POV-Ray : Newsgroups : povray.beta-test : Same scene renders different in v3.7beta34 versus v3.62 Server Time
4 Jul 2025 06:40:14 EDT (-0400)
  Same scene renders different in v3.7beta34 versus v3.62 (Message 1 to 10 of 104)
Subject: Same scene renders different in v3.7beta34 versus v3.62
Date: 22 Aug 2009 10:25:00
Message: <web.4a8fff06e8953aaff8ed4b7f0@news.povray.org>
Hi all,
I rendered a very simple scene in both v3.62 and v3.7beta34:
camera{location <0,2,-2> look_at <0,0,0>}
light_source {<0,2,-2> color 1}
sphere{0,1 pigment{rgb<1,0,0>}}
If you render this scene in both versions, then it looks as if the sphere has
"flattened" in the new version.
Have certain default settings changed? Any ideas?
Thanks!
Cheers,
Frank
Subject: Re: Same scene renders different in v3.7beta34 versus v3.62
Date: 22 Aug 2009 11:22:38
Message: <t83095dtbd2i5gb7m2vq271nho4528kr4f@4ax.com>
Sorry but the only differences that I get in pigment which disappears when
adding  global_settings { assumed_gamma 1 } to the v3.62 scene.
Regards
Date: 22 Aug 2009 13:34:23
Message: <4a902c1f$1@news.povray.org>
Same here.
Frank, are you sure you used the same resolution with both renders?
Date: 22 Aug 2009 14:01:26
Message: <4a903276@news.povray.org>
  Btw, could someone explain, once again, why the default gamma settings
of povray 3.7 are different from the defaults in 3.6, making all scenes
without explicit gamma settings render differently? I never quite got the
reason for this.
Date: 22 Aug 2009 15:56:01
Message: <4a904d51$1@news.povray.org>
> reason for this.
Maybe because they actually /do/ render identically, provided you
specify "#version 3.6" to enforce backward compatibility?
Things only get complicated when you explicitly use a flexible-gamma
file format (such as .png or .hdr). Having these render identically as
well would probably require different "#version 3.6" defaults for the
parameters of 3.7's gamma-handling mechanism. Or a nasty hack of that
mechanism.
Date: 22 Aug 2009 16:37:11
Message: <4a9056f7@news.povray.org>
> > reason for this.
  That didn't really answer my question.
Date: 22 Aug 2009 18:23:27
Message: <4a906fdf$1@news.povray.org>
Of course it didn't - if the question is based on false observations and
therefore moot, what point would there be in answering it?
That is, unless you are asking why the behavior is different when a
#version statement is /not/ present. But in that case, there's no reason
to favor compatibility over correctness: 3.6 default gamma handling was
simply wrong (because it wasn't any gamma handling at all, thereby
producing linear output where other software commonly expects
gamma-precorrected files).
Date: 22 Aug 2009 19:45:00
Message: <web.4a9080701659a44ff8ed4b7f0@news.povray.org>
> Same here.
Hi!
I used indeed the same resolution settings for both renderings.
As Stephen indicated, the assumed_gamma keyword made both renders equal. However
I added an {assumed_gamma 2.2} in POV3.7 instead of an {assumed_gamma 1} in
POV3.62. This is because -on my PC- the latter setting had the effect of
"flattening" the sphere (or any other object).
Kind regards
Frank
Date: 22 Aug 2009 19:49:22
Message: <4a908402$1@news.povray.org>
Ah, I see! I thought you meant geometric "flattening", but you're
talking about colors.
Yes, gamma handling is significantly different between 3.6 and 3.7, and
does lead to differences in color "intensity".
Date: 22 Aug 2009 20:00:01
Message: <web.4a90851d1659a44ff8ed4b7f0@news.povray.org>
Just for the completeness, here's a comparison between the two spheres.
The sphere on the left was created with version 3.6 and the sphere on the right
was rendered in version 3.7. I didn't use the assumed_gamma keyword here.
http://img41.imageshack.us/img41/5444/testgjc.png
