POV-Ray : Newsgroups : povray.beta-test : POV-Ray v3.8.0-x.freetype.1 Server Time
24 Jun 2026 01:53:52 EDT (-0400)
  POV-Ray v3.8.0-x.freetype.1 (Message 1 to 10 of 22)
Subject: POV-Ray v3.8.0-x.freetype.1
Date: 16 Jan 2019 21:22:52
Message: <5c3fe6fc$1@news.povray.org>
Now implementing `text` objects via FreeType and prism primitives:
https://github.com/POV-Ray/povray/releases/tag/v3.8.0-x.freetype.1
Some notes:
- The `cmap` syntax is currently doing nothing.
- Support for various non-TrueType fonts should be included for free,
provided the font is any outline font (e.g. CFF-flavour OpenType fonts).
Bitmap fonts will of course not work, nor will colour SVG fonts.
- Performance has degraded a bit, but I'm willing to accept this for the
sake of extended functionality and easier maintenance.
Also, render results differ in several ways:
- Previously, the text was aligned so that x=0 coincided with the
/actual/ left side of the first character (i.e. its outline). The new
implementation instead has x=0 coincide with the first character's
/nominal/ left side (i.e. its "character box"), leaving a small gap
typically matching half the distance between characters. Since I expect
this to give aesthetically more pleasing results with multiple lines, I
hesitate to invest time and effort to reproduce the old behaviour.
- In some cases (e.g. the German umlaut sequence `äöüß` with the
`arial.ttf` font) horizontal placement of individual characters has
changed. Since the new behaviour looks cleaner, I have no intention
whatsoever to reproduce the old behaviour.
- POV-Ray v3.7 (haven't checked whether this has been fixed already) had
the inside/outside orientation of the character "sides" the wrong way
round, giving unexpected results when `interior_texture` is used. This
has also been changed to be consistent with the character "faces" (*).
- (*) For normal TrueType fonts, that is. Based on the FreeType
documentation, I totally expect the new implementation to get this
wrong, and/or to mess up the "holes" (e.g. in characters like `o`), with
/some/ font file formats or even individual fonts. Please keep your eyes
peeled, I'm keen to get my hands on any such font specimens.
Subject: Re: POV-Ray v3.8.0-x.freetype.1
Date: 17 Jan 2019 09:05:50
Message: <5c408bbe$1@news.povray.org>
> Some notes:
Hmm, I'm surprised some by this. Are your test character strings really
short? In the existing text shape code all the characters ended up more
or less as one huge glyph as you know. As the string to the text shape
got large, performance slowed substantially. Your implementing
internally as a union of prisms should address this shortcoming well -
providing a lot of room for other code to slow without overall impact.
Wonder... Is the prism object a lot slower than the text object was?
(I've never compared)
It is fixed in the current 3.8 master. You picked up - or made
independently - a change quite like one Jérôme made in hgpovray. I know
because that code change collided on a rebase in a text shape branch
where I'd made similar updates. I vaguely remember doing some
verification of the fix too, along with some prism fix - but... maybe /
maybe not.
I have somewhere a crude test set up / scene collection I created when I
did my text shape hacks. I'll put it on my list to run those.
Plus, IIRC, I saw font sites offering fonts in multiple formats. Might
be we can turn up problems with holes / overlaps or whatever by running
such format sets and comparing resultant images. I now have a pretty
good semi-automated testing framework for that sort of scene to sceen
image testing so shouldn't take too much to get something going -
provided I'm right about the availability of fonts in multiple formats.
Good stuff Christoph!
However, first up for me is to rebase my branches to the current 3.8
master with the updated parser so the solver/other personal branch
testing I'm doing is running the updated parser too.
Bill P.
Date: 17 Jan 2019 12:03:05
Message: <5c40b549$1@news.povray.org>
Am 17.01.2019 um 15:05 schrieb William F Pokorny:
>> the sake of extended functionality and easier maintenance.
My strings are roundabout one or two dozen characters.
My first guess was that it was caused by 3rd order vs. 2nd order
splines, but that doesn't seem to make much of a difference.
Another potential cause for slowdown could be rooted in prism being able
to support conic sweeps.
My current guess however is that there's some "poor man's bounding"
hidden in the TrueType code that the prism doesn't have.
What I can say is that the same text strings composed into a single
prism gave abysmal performance.
What I also can say is that my performance comparisons were only cursory.
Yeah, found text to that effect in the changelog, so it must be true ;)
>> with /some/ font file formats or even individual fonts. Please keep
>> your eyes peeled, I'm keen to get my hands on any such font specimens.
If you would like to pick up that glove some time in the near future,
I'd very much appreciate it.
Right now, I have found one font where the surface normal orientation is
broken for at least one character, namely the closing square bracket
("]") in the "Arial Black" font. I blame FreeType, with the mechanism
being that the font defines that glyph by scaled reference to the
opening square bracket glyph ("["), mirroring it horizontally (and thus
messing up control point order).
Date: 17 Jan 2019 12:41:34
Message: <XnsA9DABE280A130seed7@news.povray.org>
interesting feature for fonts ;)
ingo
Date: 17 Jan 2019 12:52:29
Message: <5c40c0dd@news.povray.org>
Am 17.01.2019 um 18:41 schrieb ingo:
Not currently supported; would need extra work to make sure all
characters converge towards the same apex point.
