POV-Ray : Newsgroups : povray.beta-test : Bug in beta 35 Server Time
28 Mar 2026 03:28:41 EDT (-0400)
  Bug in beta 35 (Message 1 to 7 of 7)
Subject: Bug in beta 35
Date: 4 Jan 2010 13:05:00
Message: <web.4b422cc11d896a39900266f50@news.povray.org>
Hello everyone.
I tried the beta 35, since I got an error message about expiration of version
34, since january 1st.
Unfortunately, I discovered a quite serius bug in beta 35.
Any cone will have both ends with the sign of every coordinate changed!
This doesn't happen with version 34.
For example, try:
cylinder{0,10*x,0.02 pigment{color x}}
cylinder{0,10*y,0.02 pigment{color y}}
cylinder{0,10*z,0.02 pigment{color z}}
camera
   location 3
   right x*16/9
   direction x*2
   sky z
   up y
   look_at 0
cone{<0,0,0>,0,<1,0,0>,0.3 pigment{color rgb 1}}
light_source{10 color rgb 1}
I hope this will be fixed as soon as possible.
In the meanwhile, I will try to uninstall beta 35 and install back version 34.
Thank you.
Best regards.
                   Rosso5
Subject: Re: Bug in beta 35
Date: 4 Jan 2010 14:02:13
Message: <4b423b35$1@news.povray.org>
Le 04/01/2010 19:02, Rosso5 nous fit lire :
> Hello everyone.
It's all my fault. Sincerely. Sorry.
I forget to add a
VScaleEq(axis, -1.0);
inside
  if (apex_radius < base_radius)
    /* Want the bigger end at the top */
    Assign_Vector(tmpv,base);
    Assign_Vector(base,apex);
    Assign_Vector(apex,tmpv);
    tmpf = base_radius;
    base_radius = apex_radius;
    apex_radius = tmpf;
    VScaleEq(axis, -1.0);  // Missing: opposite axis
in cones.cpp::Cone::Compute_Cone_Data() (circa line 866)
Previously, axis was computed after that inversion.
It is now computed before, because I needed the length of the cone a bit
before.
> Thank you.
> Best regards.
>                    Rosso5
Date: 4 Jan 2010 15:00:00
Message: <web.4b42481230f6e19bbe55c2ae0@news.povray.org>
Thank you for your ready answer.
So, if I have well understood, it will be fixed in the new release, right?
Do you know when? Sorry, I don't know if there is any established rule about
date publication for every release.
Thank you so much.
                     Rosso5
Date: 4 Jan 2010 18:46:00
Message: <4b427db8$1@news.povray.org>
I'll do a new release to fix this issue in the next day or two.
-- Chris
Date: 5 Jan 2010 15:30:01
Message: <web.4b43a13130f6e19b1e7f75a70@news.povray.org>
Thank you very much, Chris.
I asked also because the version 34 doesn't allow anymore to make any render.
I get the message "Please obtain an update version of this application" even if
I have just done the "Extend" after the application launch.
The only way is to modify the date/time in computer clock. Or otherwise, to use
version 3.6.2, but it is quite slower than 3.7 one.
I have to generate a lot of frames with the Death Star...
Best regards.
                     Rosso5
Date: 7 Jan 2010 11:58:37
Message: <20100107135836.a34faa86.john@johncoppens.com>
On Tue,  5 Jan 2010 15:29:37 EST
> render.
See the source download page for a small mod to be made to just one file.
This re-enables beta34.
John
Date: 7 Jan 2010 12:40:00
Message: <web.4b461c4730f6e19b106318a0@news.povray.org>
> > render.
> John
Thank you John, but I think you are referring to the note in Unix/Linux section:
Note: to get the Linux beta 34 source to work after 31 December 2009...
In my case, I'm using PoV on Windows, ver. 3.7 beta 34 & 35.
Maybe I should have specified this first, sorry.
Best regards.
                  Rosso5
