POV-Ray : Newsgroups : povray.beta-test : Same scene renders different in v3.7beta34 versus v3.62 Server Time
20 Mar 2026 06:53:06 EDT (-0400)
  Same scene renders different in v3.7beta34 versus v3.62 (Message 5 to 14 of 104)
<<< Previous 4 Messages Goto Latest 10 Messages Next 10 Messages >>>
Subject: Re: Same scene renders different in v3.7beta34 versus v3.62
Date: 22 Aug 2009 15:56:01
Message: <4a904d51$1@news.povray.org>
Warp schrieb:
>   Btw, could someone explain, once again, why the default gamma settings
> of povray 3.7 are different from the defaults in 3.6, making all scenes
> without explicit gamma settings render differently? I never quite got the
> reason for this.
Maybe because they actually /do/ render identically, provided you
specify "#version 3.6" to enforce backward compatibility?
Things only get complicated when you explicitly use a flexible-gamma
file format (such as .png or .hdr). Having these render identically as
well would probably require different "#version 3.6" defaults for the
parameters of 3.7's gamma-handling mechanism. Or a nasty hack of that
mechanism.
Date: 22 Aug 2009 16:37:11
Message: <4a9056f7@news.povray.org>
> > reason for this.
  That didn't really answer my question.
Date: 22 Aug 2009 18:23:27
Message: <4a906fdf$1@news.povray.org>
Of course it didn't - if the question is based on false observations and
therefore moot, what point would there be in answering it?
That is, unless you are asking why the behavior is different when a
#version statement is /not/ present. But in that case, there's no reason
to favor compatibility over correctness: 3.6 default gamma handling was
simply wrong (because it wasn't any gamma handling at all, thereby
producing linear output where other software commonly expects
gamma-precorrected files).
Date: 22 Aug 2009 19:45:00
Message: <web.4a9080701659a44ff8ed4b7f0@news.povray.org>
> Stephen schrieb:
> > On Sat, 22 Aug 2009 10:21:58 EDT, "Frank_C" <fra### [at] skynetbe> wrote:
> >> If you render this scene in both versions, then it looks as if the sphere has
> >> "flattened" in the new version.
> > Sorry but the only differences that I get in pigment which disappears when
> > adding  global_settings { assumed_gamma 1 } to the v3.62 scene.
> Same here.
> Frank, are you sure you used the same resolution with both renders?
Hi!
I used indeed the same resolution settings for both renderings.
As Stephen indicated, the assumed_gamma keyword made both renders equal. However
I added an {assumed_gamma 2.2} in POV3.7 instead of an {assumed_gamma 1} in
POV3.62. This is because -on my PC- the latter setting had the effect of
"flattening" the sphere (or any other object).
Kind regards
Frank
Date: 22 Aug 2009 19:49:22
Message: <4a908402$1@news.povray.org>
Ah, I see! I thought you meant geometric "flattening", but you're
talking about colors.
Yes, gamma handling is significantly different between 3.6 and 3.7, and
does lead to differences in color "intensity".
Date: 22 Aug 2009 20:00:01
Message: <web.4a90851d1659a44ff8ed4b7f0@news.povray.org>
Just for the completeness, here's a comparison between the two spheres.
The sphere on the left was created with version 3.6 and the sphere on the right
was rendered in version 3.7. I didn't use the assumed_gamma keyword here.
http://img41.imageshack.us/img41/5444/testgjc.png
Date: 23 Aug 2009 02:48:36
Message: <4a90e644@news.povray.org>
  How is it a false observation that I take a scene, render it in 3.6 and
3.7, and I get results which only differ in their gamma setting, and they
do so rather radically?
  Obviously the default gamma settings are different. What has never been
obvious to me is the reason for this.
  Could you be more precise about this? I still don't understand the reason.
Maybe some concrete examples?
Date: 23 Aug 2009 04:54:40
Message: <4a9103d0@news.povray.org>
Take any scene with (A) an object with a small-scale black-and-white
checker pattern (if you're using a CRT display, use a large scale
horizontally), and (B) some rgb 0.5 object. Render without AA.
Now if you render the whole smash and squint your eyes, you /should/ see
just plain 50% grey for both objects.
Indeed the black-and-white object (A) /will/ look 50% grey (unless your
display's black and/or white point are bogus), because POV-Ray will have
output the perfectly unambiguous values 0 and 255 representing 0% and
100% intensity respectively, in a 1:1 mix, and averaged no earlier than
when passing between your eyelids.
In 3.6, however, the rgb 0.5 object (B) will look way darker: POV-Ray
will have output "127", but your graphics card + display will interpret
this as a meager 22% grey (0.5^2.2 - provided your display has indeed a
gamma of 2.2).
3.7, on the other hand, will output "186" (255 * 0.5^(1/2.2)) for rgb
0.5, which is just the right value for a 2.2-gamma display system to
show 50% grey ((186/255)^2.2); even if your display gamma is somewhat
off, like 2.0 or so, it will still be closer to the right thing than the
3.6 output.
(Or, alternatively, POV-Ray will output "127", but store information in
the output file that a display gamma of 1.0 has been assumed, leaving it
  to the image viewer to perform gamma-correction; this will happen for
instance if you choose PNG output and set File_Gamma=1.0.)
Date: 23 Aug 2009 05:02:50
Message: <4a9105b9@news.povray.org>
  You mean that POV-Ray 3.6 didn't gamma-correct the output at all, while
POV-Ray 3.7 now does?
  Does that mean there's now a new option to set the gamma correction of
the created image (the actual pixels, not just some header data in the
image file format)? Is there a way to turn this off, if one so desires
(eg. if you really *want* the pixels to be exactly (127,127,127) and
nothing else)?
Date: 23 Aug 2009 05:24:31
Message: <4a910acf$1@news.povray.org>
I mean that 3.6 didn't do it /by default/ (which is what you've been
asking about all the time).
> nothing else)?
Yup. "File_Gamma" is the magic ini file option. Set it to 1.0 and you'll
get linear pixel values, plus (for PNG and HDR) a header saying that the
data is linear. Set it to 2.2 and you'll get gamma pre-corrected pixel
values, plus a header saying that the data is pre-corrected for a gamma
of 2.2. (The latter is highly recommended though, as not all viewers -
browsers included - support linear image data.)
Note that this makes it impossible to deliberately mess with gamma for
artistic effect in POV-Ray when you use PNG output and all your image
processing software handles gAMA chunks properly: You can only affect
the encoding of pixels - and thereby the dynamic ranges of highlights
vs. shadows - but not their interpretation.
At least that's the theory as known to me. I never tested in detail
whether it indeed works exactly as intended.
