POV-Ray : Newsgroups : povray.beta-test : Output Alpha problem when exporting from blender Server Time
26 Apr 2026 01:31:04 EDT (-0400)
  Output Alpha problem when exporting from blender (Message 21 to 30 of 30)
Subject: Re: Output Alpha problem when exporting from blender
Date: 7 May 2010 17:13:51
Message: <4be4828f$1@news.povray.org>
Am 23.03.2010 17:13, schrieb Thorsten Froehlich:
>> IIRC, POV-Ray 3.5 mishandled alpha transparency against the background
>> in that with antialiased edges and semi-transparent surfaces it blended
>> the surface's color with the background color and then saved the
>> resulting
>> color with an alpha value. This caused object borders to have a
>> pixel-wide
>> halo of the wrong shade, and especially semi-transparent surfaces
>> would have
>> the wrong color.
>> This was fixed in POV-Ray 3.6, where it's calculated correctly (iow. the
>> background color has no effect on the pixel colors when using +UA).
>> Last time I checked (it has been some time, though), the same problem had
>> resurfaced in POV-Ray 3.7 beta. Someone had undone the fix in POV-Ray
>> 3.6.
>> Has this been corrected already?
> The fix was that alpha is treated differently depending on the version
> directive as the 3.6 change was unpopular...
I just noticed the following:
(a) With +UA, POV-Ray 3.6 /completely/ suppresses the background except
in reflections and radiosity-based diffuse illumination.
(b) POV-Ray 3.7 /without/ a #version directive (or with #version >=3.7)
/always/ takes the background into account, and uses the background's
transmittance as the basis for alpha channel computation.
(c) POV-Ray 3.7 /with/ a legacy #version directive (e.g. #version 3.6)
/always/ takes the background into account as well, except that it
forces the transmittance to 1.0.
The latter variant is totally rubbish, as it cannot be used for anything
useful at all, and doesn't actually make the thing backward compatible.
As a side note, I think (a) is the most useful, as it allows for the
background to be used for specifying a color to be seen in reflections
of the background, while not showing up in the image itself - something
that cannot easily be accomplished otherwise - so completely
"retreating" from that behavior seems a bad idea to me. Instead, I
suggest to make this behavior configurable to the user independently of
the #version directive, using some additional syntax; and as we're on
it, we can extend the same syntax to be used with a sky sphere as well,
so the user can choose whether to have the sky show up only in
reflections (leaving the background completely transparent), or in the
background as well (e.g. for generating fully or partially opaque
clouds). Or use this additional syntax only for the sky_sphere, and make
the background always invisible in the image itself when +UA is
specified. (If a user wants to mix some constant background into the
alpha channel, they can always resort to using a sky sphere with a plain
constant-color pigment.)
I'm thinking about something along the lines of
background {
   COLOR // only used in reflections or without +UA
sky_sphere {
   alpha_substitute { // must be first
     // pigments only used in reflections or without +UA:
     PIGMENT_1
     PIGMENT_2
   // pigments to use always:
   PIGMENT_3
   PIGMENT_4
or:
// to be rendered always:
background { COLOR }
sky_sphere { PIGMENT_LIST }
// to be rendered /additionally/
// "behind" the regular background & sky_sphere
// only in reflections or when +UA is not used:
alpha_substitute {
Note that if the alpha_substitute contains any transmittance in itself,
this might be used as an indicator that the user wishes alpha
transparency even in reflections.
Date: 8 May 2010 01:43:43
Message: <4be4fa0e@news.povray.org>
  Yes. As I already commented in this thread, All versions of POV-Ray which
have supported outputting an alpha-channeled image up to 3.5 (IIRC) had a
simplistic background transparency algorithm which calculated pixel colors
otherwise normally, but added an alpha value proportional to how much
the background was visible in that pixel.
  The problem with this was, of course, that the background color would
affect the color of semi-transparent pixels eg. at antialiased object
edges (where the visible edge of the object is against the background).
This meant that if you eg. had a black bacground, there would be a darkening
of the antialiased edge pixels. When such an image was then viewed eg. with
a web browser against some background color, eg. a white background, the
object would have a visibly darkish border around it. This made the entire
background-transparency feature significantly less useful.
  An even major problem happened with semi-transparent objects, or fully
transparent objects with eg. media inside them: The background color would
affect the color of the entire object, rendering eg. pure media effects
with a transparent background completely unusable (as the shape of the
container object would be visible).
  All in all, this rendered the feature rather useless, or at least a lot
less useful than it could have been. And this is why it was fixed in 3.6
(IIRC; could have been in 3.5, but I don't remember exactly now).
  3.6 did the background transparency properly, making the feature very
useful: Now you could render antialiased objects against a transparent
background, and the resulting image would work perfectly when put eg. on
a web page: The edges would blend nicely against the webpage's background,
without any extraneous coloring. Moreover, media effects against transparent
backgrounds worked like a charm: You could eg. render a flame against a
transparent background, and then use the resulting image on a web page and
it would look superb.
  In fact, when this was first fixed, many many years ago, I actually rendered
an image just as a proof of concept that it indeed worked like a charm:
http://warp.povusers.org/alphatest.html
  As you can see, the fire media blends with the background superbly.
  My guess is that when the result image handling routines were redesigned
in POV-Ray 3.7, this fix was accidentally dropped. This was a mistake which
should be corrected.
