1.000000, 0.999999, 1.000000>,
  <0.999999, -1.000001, 1.000000>,
  <-1.000000, -1.000000, 1.000000>,
  <-1.000000, 1.000000, 1.000000>
 normal_vectors {
  6,
  <1.000000, -0.000000, 0.000000>,
  <0.000000, -0.000000, 1.000000>,
  <0.000000, 0.000000, -1.000000>,
  <-0.000000, -1.000000, -0.000000>,
  <-1.000000, 0.000000, -0.000000>,
  <0.000000, 1.000000, 0.000000>
 texture_list {
  1
    pigment {rgbft<0.8, 0.8, 0.8, 0, 0>}finish {shader_Material}
 face_indices {
  12,
  <0,1,2>, 0,0,0,
  <0,2,3>, 0,0,0,
  <4,7,6>, 0,0,0,
  <4,6,5>, 0,0,0,
  <0,4,5>, 0,0,0,
  <0,5,1>, 0,0,0,
  <1,5,6>, 0,0,0,
  <1,6,2>, 0,0,0,
  <2,6,7>, 0,0,0,
  <2,7,3>, 0,0,0,
  <4,0,3>, 0,0,0,
  <4,3,7>, 0,0,0
 normal_indices {
  12,
  <2,2,2>,
  <2,2,2>,
  <1,1,1>,
  <1,1,1>,
  <0,0,0>,
  <0,0,0>,
  <3,3,3>,
  <3,3,3>,
  <4,4,4>,
  <4,4,4>,
  <5,5,5>,
  <5,5,5>
 interior { ior 1.000000
 caustics 0.1
 matrix <1.000000, 0.000000, 0.000000,  0.000000, 1.000000, 0.000000,  0.000000,
0.000000, 1.000000,  0.000000, 0.000000, 0.000000>
sky_sphere {
  gradient y
  color_map {
   [0.0 rgbt<0.33, 0, 0.528, 1>]
   [1.0 rgbt<0.481, 0.774, 0.645, 1>]
global_settings {
 max_trace_level 7
 ambient_light rgb<0, 0, 0>
Date: 27 Oct 2010 08:28:09
Message: <4cc81ad9$1@news.povray.org>
>> transparencies
> colors and alpha?
You are specifying a transmit of 1, which means that the ray must goes
straight through the sky_sphere, without interacting with the colour.
Hence it get to the background... whose default is black unless you
specify another.
I'm afraid we are entering the big discussion in image format: does a
transparent pixel have a colour (or: is the rgb part of an alpha-enabled
image format pre-multiplied or not in regard to alpha (and gamma, it's
far more fun with gamma in the equation)).
The problem is that different format have different answers.
(and they might be all valid, up to their tenants)
Maybe you want to replace rgbt with rgbf (it give a colored background
with some transparency with +UA (and using a format which support alpha,
such as png)) ?
Or keep rgbt, but reduces t to 0.5 ?
I do not get what you are trying to achieve with such transmitting
sky_sphere.
Real software engineers work from 9 to 5, because that is<br/>
the way the job is described in the formal spec.  Working<br/>
late would feel like using an undocumented external procedure.
Date: 27 Oct 2010 09:55:01
Message: <web.4cc82d7b54c4afac82b320a90@news.povray.org>
> >> transparencies
> > colors and alpha?
> specify another.
> such as png)) ?
> sky_sphere.
I'm working with PNG and I want my Blender exporter to give me the proper alpha
to allow compositing, and other things just like the internal renderer outputs:
it allows a gradient for color of the background sky (blend sky option) but the
alpha is  still cutting the whole sky as *fully* tranparent. So in Pov an alpha
of 0.5 will not solve the problem as I'll have only partial transparency.
And the first solution you suggest, won't work either, should I use Filter for
the background, I get no transparency at all. Maybe that's what is broken? So I
assume you meant transmit, and transmit 0 for BG as well as both sky sphere
color map entries gets me no transparency, transmit 1 for both color entries
of skysphere gives me only the flat color taken from background keyword, and
using transmit 1 for only one of the sky sphere colormap entries, namely the one
that is similar to the "background" to let background actually do it and sky
sphere only do the second color: then I get a gradient in the transparency
values.
Any other solution?
Date: 27 Oct 2010 10:20:04
Message: <4cc83514@news.povray.org>
With filter at 1 on the sky_sphere and NO background, with beta 39, I
got the attached pictures.
sky_sphere {
  gradient y
  color_map {
   [0.0 rgbf<0.33, 0, 0.528, 1>]
   [1.0 rgbf<0.481, 0.774, 0.645, 1>]
global_settings {
 max_trace_level 7
 //  background { rgbt <1,1,1,0.5>}
A good Manager will take you
through the forest, no mater what.
A Leader will take time to climb on a
Tree and say 'This is the wrong forest'.
Download 'skysphere.png' (9 KB)
Preview of image 'skysphere.png'
Date: 27 Oct 2010 10:50:01
Message: <web.4cc83b9154c4afac82b320a90@news.povray.org>
> sky_sphere {
>  pigment {
>   gradient y
>   color_map {
> global_settings {
>  max_trace_level 7
I had the same.
The closest workaround I found:
using transmit 0.99 for the background-like entry of the sky sphere I have the
behaviour I want for transparency with gradient. only problem remaining is when
user selects no sky spher I let background with transmit 1 do the job, but the
anti aliasing is white. if I put transmit 0.99 in bacground color, AA is
perfect, but then color is slightly off.
Date: 27 Oct 2010 13:55:01
Message: <web.4cc866cb54c4afac82b320a90@news.povray.org>
If someone wants to try with the exporter for latest blender 2.5, here it is:
https://projects.blender.org/tracker/index.php?func=detail&aid=22717&group_id=153&atid=468
Date: 30 Oct 2010 06:11:54
Message: <4ccbef6a$1@news.povray.org>
Am 26.10.2010 23:49, schrieb Mr:
>> transparencies
> colors and alpha?
If you're using OpenEXR, there is nothing that can be done about this,
except for violating the file format specifications. OpenEXR uses what
is called "premultiplied alpha", i.e. if you take the RGB components by
themselves, you get the same result as if you'd compose the transparent
image against a black background. So with 100% transparency you'll
always get pitch black, no matter what. (This /does/ have some benefits
of its own.)
With the PNG file format, the story is rather different: PNG is
specified to use "non-premultiplied alpha", i.e. if you take the RGB
components by themselves, you get the same result as if you had no
transparency in the first place. So theoretically, what you're asking
for should be possible.
However, for internal computations POV-Ray uses "premultiplied
alpha"-like format as well. With the most recent betas, it /does/
"un-premultiply" the values when writing PNG files - but when the
transparency is 100%, this approach breaks down: Regardless of the
original color, the premultiplied value will be <0,0,0>, so there's no
way to tell what the original color might have been. In the absence of
better information, POV-Ray will resort to guessing that the color may
have been pitch black.
 From this root cause it is pretty easy to derive a workaround: Just
never use 100% transparency. If you use e.g. 99.9% and PNG output, you
should be fine.
That is, provided you use the newest beta. Earlier versions of POV-Ray
weren't even aware of the premultiplied vs. non-premultiplied alpha
issue, and erroneously wrote premultiplied alpha data for all file
formats, even where contrary to specification. (Worse yet, they presumed
all input files to use /non/-premultiplied alpha, i.e. POV-Ray wasn't
even self-consistent about it.)
