POV-Ray : Newsgroups : povray.beta-test : About no_radiosity and radiosity off Server Time
26 Apr 2026 07:37:02 EDT (-0400)
  About no_radiosity and radiosity off (Message 5 to 14 of 34)
<<< Previous 4 Messages Goto Latest 10 Messages Next 10 Messages >>>
Subject: Re: About no_radiosity and radiosity off
Date: 15 Sep 2009 06:25:01
Message: <web.4aaf6b75c26aab573b29dc8d0@news.povray.org>
> Carlo C. schrieb:
> > clipka <ano### [at] anonymousorg> wrote:
> >> Unless I perfectly goofed it up, "radiosity off" prevents an object from
> >> *receiving* diffuse interreflection (aka radiosity), while
> >> "no_radiosity" prevents an object from *emitting* diffuse interreflection.
> (I just checked whether it indeed does what I thought it does after
> having seen the code - it does do right that :-))
Ach komm, das gibt's doch nicht! :-)
> The syntax for "no_radiosity" was chosen to (a) match the megapov
> syntax, and (b) fit into the family of no_shadow, no_reflection and
> no_image keywords, which all basically say, "for the sake of
> [shadow/reflection/image/radiosity] rays, this object does not exist",
> to be consistent there (which was also probably the motivation for the
> megapov syntax).
> The "radiosity off" syntax already existed at that time, so it was just
> left unchanged. It's a bit "dangling" I think.
I fully understand the reasons.
Date: 15 Sep 2009 16:49:39
Message: <4aaffde3@news.povray.org>
  It feels quite confusing. How about reusing existing keywords for a
clearer syntax:
radiosity { emission on/off }
radiosity { collect on/off }
Date: 15 Sep 2009 17:04:35
Message: <4ab00163$1@news.povray.org>
> clearer syntax:
How about sticking to the established megapov syntax, hm?
Date: 15 Sep 2009 17:11:12
Message: <4ab002f0@news.povray.org>
clipka wrote:
>> clearer syntax:
Compatibility to MegaPOV should be of *no* concern when porting a patch or
feature over to official POV-Ray. Consistency and avoiding new keywords when
reasonable should be the primary conditions for syntax decisions.
	Thorsten, POV-Team
Date: 15 Sep 2009 17:41:13
Message: <4ab009f9$1@news.povray.org>
> or feature over to official POV-Ray. Consistency and avoiding new
> keywords when reasonable should be the primary conditions for syntax
> decisions.
>     Thorsten, POV-Team
Though I generally consider this a reasonable position, in this
particular case there was a reason for the MegaPOV patch to use this
particular syntax and not a different one, touching one of the very
points mentioned: Consistency, in this case with the other
"no_something" keywords.
So using any other syntax as that used in MegaPOV would have meant...:
- breaking consistency among the "no_something" family of keywords
- having to invent a new syntax from scratch
- with not much of a precendence case to orient on
- and with the syntax "radiosity off" already being in use for another
very different feature.
Plus, as already mentioned, sacrificing the opportunity to use a syntax
already familiar to the users of a very famous POV-Ray patch - which of
course would not be sufficient alone, but I think it quite well rounds
off the whole thing.
Date: 15 Sep 2009 18:34:00
Message: <4ab01658@news.povray.org>
  Just because "no_something" is used for some features doesn't mean the
syntax is sound for all possible such features.
  Take, for instance, photon mapping. There's no "no_photons" keyword.
There is "photons { pass_through }" and "photons { collect off }", and
for good reasons.
  I see radiosity being more akin to photon mapping than to things like
no_image and no_reflection.
  Photon mapping already "breaks consistency". Except that it doesn't.
Artificially forcing a feature to the same mold as some other feature
is not always a good idea. With photon mapping the different syntax is
justified, and IMO so it is with radiosity.
  I fail to see how that is a bad thing. If the new syntax is *better*
and easier to understand, it's definitely a *good* thing, not a bad one.
  Wrong. See photon mapping.
  Just because an unofficial patch has made poor choices in syntax doesn't
mean those same poor choices must be replicated in the official version.
Date: 15 Sep 2009 19:17:47
Message: <4ab0209b$1@news.povray.org>
Um... no.
Radiosity is actually just cached diffuse reflections, nothing else.
It's the forward-raytracing component that places photon mapping
seriously off the grid.
There is no such thing as a "collect on|off" or "emission on|off" in the
specular (inter-)reflection block, so why should there be such a thing
for diffuse interreflection?
It isn't a poor choice from my seat, for the reasons already explained,
and in that light I do think that the syntax of a well-established
unfficial patch should be favored over an otherwise equally good but
newly invented syntax.
Date: 16 Sep 2009 03:55:01
Message: <web.4ab098aac26aab57cd37c620@news.povray.org>
> Um... no.
this is my irrelevant view...
But photons and radiosity in "global_settings" are already very similar!
Making radiosity syntax more similar to photons (outside "global_settings")
would not be all bad...
I find that the idea of Warp is slightly better that syntax "no_..." for
radiosity.
Date: 16 Sep 2009 12:04:41
Message: <4ab10c98@news.povray.org>
> Um... no.
  It doesn't matter how radiosity is implemented internally. From the syntax
point of view the important thing is how the user perceives it.
  Because radiosity settings are a whole lot more complicated than some
specular settings and thus deserve their own block, just like photons.
  It is a very poor choice. Do you know why? Because it's rigid and hard
to expand.
  If in the future support for new per-object radiosity settings is added,
what are you going to do? Add new keywords to be used in the main object
definition?
  The advantage of using a per-object "radiosity {}" block now is that in
the future it will be much easier to add new features to it.
  "Well-established" means absolutely nothing if it's a poor choice. It makes
no sense to deliberately drag bad choices.
Date: 16 Sep 2009 13:27:45
Message: <4ab12011$1@news.povray.org>
No, actually for any particular surface or object, the radiosity
settings are even simpler than the diffuse settings (because they take
part of the information from there).
In contrast to the photons algorithm, which /needs/ per-object settings
to be anywhere close to performant, there's virtually only one single
reason for the per-object or per-material settings currently implemented
- and that's the same as for the no_reflection, no_shadow or no_image:
Pure artistic choice.
> to expand.
There is some point to that - but that choice has been made much, much
earlier, when "no_shadow", "no_image" and "no_reflection" were
introduced. Fix those to be more flecible, and I'll happily agree that
the no_radiosity feature should fall in with them in that more flexible
syntax.
> definition?
There's another difference you're missing here:
no_radiosity does not affect the radiosity illumination calculation for
/this/ object - it affects the calculations for /other/ objects. (Just
like no_shadow affects whether a shadow is seen on /other/ objects, and
no_reflection, too, affects the effective color seen on some /other/
object).
If ever the radiosity code would be parameterized on a per-object basis
(and why should it? shouldn't that be part of the material properties?),
still the "no_radiosity" object flag wouldn't properly fit in.
Maybe a "visibility {}" block would be a proper container for those flags.
It does.
If you were to program an extension module to a spacecraft control
software natively working with feet and miles, it would be a bad idea to
try rewrite the whole smash to use metric units. And it would be
probably just as bad to insist on writing your module to use metric
units and convert back and forth.