> Instead, I
  I don't know why anyone would want to use anything else than what 3.6 did,
but even if more options are made available, the 3.6 way should definitely
be the default, as it's the most useful and it's what people expect.
Date: 8 May 2010 03:33:55
Message: <4be513e3$1@news.povray.org>
Am 08.05.2010 07:43, schrieb Warp:
One could argue that e.g. sky spheres should show up in the background,
to allow for rendering opaque clouds against an otherwise transparent
background.
I've also found that 3.6 is /not/ doing it right either (at least with
regard to PNG), as it premultiplies alpha. Maybe 3.5 had that right, and
people complained about /that/ change?
Date: 8 May 2010 04:16:30
Message: <4be51ddd@news.povray.org>
> background.
  You mean that, with respect to alpha transparency, the sky_sphere would
work the same as if it was an actual sphere primitive with that texture
(naturally without lighting affecting it)?
  I agree that it sounds sensible and could be useful.
  (Nitpicking, but I disagree on the clouds example, though. sky_sphere is
the wrong but unfortunately too much used place to put clouds. Clouds do not
work that way in real life. Clouds work much better on a *plane* which is
parallel to the ground. :) )
  I don't really understand the difference. It has never come up as any kind
of problem when I have used POV-Ray 3.6 to render some alpha-channeled images.
  (Is the perceived problem that pre-multiplying means that some color
accuracy can be lost in the process?)
Date: 8 May 2010 05:12:21
Message: <4be52af5$1@news.povray.org>
Am 08.05.2010 10:16, schrieb Warp:
No, the main problem is that colors simply aren't right.
Compositing images with an alpha channel always works according to the
formula:
   ResultColor = (R;G;B) * A + Background * (A-1)
The PNG file format specification demands that the file stores the raw
values ("non-premultiplied alpha"), i.e.:
   (R;G;B;A)
However, POV-Ray - at least at present - internally uses premultiplied
alpha, i.e. it works with color tuples of the form:
   (R*A; G*A; B*A; 1-A)
For output to PNG files, POV-Ray 3.6 only converts the transparency
(1-A) to alpha (A), i.e. it writes tuples of the following form to the file:
   (R*A; G*A; B*A; A)
   = (R;G;B;1) * A
Obviously, if you use these values in the above formula, you get:
   ResultColor = (R;G;B) * A^2 + Background * (A-1)
which of course gives a different result color (except for A=0.0 and
A=1.0). One symptom is that gradients from opacity to transparency,
while appearing smooth in the preview, will exhibit pretty hard edges in
the image file.
Date: 8 May 2010 06:38:26
Message: <4be53f21@news.povray.org>
> the image file.
  I don't see that happening. Just to test this, I rendered this scene
with POV-Ray 3.6, without +ua and then with +ua:
background { rgb 1 }
camera { right x location -z look_at 0 angle 90 }
plane
{ -z, 0
  pigment
  { gradient y color_map
    { [0 rgb 0]
      [.5 rgb y transmit .5]
      [1 rgb y transmit 1]
    scale 2 translate -y
  finish { ambient 1 }
  I put the two images side-by-side here:
http://warp.povusers.org/images/gradient_test.html
  The image on the left uses no alpha channel, and it's just a gradient
from black to white, going through green. The image on the right uses
alpha channel and goes from opaque black to transparent green.
  There is no visible difference. You can't even tell where the border
between the two images is.
  To corroborate that the image on the right indeed has alpha-transparency,
contrast with this (the only difference being the background color of the
page):
http://warp.povusers.org/images/gradient_test2.html
Date: 8 May 2010 08:04:07
Message: <4be55337@news.povray.org>
Am 08.05.2010 12:38, schrieb Warp:
(1) Yes, we can - see attched screenshot from IE8. It is not easy to
distinguish, but it is there (measure in photoshop if you can't see it).
With a gradient from fully-opaque green to fully-transparency green the
effect would be more pronounced and thus a bit better visible.
(2) Try again with assumed_gamma=1.0, which does give you the proper
mixing of colors in POV-Ray, and you /will/ see.
What happened in your test images is that the gamma issues almost (but
not quite) canceled out the effect of the premultiplied alpha.
Download 'alpha_comparison.png' (63 KB)
Preview of image 'alpha_comparison.png'
Date: 8 May 2010 10:05:30
Message: <4be56fa9@news.povray.org>
  There's a really faint dividing vertical line barely visible between the
two images in your screenshot. I can swear it's not visible when I look at
the page with Firefox, and it's impossible to say where the edge between
the two images is. Maybe Firefox handles pngs slightly differently than IE?
  But I suppose that if what you suggest will make the difference disappear
even in IE, it's worth it.
Date: 8 May 2010 10:25:14
Message: <4be5744a$1@news.povray.org>
Am 08.05.2010 16:05, schrieb Warp:
As I mentioned, with assumed_gamma=1.0 we're no longer talking about
mere faint lines.
Date: 8 May 2010 16:04:51
Message: <4be5c3e3$1@news.povray.org>
That's the way it must work. You have a non-uniform background whose
colour is not known before you render, and the location and scaling of
your image is also not known beforehand and can be altered by the user.
>> Instead, I
In my view, your "should" have to replaced by "must".
If you want to be able to have the background dolour to show thru
transparency, it must be user selectable, defaulting to off.
The only background that peoples may actualy usualy want to show in
transparency, is the rainbow.
