POV-Ray : Newsgroups : povray.beta-test : default light source in 3.7? Server Time
17 Nov 2025 10:14:45 EST (-0500)
  default light source in 3.7? (Message 1 to 9 of 9)
Subject: default light source in 3.7?
Date: 17 Nov 2009 11:00:01
Message: <web.4b02c77e4c442a2e27a6896b0@news.povray.org>
There seems to be a default light source in 3.7 Beta 34.
When I turn all light sources off and set global_settings{ambient_light 0} in
3.6 I get a black image, but 3.7 gives a dusk ambient lighted image. All my
scenes tend to be allot brighter in 3.7 than in 3.6.
I googled and bingd on how to turn this off without success, or is it something
else?
Cheers,
Louis
Subject: Re: default light source in 3.7?
Date: 17 Nov 2009 13:51:35
Message: <4b02f0b7@news.povray.org>
"Louis" <nomail@nomail> wrote in message
news:web.4b02c77e4c442a2e27a6896b0@news.povray.org...
> in
> my
> something
> else?
sounds like gamma handling issue ... check out the threads in this newsgroup
that discuss gamma and see if that sheds any light (no pun intended) on your
issue.
Jim
Date: 18 Nov 2009 08:25:01
Message: <web.4b03f48bbf483f5827a6896b0@news.povray.org>
> issue.
> Jim
"#version 3.6" did the trick, thanks!
Date: 18 Nov 2009 19:33:48
Message: <4b04926c@news.povray.org>
>> issue.
>> Jim
You may also use #default{finish{ambient 0}} anywhere in your scene
file. 3.7 gives me no problems this way.
Happy Povving,
Sam
Date: 20 Nov 2009 02:00:10
Message: <web.4b063e28bf483f58b46bd10b0@news.povray.org>
> Happy Povving,
> Sam
This woudln't do the same actually.
To have the same result as 3.6, you have to change the gamme in the ini settings
Display_Gamma=1.0 File_Gamma=1.0
This is because the default gamma changed from 1.0 in povray 3.6 to 2.2 in
povray 3.7 ; so if you just change back the gamma, everything will be back to
normal. And this isn't the same as turning off default ambient, because even
with gamma 1.0, unlit objects will look dark but not black.
Date: 20 Nov 2009 10:06:48
Message: <4b06b088@news.povray.org>
>> Happy Povving,
>> Sam
> settings
> to normal. And this isn't the same as turning off default ambient, because
> even with gamma 1.0, unlit objects will look dark but not black.
Total black should be unaffected by any gamma correction...
Date: 24 Nov 2009 05:55:01
Message: <web.4b0bbaaebf483f58b46bd10b0@news.povray.org>
Indeed, that's why gamma and ambient-light can't do the same thing.
Date: 24 Nov 2009 07:59:34
Message: <4b0bd8b6$1@news.povray.org>
The OP apparently has(had?) two problems:
1) Even with no light sources and ambient light turned off the scene was not
black.  AIUI this would be a bug as the output should be totally black no
matter what the gamma setting is.
2) All scenes look lighter in 3.7 compared to 3.6.  This is because 3.7 has
gamma correction applied by default.  You should fix your scene to make it
look how you want (because you need gamma correction to make the lighting
look physically correct on your monitor), or if you're lazy just turn off
gamma correction to get the same output as 3.6 gave by default.
Date: 24 Nov 2009 11:03:50
Message: <4b0c03e6@news.povray.org>
  That actually depends on the contents of the scene. For example emitting
media doesn't care about light sources (or lack thereof) or ambient settings.
