POV-Ray : Newsgroups : povray.beta-test : Bug: dispersion_samples affects photon brightness Server Time
24 Mar 2026 17:49:18 EDT (-0400)
  Bug: dispersion_samples affects photon brightness (Message 1 to 3 of 3)
Subject: Bug: dispersion_samples affects photon brightness
Date: 12 Oct 2001 22:29:40
Message: <MPG.1631c5fca936293298969e@news.povray.org>
While playing with Photons and dispersion I noticed that higher
dispersion_samples also gives brighter refractive photons.
With dispersion_samples 7 (default) the brightness is equal to photons
without dispersion, but with for example 14, they are way too bright.
I guess the brightness of each color-band is divided through the default
dispersion_samples of 7 instead the dispersion_samples actually used in
the texture.
Win98SE, Pov 3.5 beta 6
Lutz-Peter
Subject: Re: Bug: dispersion_samples affects photon brightness
Date: 13 Oct 2001 09:13:31
Message: <MPG.16325cd38179c1ea98969f@news.povray.org>
Here is a scene to demonstate the bug:
#version 3.5; // beta 6
global_settings
	assumed_gamma 2
	photons{count 5000}
camera{location <1,4,-4> look_at <.5,0,0> angle 60}
light_source{<-10,4,0>	color rgb 1}
plane{y,0 pigment{color rgb 1}}
prism
	0,1,3,<-.5,.001>,<.5,.001>,<.001,1> rotate -x*90
	pigment{color rgbt <1,1,1,.8>}
	interior
		ior 1.2
		dispersion 1.05
		dispersion_samples 7 // higher-> brighter!
	photons
		target
		refraction on
		collect off
Date: 2 Nov 2001 13:15:58
Message: <3BE2E2E7.D76D7F0C@engineer.com>
Same with beta 7 both compiles. This is not on the known bugs list.
I used a different scene with dispersion samples 100:
http://lightning.prohosting.com/~lf/dispersion2.jpg
_____________
Kari Kivisalo
