POV-Ray : Newsgroups : povray.beta-test : That was close... Server Time
16 Feb 2026 20:30:16 EST (-0500)
  That was close... (Message 1 to 7 of 7)
Subject: That was close...
Date: 7 Jan 2009 00:50:00
Message: <web.49644176e3858249fe60fc2c0@news.povray.org>
Darn - one of my hard disks just suffered sudden death!
Looks like something killed the electronics; it still spins up and all, and the
system recognizes that it's there, but it doesn't even disclose its model name
to the BIOS anymore.
Fortunately it was "only" the brand-new Western Digital drive of my
just-as-brand-new Linux machine, and not the main HD in my Windows system... so
the only thing lost are a few shell scripts, a few hours' worth of rendering
time on some standard scenes, and a small deal of installation and
configuration work... plus a few minor updates to the radiosity tutorial I
posted not long ago. Nothing that couldn't be reconstructed in a few hours'
time.
If the same thing had happened to the - significantly older - main HD of my
Windows machine, it would have meant sayonara to something like a week of
brain-wrecking radiosity thinking and coding...
I just checked whether I was smart enough when setting up my project versioning
database: I was. If I should lose any single HD of my Windows system, I might
lose either recent work or the complete version history, but not both... phew!
Might also be a good occasion to dump the current versioning database to CD-ROM.
The nasty thing about it is that with the Linux system I lost my primary
performance testbed for the radiosity code, so unless I get a replacement soon
this might slow progress.
Subject: Re: That was close...
Date: 7 Jan 2009 13:40:01
Message: <web.4964f6d121b42647e44542980@news.povray.org>
I felt a sudden death experience until reading the following paragraphs! XD
Date: 7 Jan 2009 17:59:18
Message: <496533c6@news.povray.org>
This reminds me... I mentioned in p.b.images that I sometimes get black
splotches in certain scenes using radiosity. It is not caused by
reflecting or refracting objects in the scene; I've known about those
artifacts for some time.
This problem is caused by something else. I ran into it again last
night. The radiosity count was at 300 when it happened. As it turns out
the problem has to do with my setting for adc_bailout. I had it set to a
value of 0.1. I changed it to 1/256 and the black splotches are gone! I
found no mention in the docs about such behavior, but it makes sense in
a way. I don't know why raising the count would make black splotches
suddenly appear though, but since I have a fix I don't really care at
this point. I thought I'd let you know about it, just in case it's not
supposed to work that way.
Sam
Date: 7 Jan 2009 20:30:00
Message: <web.4965569d21b42647e6fcd2f30@news.povray.org>
> a way.
Hum... why should it make sense to get black splotches if your adc bailout is
too high? ;)
It is indeed not supposed to. But I expected something like this from the code -
I just didn't bother to try and come up with a test scene - instead I just fixed
that thing... ;)
It's quite a similar problem as with the max trace level: In both cases, if some
ray caused a sample to be taken, the relevant values (current trace level and
weight) were "inherited" by the sampling rays. If the origonal ray happened to
be reflected, these values would leave comparatively few trace iterations
(either due to the trace level, or due to the ADC bailout). But for the
surrounding samples the original rays might have come directly from the camera,
equipping the sampling rays with both a higher number of trace levels to go and
a heavier weight, so they might see a mirror or window where that other sample
just saw a pitch black square.
Date: 8 Jan 2009 19:45:09
Message: <49669e15$1@news.povray.org>
I have found that hard drives are not as reliable as they used to be.
Several years ago I lost my main drive and hadn't made a backup for several
months. It was the main reason I stopped doing graphics for several years.
Since then I have always had several copies of my data and always have a
RAID 1 setup. Hard drives are so big these days and relatively inexpensive
there really is no reason not to. On paper the chance of losing both disks
is 0.25%, although realistically it is probably a little higher. It has been
a nice setup, since I have had drives fail over the years and have been able
to just replace the drive and mirror without any major downtime or hassle. I
make a point to keep any non-essentials like programs and the OS on a
different disk since these are most likely to frag a disk(yes, I use
Windows). I guess that sounds a little paranoid...
Mike
"clipka" <nomail@nomail> wrote in message
news:web.49644176e3858249fe60fc2c0@news.povray.org...
> and the
> name
> system... so
> rendering
> hours'
> time.
> my
> versioning
> might
> phew!
> CD-ROM.
> soon
Date: 10 Jan 2009 03:20:00
Message: <web.496859b321b42647f3c0a050@news.povray.org>
It's actually the first hard drive I ever lose (well, the first one that is a
total loss, instead of just being mangled enough to start losing data and
wanting replacement), so you may be right. Maybe not too much of a surprise, as
the devices necessarily keep getting more and more delicate as the storage
density increases.
My wallet calls your approach paranoid indeed, but the security-aware computer
expert in me calls it wisdom... so far, it's just that my wallet has always had
the last say when it came to my personal stuff, righteously claiming that
"nothing has ever happened so far". So with that Linux machine mainboard having
five SATA channels, maybe it is time to go RAID.
My windows machine doesn't allow an easy transition to RAID, however. It does
have some BIOS support for RAID, but with only two SATA channels - and both of
them already in use (and the IDE channels just as well) - that might be a
daring quest in itself.
Date: 14 Jan 2009 17:43:39
Message: <496e6a9b@news.povray.org>
Reliability doesn't sell. Capacity sells. Capacity involves putting bits
closer together, lowering reliability (they make them more reliable to
compensate for that but not enough).
