POV-Ray : Newsgroups : povray.beta-test : Struggling with gamma... Server Time
3 Mar 2026 19:27:31 EST (-0500)
  Struggling with gamma... (Message 1 to 10 of 33)
Subject: Struggling with gamma...
Date: 26 Jun 2010 04:15:00
Message: <web.4c25b685f7030258e3006550@news.povray.org>
Hello there !
I tried, I tried, I really tried to understand how gamma works...
How could I switch it off ?... So this scene would give a perfectly mid-gray
image :
  location -z
  look_at 0
box {
  -0.5
  0.5
  pigment { rgb 0.5 }
  finish { ambient 1 }
I don't understand why this isn't the case when NO gamma settings is set
(evertything to default).
I tried File_Gamma=1 Display_Gamma=1, and it seemed to work fine in gimp and in
the window image viewer, but then I try to see the image in firefox and it is
way to bright - so firefox can't handle gamma data ?
Subject: Re: Struggling with gamma...
Date: 26 Jun 2010 05:05:01
Message: <web.4c25c26265b49d46e3006550@news.povray.org>
I just saw the gamma tutorial on the wiki, so I'll be reading it... Hopefully
I'll finally get to what I want ! :)
Date: 26 Jun 2010 06:00:00
Message: <web.4c25cf9065b49d46e3006550@news.povray.org>
If I understood correctly, the 'over-bright impression' is actually the correct
way images should be, right ?
But then, the default ambient light is waaaay to high, isn't it ?
Date: 26 Jun 2010 06:22:05
Message: <4c25d4cd$1@news.povray.org>
Am 26.06.2010 10:12, schrieb Gyscos:
> Hello there !
> image :
> camera {
>    location -z
>    look_at 0
> box {
>    -0.5
>    0.5
>    pigment { rgb 0.5 }
This scene actually /does/ give a perfectly mid-gray image... as long as
we're talking about physical light intensity, rather than perceptual
brightness ;-)
To really get the scene to look the way you want it to, use:
    pigment { rgb pow(0.5, 2.2) }
Future betas will also provide an extended color syntax for this purpose:
    pigment { rgb 0.5 gamma 2.2 }
Let me guess - you used PNG file output? In that case it is a sign that
/Firefox/ is getting it right, while gimp and the image viewer are not.
The File_Gamma setting does not affect PNG output very much (provided
that your image processing software is handling gamma right), except for
banding artifacts.
Date: 26 Jun 2010 06:25:51
Message: <4c25d5af@news.povray.org>
high. That means the box does not need a light source to be fully
illuminated. If you are using radiosity set the ambient to zero. If not
try an ambient between 0.1 and 0.2.
There have been a few discussions on this newsgroup about the changes in
the way Pov 3.7 beta handles gamma so you could search here. Also the
Wiki has a topic.
http://wiki.povray.org/content/HowTo:Fix_old_scenes_to_work_with_the_new_gamma_system
Best Regards,
Date: 26 Jun 2010 06:33:53
Message: <4c25d791$1@news.povray.org>
Am 26.06.2010 11:59, schrieb Gyscos:
Um... yes and no.
Yes: That's the right math.
No: If your scene looks overly bright, your parameters are wrong.
If you're talking about the default global { ambient_light 1.0 }: No,
that has nothing to do with gamma.
If you're talking about the default finish { ambient 0.1 }, and/or the
ambient values in all those standard material .inc files coming with
POV-Ray, then no, no and maybe.
No: Ambient light is pretty dependent on the actual scene, and actually
the only way to /really/ do it right is using radiosity instead.
No: The effect of ambient light also depends on the object's pigment,
which is waaaay too high in the default colors as well, as they were
designed at times when gamma wasn't done right.
Maybe: The ambient light defaults, too, were chosen at a time when gamma
wasn't done right, so they should be subject to re-evaluation.
Date: 26 Jun 2010 06:41:09
Message: <4c25d945$1@news.povray.org>
Am 26.06.2010 11:03, schrieb Gyscos:
Not sure which one you're talking about right now, but I'd like to take
the opportunity to advertise my gamma tutorial WIP once again:
<http://wiki.povray.org/content/User:Clipka/Gamma>
(Feedback appreciated, as usual.)
Date: 26 Jun 2010 07:25:01
Message: <web.4c25e2a065b49d46e3006550@news.povray.org>
Yup, that's the one I was reading. :)
About the ambient light, I meant that in a simple scene, with just a plane and a
box for instance, the ambient light was indeed designed to work with the old
settings ; and now, with the new gamma stuff, it might need some re-adjusting.
I don't want to adapt old scenes, I'm just trying to make new ones with what I
knew from before.
But I'm trying to make some nice scattering, and it is really harder now... I
used to use type 2, but now I can't get enough contrast between the high-angle
and the low-angle zone... So I use type 3, wich gives more or less the same
result as type 2 before, but... It doesn't seem right to change type for that.
Message: <web.4c25e37465b49d46e3006550@news.povray.org>
> banding artifacts.
But the POV-Ray preview was identical to what I get in Gimp or window viewer...
Is that normal ?
Display_gamma and File_Gamma being identical doesn't mean the preview and the
output image - when correctly decoded - are the same ?
Date: 26 Jun 2010 10:10:10
Message: <4c260a42$1@news.povray.org>
Am 26.06.2010 13:24, schrieb Gyscos:
>> banding artifacts.
> Is that normal ?
If you set Display_Gamma=1.0, then yes - you'll typically get a wrong
preview...
That depends.
Display_Gamma always specifies the gamma pre-correction to apply in
order to show a correct preview.
File_Gamma strictly speaking doesn't specify gamma pre-correction, but
gamma encoding (or, even more strictly speaking, the inverse of the
encoding gamma). For some older file formats, like BMP or JPEG, where
gamma encoding double-features as gamma pre-correction, this happens to
be the same; PNG, on the other hand, includes information about the
encoding gamma used in the file header, so that it can be left all up to
the viewing software to perform both gamma decoding and gamma
pre-correction for display. And for HDR and OpenEXR file formats,
File_Gamma has no effect whatsoever because those file formats always
use linear encoding.
