POV-Ray : Newsgroups : povray.beta-test : Same scene renders different in v3.7beta34 versus v3.62 Server Time
24 Mar 2026 00:55:33 EDT (-0400)
  Same scene renders different in v3.7beta34 versus v3.62 (Message 81 to 90 of 104)
Subject: Re: Same scene renders different in v3.7beta34 versus v3.62
Date: 3 Sep 2009 10:54:16
Message: <4a9fd898$1@news.povray.org>
Warp schrieb:
>   I do understand that. However, my point is that there are situations
> where you are not rendering for your display, but for something else
> (for example to match HTML colors, or the colors of an existing image).
For such purposes, what you need to do is to simply convert the HTML
colors to linear values, and go with those. The output (PNG, or any
other file format with File_Gamma=2.2, which is the de-facto internet
standard) will then automatically match those HTML colors.
Is that so difficult?
> It seems that the ideology in POV-Ray 3.7 color handling
> is that the user must always pre-correct all color values by hand, as
> POV-Ray itself offers little help in this. Is this practical?
It is practical insofar as it would be difficult for POV-Ray to figure
out automatically whether a color value supplied by the user is
gamma-corrected already or not.
For instance, a user may have defined a light source and be quite happy
with it, but now decide to split it up into two light sources set a bit
apart and with slightly different hues.
So with linear color values, he can just write:
     light_source {
         MyLightPos - MyLightSpacing/2
         color (MyLightColour/2 + MyLightTweak)
     light_source {
         MyLightPos + MyLightSpacing/2
         color (MyLightColour/2 - MyLightTweak)
and get exactly the same overall scene brightness, with just a somewhat
more lively illumination.
Would you want to do that with gamma pre-corrected values?
I do agree that it is somewhat impractical to not be able to use colors
picked from, say, Photoshop directly in POV-Ray. But as far as that is
concerned,
- You can easily write a macro to "gamma-un-correct" colors.
- My suggestion would be to provide a dedicated syntax for specifying
gamma pre-corrected color values, such as:
     color rgb <0.6,0.3,0.6> gamma 2.2
(or, alternatively, a predefined macro in colors.inc or some such to
achieve that same effect).
>   It's absolutely unreasonable for POV-Ray to not to offer any way of
> automatically gamma-correcting input images which do not have gamma
> information in them.
That is true indeed, and if the day had 36 hours I would be the first to
implement a feature like this:
     http://bugs.povray.org/task/10
Date: 3 Sep 2009 11:03:27
Message: <4a9fdabf$1@news.povray.org>
Warp schrieb:
>   I just figured out the *perfect* example of a situation where you want
> raw, linear pixel values which are *not* gamma-corrected: When you are
> rendering an image which will be used as input to create a heightfield.
>   There 0.5 should mean exactly half height, not a height of 0.73.
>   clipca asked some time ago *why* one would ever want linear, uncorrected
> pixel values. There you have your perfect example.
Note that I deliberately put parentheses around that "linear,
uncorrected pixel values" (quoting from your posting) when I asked that.
PNG files as output by POV-Ray *are* linear uncorrected in effect (and,
if File_Gamma is chosen to be 1.0, also in encoding). It's just the
viewing software that, by /knowing/ them to be effectively linear and
therefore performing display gamma correction itself, gives you the
wrong impression that they were gamma pre-corrected already.
Date: 3 Sep 2009 11:16:12
Message: <4a9fddbc@news.povray.org>
  I suppose something like that could work. One question is, however,
whether the gamma assumption will be done when reading the image file
(ie. the pixel colors will be changed immediately when reading them
from the file), or only when they are needed to calculate a color (ie.
when evaluating the pigment).
  I actually don't know if POV-Ray internally stores images in memory as
bytes (like in the input image itself) or as floats. If it stores them
as bytes then pre-correcting the values will potentially lose some
information. On the other hand, post-correcting them (ie. correcting
them on the fly only when they are required for color calculations) might
make the evaluation of the pigment slightly slower.
  You might also end up having a conflict of interest: If the exact same
image map is used to both create a heightfield and as a pigment, you may
want non-corrected pixels in the first case and corrected pixels in the
latter. (Of course this could be solved just by loading the image twice.)
Date: 3 Sep 2009 11:25:21
Message: <op.uzos4jjk7bxctx@bigfrog.bredbandsbolaget.se>
Either way, Display_Gamma should always be set to match your display.
>   As it is now, there's no "official" way of making 3.7 to create a PNG
> file which is the same as what 3.6 creates. Even "#version 3.6" won't do
> that (because 3.7 will still write the gamma info to the PNG file, making
> it look different). The only way to achieve that is to "abuse"
> side-effects of other file formats not having support for gamma
> information.
I would argue that v3.6 did it wrong, and the only way to get that result
then was to "abuse" the system.
Keep in mind that images without embedded gamma information are generally
assumed by most applications to be pre-corrected for a gamma of 2.2.
>   I do understand the motivation of making the image always look the
> same regardless of what were the gamma settings of the system where the
> image was rendered and the gamma settings of the system where the image
> is displayed.
>   However, there are situations where you precisely *don't want* that.
> You want raw pixel values, and nothing else, as I exemplified above.
In which case the colours must be corrected on input. Rendering in a
non-linear colour space gives the wrong *colours*, not just the wrong
brightness.
