POV-Ray : Newsgroups : povray.beta-test : Small scene causing beta 14 to exit on completion ... Server Time
11 Oct 2025 01:18:12 EDT (-0400)
  Small scene causing beta 14 to exit on completion ... (Message 1 to 7 of 7)
Subject: Small scene causing beta 14 to exit on completion ...
Date: 18 Aug 2006 07:15:00
Message: <web.44e5a00bfcc26e0fc717c9af0@news.povray.org>
Hi Folks,
I've posted a similar message on the Windows group about a small, apparently
sensible scene, throwing an unhandled exception.
I've now tried a very similar scene on beta 14, causing it to exit on
completion. The scene is appended below. I can see nothing wrong with the
scene code and I'd appreciate knowing why it fails.
System: 933MHz PIII, 512Mb, Win XP Pro SP2, PoV-Ray
v3.7.0.beta.14.icl8.win32
Bye for now,
Mike Andrews.
// --- code starts ---
#declare camPos = 5*<-0.1,6,-5>;
camera{
  ultra_wide_angle
  up y
  right x*4/3
  location camPos
  look_at  0
  angle 50
#declare Phi=(sqrt(5)+1)/2;
#declare rPhi=2-Phi;
#declare Cen = (Phi-1)/(2*Phi-1);
#declare Ill = box {
  <0.1,-rPhi-0.1,-0.01>,<0.9,-0.1,0.01>
  translate <-Cen,0,-Phi*(1-Cen)>
#declare Scl = 1;
#declare Rot = 0;
#declare C = 0; #while (C < 10)
  object {
    Ill scale Scl rotate -Rot*y
    translate <Cen,0,Phi*(1-Cen)>-<0.5,0,Phi/2>
    rotate 90*y
    scale 20
    pigment { rgb 1 }
    finish { diffuse 0 ambient 1 }
  #declare Scl = Scl/Phi;
  #declare Rot = Rot+90;
#declare C = C + 1; #end
// --- code ends ---
Subject: Re: Small scene causing beta 14 to exit on completion ...
Date: 29 Aug 2006 06:49:45
Message: <44f41bc9$1@news.povray.org>
"Mike Andrews" <nomail@nomail> wrote in message
news:web.44e5a00bfcc26e0fc717c9af0@news.povray.org...
> Hi Folks,
> apparently
I got the same on my system however I'm running as follows:
System: 2.39GHz P4 1GB Win XP Pro SP2, PoV-Ray v3.6.icl8.win32
so either something got missed in the last release or it IS something with
your code ....
I was curious when I recalled I had v3.5.ic18.win32 installed as well so I
ran your file using that version and it finished the render .....
so maybe it's NOT your code .....
Jim
Date: 29 Aug 2006 09:40:01
Message: <web.44f44290ce1381d8c717c9af0@news.povray.org>
Hi Jim,
Thanks for the feedback.
This seems to be a very odd fault, as the code is almost identical to code I
often use and I can not discern anything wierd about it. I'm hoping the devs
can figure it out ...
Bye for now,
Mike Andrews.
> > Hi Folks,
> > apparently
> your code ....
> Jim
Date: 30 Aug 2006 19:05:00
Message: <44f6199c$1@news.povray.org>
	The scene renders fine with the Linux beta.14a, so I suppose what you
experience is indeed Windows-specific (your other scene posted in the windows
group also renders fine under Linux with both POV-Ray 3.6.1 and 3.7.0.beta.14a).
	- NC
Date: 31 Aug 2006 05:45:00
Message: <web.44f6af5ece1381d85e1e98150@news.povray.org>
Hi Nicolas,
>  - NC
I'm wondering if the problem is compiler (optimisation?) dependant. As I
noted in the windows group thread a Cygwin (GCC 3.4.4) compile of MegaPOV
also ran the scene without problems.
Bye for now,
Mike Andrews.
Date: 3 Sep 2006 18:37:32
Message: <44fb592c@news.povray.org>
Can you please test it using both no bounding (-mb) and also the new BSP
bounding (+b2)?. I have a suspicion it's in the BVH code, but it's sneaky and
goes away when I do a debug build, plus in release mode it triggers a crash
somewhere other than the actual fault location (heap corruption).
-- Chris
Date: 4 Sep 2006 12:07:12
Message: <44fc4f30$1@news.povray.org>
This is fixed now, thanks for the report.
-- Chris
