POV-Ray : Newsgroups : povray.beta-test : Problem with "no_image" and transparency? Server Time
16 Jan 2026 03:06:42 EST (-0500)
  Problem with "no_image" and transparency? (Message 1 to 10 of 12)
Subject: Problem with "no_image" and transparency?
Date: 24 Sep 2007 19:45:01
Message: <web.46f84a9cd032f3c7cb86afba0@news.povray.org>
I have a kinda weird problem with the newest beta. I hope I can explain it
in a not too confusing way.
Around my scene, I have a large sphere with the parameters
no_image
no_shadow
inverse
It serves as a kind of reflection or environment map, as shiny surfaces in
my scene will reflect this sphere while the thing itself is invisible.
With the latest beta, weird things happen to object that have a transparent
or semi-transparent surface. While the exterior surface is correctly made
transparent, the then-visible interior is not... it shows the texture of
that sphere instead.
I tried defining an "interior_texture" for those objects, setting them to
full transparency, but that didn't change a thing.
I'd like to know if that is a bug in the new beta or just some new way of
interpreting textures... in the latter case, what do I have to change?
Thx,
Ansgar
Subject: Re: Problem with "no_image" and transparency?
Date: 25 Sep 2007 02:58:19
Message: <46f8b18a@news.povray.org>
Ansgar <Tem### [at] gmxde> wrote:
> no_image
> no_shadow
> inverse
  Are you sure this doesn't happen with POV-Ray 3.6 too? Because I can't
see anything logically wrong with that behavior according to the settings
you have specified. ('no_image' means that the object is ignored for rays
shot directly from the camera, ie. the first recursion rays, but when a
ray goes through an object it's not a first-recursion ray anymore.)
Date: 25 Sep 2007 04:15:00
Message: <web.46f8c270aff96f2fcb86afba0@news.povray.org>
It does not happen in 3.6.
Transparent or semi-transparent parts let the background color of the scene
show through, as it should be.
Date: 25 Sep 2007 05:10:00
Message: <web.46f8d032aff96f2fcb86afba0@news.povray.org>
I just went through the POV-Ray help and found this in the section about
"no_image".
"When no_image is used, the object will not be seen by the camera, either
directly or through transparent/refractive objects. However, it will still
cast shadows, and show up in reflections (unless no_reflection and/or
no_shadow is used also)."
There you go. The object is not supposed to be seen through
Date: 25 Sep 2007 06:55:34
Message: <46f8e926@news.povray.org>
  Then it's probably a bug in 3.7.
Date: 25 Sep 2007 19:17:43
Message: <46f99717@news.povray.org>
> "no_image".
Please post a minimal sample scene for us to work with.
thanks,
-- Chris
Date: 26 Sep 2007 09:17:46
Message: <46fa5bfa$1@news.povray.org>
Chris Cason nous apporta ses lumieres en ce 2007/09/25 19:17:
>> "no_image".
> thanks,
> -- Chris
As minimal as you can:
plane{z, 15 pigment{checker}finish{ambient 1} no_image}
sphere{<0,0,3>,1 pigment{rgbt 1}}
It should be all black but you see the checker pigment through the sphere.
Documentation; The worst part of programming.
Date: 26 Sep 2007 11:41:42
Message: <46fa7db6@news.povray.org>
Le 26.09.2007 15:17, Alain nous fit lire :
does it mean we need no_transmission and no_refraction also ?
The superior man understands what is right;
the inferior man understands what will sell.
-- Confucius
Date: 26 Sep 2007 14:56:50
Message: <46faab72$1@news.povray.org>
Le Forgeron nous apporta ses lumieres en ce 2007/09/26 11:41:
No. Just make no_image work coherently between versions, and according to the
documentations.
An object with no_image is normaly invisible, but still cast shadows and show in
reflections.
An object with no_reflection is visible, cast shadow, but don't show in reflections.
An object with no_shadow is visible normaly and in reflections but don't cast
any shadow.
WARNING: The consumption of alcohol is a major factor in dancing like a retard.
Date: 29 Sep 2007 16:55:05
Message: <46febba9@news.povray.org>
> to the documentations.
Why not? We could have no_image work coherently between versions and new
no_transmission and no_refraction keywords too ;-)
