POV-Ray : Newsgroups : povray.beta-test : Povray 3.7 - duty cycle : not working or obsolete? Server Time
4 Mar 2026 02:12:03 EST (-0500)
  Povray 3.7 - duty cycle : not working or obsolete? (Message 1 to 7 of 7)
Subject: Povray 3.7 - duty cycle : not working or obsolete?
Date: 23 Jun 2009 13:15:00
Message: <web.4a410cbccb89257b9ff3d51b0@news.povray.org>
First, hi to all the Povray community and team. And thanks for this great
software I use for many years. This is the first time I post something here. I
decided to look at Povray3.7, even if it is in beta, the new feature of
Subsurface Scattering is attracting! There was a function in Povray 3.6 I use
everytime is duty cycle. Time is not important, and I prefer to have some CPU
time for me and my other applications instead of 100% rendering. In Povray 3.7
this function seems to be not working. Is this a feature you'll drop in the
next version? Or it is disabled for the beta?
The other things are working normally for me, except some scenes with photon
mapping, I found that caustics seems to be brighter in 3.6.
Now, when I need some CPU time, I pause the render.
Subject: Re: Povray 3.7 - duty cycle : not working or obsolete?
Date: 23 Jun 2009 19:19:13
Message: <4a4162f1$1@news.povray.org>
When you render with version 3.7, the process priority in "lower than
normal".
This means than just about every other processes have a higher priority.
In fact, on my computer, there are only 2 process running with a lower
priority: Idle and those of distributed computing projects that I
participate in, like Seti@home.
The result is that your other applications will take precedance, and
that the duty cycle setting is no longer usefull.
Historicaly, the purpose of that setting was so that a computer
operating in zero G had less chances of overheating. There is no thermal
convection in the shuttle or in the International Space Station.
Date: 25 Jun 2009 11:55:01
Message: <web.4a439cb4626d35394456e660@news.povray.org>
For all who think this sounds like pure bullshit babble: POV-Ray has indeed been
up in space. See the Hall of Fame for what I guess is probably the only artistic
3D render ever produced under zero G conditions.
Date: 25 Jun 2009 12:15:01
Message: <web.4a43a1a4626d3535fd99d9e0@news.povray.org>
I used this feature when my laptop was overheating. It kept it rendering without
shutting down.
Date: 25 Jun 2009 12:40:00
Message: <web.4a43a7a3626d35357b0d79f0@news.povray.org>
> shutting down.
> Stephen
Not only in space... A laptop can easily overheat on Earth when the processor is
constantly at 100%. And Duty Cycle was a good option to save temperature.
There is this small Windows utility from SysInternals :
http://technet.microsoft.com/en-us/sysinternals/bb897540.aspx
Of course, on Windows you can just hit "Pause" in the editor, but with this
command, I think there is a possibility to write a script to "pause" Povray
every 10 seconds for example, when you run renders by night. It will be a
simple solution if POVRay drops this feature instead of recompiling POVRay.
Date: 25 Jun 2009 12:41:04
Message: <4a43a8a0@news.povray.org>
  Yes, that duty cycle option was added precisely for that space flight.
  Anyways, the purpose of the duty cycle option is to keep the CPU idle
for a certain percentage of time in order to avoid overheating. Its purpose
is not really to give time to other processes. Time sharing is a feature
of the operating system, and in most of them you can configure the priority
of processes. If you want POV-Ray to hog less CPU, just tell your OS to give
it a lower priority: Then if some other program needs CPU, the OS will share
more of it for that program.
  All modern desktop operating systems use pre-emptive multitasking. The
days of cooperative multitasking are long over. If you are using the duty
cycle option for emulating cooperative multitasking, you are using the
wrong tool.
Date: 29 Jun 2009 11:18:56
Message: <4a48db60$1@news.povray.org>
> indeed been
> artistic
I wonder if NASA has to put this function in all of its software :-)
BTW, couldn't you just underclock the CPU?
