POV-Ray : Newsgroups : povray.beta-test : Beta 31: Crackle problem Server Time
5 Apr 2026 11:32:24 EDT (-0400)
  Beta 31: Crackle problem (Message 20 to 29 of 29)
Subject: Re: Beta 31: Crackle problem
Date: 9 Mar 2009 05:10:32
Message: <49b4dd08@news.povray.org>
clipka wrote:
> Chambers <ben### [at] pacificwebguycom> wrote:
>> > Basically we need
>> > to drastically reduce the number of times we get memory from the global
>> > heap, while at the same time trying to avoid getting too much memory at any
>> > given time (which may not be needed).
>> If memory is allocated in chunks, then maybe a command-line parameter to
>> set the chunk size would be useful for testing until an optimum solution
>> is found.  Also, this would allow people with more RAM to use larger
>> cache sizes as a default, avoiding the penalty completely.
> Another option: Allocate chunks of increasing size. Allocated N bytes in total
> and they didn't suffice? Then allocate another N bytes next time for a total of
> 2*N. Still not enough? Go for another 2*N bytes.
> This way you can start out small to save memory in case it's not used much
> (waste is guaranteed to never be more than 50%), but get out of the "cost zone"
> quickly if you really need a lot of it.
> Add some "hard deck" if desired to make sure you don't waste 0.9 GB if you
> happen to need 1.1GB.
> Don't use dedicated pools for particular data structures, but allocate blocks
> for generic use, rolling your own (thread local) heap management.
Most of this stuff was already done, it's not as simple as it appears.
That said, try the current test exe.
-- Chris
Date: 9 Mar 2009 05:11:31
Message: <49b4dd43@news.povray.org>
Another test version:
  http://www.povray.org/temp/pvengine-crackle.zip
-- Chris
Date: 9 Mar 2009 05:16:04
Message: <49b4de54$1@news.povray.org>
The work I've just done brought me more or less to the conclusion that we
do need a way to allow users to provide performance hints to the renderer.
There are a number of places - particularly crackle cache - where we could
benefit from the user letting the renderer know whether they care more
about memory than speed. It's not really something we can guess in advance.
-- Chris
Date: 9 Mar 2009 10:00:01
Message: <web.49b51f9354d6e309abfc91e10@news.povray.org>
As I said, just a kind of brainstorming. Based, to be honest, not on my
knowledge of the crackle code (which in fact amounts to zero), but on how
memory handling is currently implemented in the radiosity code.
Date: 9 Mar 2009 13:35:00
Message: <web.49b552ad54d6e30912a5893a0@news.povray.org>
> -- Chris
Grazie!
I will do some tests.
Carlo
Date: 11 Mar 2009 06:50:01
Message: <web.49b7964854d6e309e8a02c3c0@news.povray.org>
> -- Chris
For me, *crackle problem* vanquished.
The performance is (significantly) improved (than 3.6.1)
I am (slightly) puzzled only for crack1.pov, so I will do further tests.
Carlo
Date: 11 Mar 2009 21:55:59
Message: <49b86baf$1@news.povray.org>
can you advise if the performance is better than 3.6.1 on a single thread? (i.e.
run the the new code with one thread only, assuming you have a SMP machine).
-- Chris
Date: 12 Mar 2009 13:10:00
Message: <web.49b9414d54d6e309fefec3860@news.povray.org>
> -- Chris
My first computer is died, so I did my tests with "muletto" (a term derived from
Formula One): Amd Athlon 1.4 Ghz and 512Mb RAM.
I don't know how this can be significat test.
Neverhless, I hope I can make myself useful.
Carlo
Date: 13 Mar 2009 04:50:00
Message: <web.49ba1d5a54d6e309178ef37a0@news.povray.org>
For now...
- Machine: Amd Athlon 1.4Ghz, 512Mb RAM, XP Home SP3 -
[File: ...\POV-Ray\v3.7\scenes\textures\patterns\crackle1.pov]
[   Settings: 1600x1200 pixels noAA -D (five tests)          ]
- 3.6.1 vs. 3.7.31 (with crackle problem):
       3.7.31 faster than 7.0/8.5%
- 3.7.31 (with crackle problem) vs. 3.7.31 (crackle patched):
       3.7.31 (patched) faster than 0.8/3.0%
[File: ...\POV-Ray\v3.7\scenes\textures\patterns\crackle2.pov]
[   Settings: 1024x512 pixels noAA -D (five tests)           ]
       3.7.31 faster than 58.9/60.0%
       3.7.31 (patched) "slower" than 0.0/0.9%
       (say the same, perhaps this old cpu has overheated!
       :-D)
Carlo
Date: 13 Mar 2009 19:36:56
Message: <49baee18$1@news.povray.org>
I tried a quick test using 640x480 res., crackle1.pov and crackle_form.pov
(not animated) and got the following.
3.7 beta 31 (fixed crackle) 1 thread:
crackle1.pov
noAA=2.5s; AA=4s
crackle_form.pov
noAA=8s; AA=16.5s
3.7 beta 31 (fixed crackle) 2 threads:
crackle1.pov
noAA=1.5s; AA=2.25s
crackle_form.pov
noAA=4.3s; AA=8.7s
3.6.1c (always 1 thread, of course):
crackle1.pov
noAA=3s; AA=5s
crackle_form.pov
noAA=13s; AA=27s
So in these cases it would seem the AA difference alone is typically an
approximate doubling (or halving without AA) of rendering times, while 2
threads is an obvious speed-up.
And 3.7 shows an improvement over 3.6 even when limited to 1 thread.
On a side note, I couldn't animate crackle_form.pov in 3.6 due to a
freeze-up that required its "process" being shutdown. However, the
unanimated renders have different appearances, such as a truncated cone part
in the 3.6 image where only a small disc shows in 3.7 (amid other *pieces*
of the crackle-made object), which I have no explanation for.
Bob H.