>> What you seem to want is to use colour values that look a certain way
>> in a gamma-2.2 environment and have them look the same in the output
>> *and* have the same numerical value in the output as they did on input.
>> To the extent that I understand these things, the correct way is to
>> alter the colour values on input, because POV-Ray expects linear
>> colours on input.
>   It might be the "most correct" way, but it might not always be
> practical.
Currently, no.
>   The basic example is, as said, when trying to render a scene designed
> for POV-Ray 3.6: It's a bit unreasonable to expect you to go and change
> all the colors used in the scene just to match the new approach in 3.7.
Going on the premise that v3.6 did it wrong, I do not find it unreasonable
to have to "abuse" the system a little to match that behaviour.
In this case, if you want to render in non-linear colour space, you could
set File_Gamma to 1.0 and output to a gamma-unaware format (or
strip/replace the gAMA chunk from the PNG file). Optionally, temporarily
set Display_Gamma to 1.0 to make the preview match what the ultimate
output will look like.
>   Also, as demonstrated earlier, input images are currently not
> gamma-corrected properly, which makes them look too bright. While this
> problem will surely be fixed at some point, there are also other sources
> of color than just image files. For example one could use a graphical
> color picker to choose colors, and if they are written as-is into a
> POV-Ray 3.7 scene, they will not look the same as in the color picker
> application. It seems that the ideology in POV-Ray 3.7 color handling
No. It would certainly be convenient if POV-Ray provided some means of
having it done in the program itself.
>> This is handled automatically for input images in PNG-format if they
>> have a correctly set gAMA chunk, but other inputs must be corrected
>> "by hand".
Agreed.
FE
Date: 3 Sep 2009 11:29:36
Message: <op.uzotbmkx7bxctx@bigfrog.bredbandsbolaget.se>
Which is exactly what you should get if you use a gamma-aware image
format, regardless of what you set File_Gamma to.
FE
Date: 3 Sep 2009 11:54:17
Message: <4a9fe6a8@news.povray.org>
  No, because gamma correction will change the actual values of the
pixels before they are used/displayed. Thus, for example, a pixel which
in the image file has values <0.5, 0.5, 0.5> will be converted to
<0.73, 0.73, 0.73> before being displayed on screen, for a gamma correction
value of 2.2.
  However, when you are using an image to generate a heightfield, you are
not *displaying* the pixels. It's actually not an image supposed to be
shown on screen. It's just an image file being used to represent height
values. (One could say that an image file is being "abused" for a different
purpose than it was originally intended.) However. this is a very common
technique because image files are both very common with a lot of support,
and a practical way of storing height information.
  In this situation gamma correction makes no sense because the image file
does not actually contain an image.
Date: 3 Sep 2009 12:02:46
Message: <4a9fe8a6@news.povray.org>
> > information.
  Saying that v3.6 did it wrong is not very helpful for someone who is
trying to render a 3.6 scene using POV-Ray 3.7.
> > is displayed.
> brightness.
  What kind of color correction do I need when I'm rendering an image to
be later used to generate a heightfield?
  The answer is: None. When I specify a color of 0.5, I expect a value
which is exactly half of the pixel component value range to be written
to the image file so that when the image is later used to create a
heightfield, that pixel will produce a height which is exactly half of
the maximum height.
  Having to "pre-correct" the value 0.5 in order to counter the gamma
correction in order to get what I want is unfeasible and doesn't make
too much sense. It's much more reasonable to be able to turn all gamma
corrections off.
Date: 3 Sep 2009 12:09:48
Message: <op.uzou6n0b7bxctx@bigfrog.bredbandsbolaget.se>
> correction value of 2.2.
When used as input, the pixel with the (gamma-corrected) value <0.73,
0.73, 0.73> will be converted back to <0.5, 0.5, 0.5> *if you use a
gamma-aware image format*.
FE
Date: 3 Sep 2009 12:15:20
Message: <op.uzovfvuh7bxctx@bigfrog.bredbandsbolaget.se>
One could argue that using "#version 3.6" should completely mimic the
behaviour of v.3.6, but that does not mean v3.7 should behave the same by
default.
> the maximum height.
> corrections off.
The whole point of using a gamma-aware image format is that you do not
need to counter the gamma correction; it is handled correctly by default.
The problems arise only when using gamma-unaware formats.
FE
Date: 3 Sep 2009 12:21:27
Message: <4a9fed07$1@news.povray.org>
Because it would be impractical to distinguish between different /use/
of the image data (e.g. what about an image used to create a pigment,
which is then in turn to define a function?) from a logical point of
view values would have to be converted when reading the file. From an
algorithmic point of view, however, the encoding used in the file could
be preserved, and gamma computations performed whenever the pixel data
is actually evaluated (for whatever purpose).
For high-resolution texture images, on-the-fly evaluation would be the
ideal way to go (saves memory, and the number of queries per pixel are
smaller, maybe even <1 per pixel, in which case the computational
overhead would even be lower than with (A)), while for low-res an
on-load computation would obviously better.
A lossy transformation is definitely /not/ the way I'd want to go, so in
case of an on-load transformation, an 8-bit image would have to be
converted to 16-bit (which is about sufficient for gamma values around
2.0) or single-precision floating point on that occasion (half-precision
float would theoretically be an alternative, but I wouldn't want to go
for that due to lack of hardware support on most systems).
Various. I haven't found the time to look at it in detail, but the image
container provides support for 8-bit, 16-bit, and single-precision float
data.