Date: 3 Feb 2019 04:04:36
Message: <5c56aea4$1@news.povray.org>
Actually, wading through the old code for unrelated reasons, I just
noticed that this isn't true: The old `text` primitive has actually been
a CSG union all along, with one child per character.
Date: 3 Feb 2019 10:35:27
Message: <5c570a3f$1@news.povray.org>
>> really short? In the existing text shape code all the characters ended
>> up more or less as one huge glyph as you know. As the string to the
>> text shape got large, performance slowed substantially.
Hmm. Not my recollection or experience. I was focused on inside tests if
those were perhaps done differently than intersections. The glyph loop
range testing I added helped regular intersection performance too, but
less.
Anyway. I'll keep what you saw in mind. Possible the code work I did was
pointless, and the performance gains seen false, for reasons of
self-foolery.
I'm maintaining my text branch with the thought the new text object
might also be too slow for what I want. Means, if motivated, I can again
do performance comparisons to the 'old' text object as well as your new
one off master, but, I probably won't so long as the new is fast enough.
Bill P.
Date: 3 Feb 2019 20:17:18
Message: <5c57929e$1@news.povray.org>
That's coherent with the object count : Adding a long text object really
increase the number of objects in a scene.
Date: 5 Feb 2019 08:25:00
Message: <web.5c598e8c67ef2bd393ab27150@news.povray.org>
*must go through old scenes to see if/where I make this ASSumption.*
Date: 7 Feb 2019 11:31:43
Message: <5c5c5d6f$1@news.povray.org>
>>> ended up more or less as one huge glyph as you know. As the string to
>>> the text shape got large, performance slowed substantially.
>> been a CSG union all along, with one child per character.
> less.
Trying to avoid sliding too much sideways into work I did almost two
years ago given I've already got more going than I'll ever finish. Can't
completely help it I guess. Over the past days, kept asking myself how
could I see such large performance improvements if the text object was
already a union (Christoph and Alain being almost certainly right).
- Remembered two years ago I was mostly going after performance using
hardware counter analysis. I was going after hot spots.
- Remembered a decade ago with the objectAsIso experiments how I looked
hard at converting other than the simplest csg to a mesh because the
inside test performance got so slow with larger/complex csg.
- Remembered Lanuhum's Blender hair scene and thinking it shouldn't
really be that slow, even with super slow sphere_sweeps.
- Remembered thinking on trying it years ago the +bm2 mode should
provide more performance than it does.
- Remembered learning early last year while finding the cause of a
particular speckling bug, that POV-Ray does inside tests when it creates
original rays.
- Remembered thinking fixes to that particular speckling bug and issues
like: https://github.com/POV-Ray/povray/issues/139 will likely require
multiple inside tests over one to account for floating point noise no
matter any improved accuracy.
These last two thoughts led me to doing a new performance test with our
ttf1.pov sample scene. One where all I changed was whether or not AA
used. My thinking is the performance improvement of my text branch
should be more or less the same with and without AA. It should be the
same, unless, the text object is a union and the real performance
problem is the csg inside test mechanism doing something like just
trundling through ALL the shapes in a csg.
Results were not similar. This leads me to a new suspicion / unproven
theory we are sitting on a csg inside test performance issue. One
perhaps affecting things generally. My code changes to the text object
only treated another problem.
I've spent zero time in the csg code and I'm working/playing elsewhere
for the foreseeable future. I'm put digging here on my, maybe, someday
list - for what little that's worth! My new theory is perhaps wrong too
- but there is something going on inside test wise which is not very
efficient.
Aside: Even looking at single shapes of a type, the inside test
performance is often awful. This is why that isosurface peeling paint
skin test of Thomas's superellipsoid using the hard/soft object patch
was so extremely slow. IIRC, a box replacement was more than 20x faster.
Bill P.
--------------------------- Data for those interested.
/usr/bin/time povray ttf1.pov +am2 +a0.1 +r4 +wt1 \
                      -j -cc -fn -d -p +w2000 +h2000
p380
12.39user 0.04system 0:12.71elapsed With +a0.1
12.21user 0.03system 0:12.51elapsed
12.27user 0.03system 0:12.56elapsed
36.87
4.40user 0.03system 0:04.70elapsed  With -a0.1
4.36user 0.05system 0:04.65elapsed
4.40user 0.02system 0:04.66elapsed
13.16
p380 + my text shape branch
12.08user 0.04system 0:12.40elapsed With +a0.1
12.08user 0.04system 0:12.36elapsed
12.18user 0.03system 0:12.45elapsed
36.34                               -1.44%
4.39user 0.01system 0:04.64elapsed  With -a0.1
4.32user 0.04system 0:04.59elapsed
4.34user 0.03system 0:04.64elapsed
13.05                               -0.84%  (??? Hmm)
----------- Repeating a few previous perf tests for my text branch.
soft_object.pov   p380 + hard/soft object only.
345.96user 0.08system 5:46.50elapsed   As 'text union'
64.91user 0.04system 1:05.52elapsed    Individual chars at top (-81.24%)
soft_object.pov   p380 + hard/soft object + my text shape branch.
161.22user 0.05system 2:41.78elapsed  As 'text union' -53.40%
69.42user 0.02system 1:09.99elapsed   Individual chars at top  (+6.95%)
