POV-Ray : Newsgroups : povray.beta-test : v3.7.1 beta.6 Server Time
13 Jul 2025 08:09:06 EDT (-0400)
  v3.7.1 beta.6 (Message 1 to 10 of 30)
Subject: v3.7.1 beta.6
Date: 7 May 2017 11:40:34
Message: <590f3ff2$1@news.povray.org>
https://github.com/POV-Ray/povray/releases/tag/v3.7.1-beta.6
Happy testing!
Subject: Re: v3.7.1 beta.6
Date: 7 May 2017 20:15:00
Message: <web.590fb831e4817c0b540f0de50@news.povray.org>
> Happy testing!
it immediately crashed on my win7 ultimate 64 box;
pov-ray critical error
failed to initialize frontend: timed out waiting for worker thread startup
unfortunately, it appears that the execution of an illegal instruction
at address 0x000000014001d6d3 has caused this unofficial
pov-ray build to crash. <write a dump?>
this is a dual-boot machine (ubuntu 16), the source compiled and ran without
issue.
Date: 8 May 2017 01:26:06
Message: <5910016e$1@news.povray.org>
Am 08.05.2017 um 02:13 schrieb green:
>> Happy testing!
Does this happen even before you have the opportunity to start the GUI?
If so, then my first guess would be that it has something to do with the
CPU-specific optimized code. Exactly what hardware are you running the
binaries on?
Otherwise, if you get that far, please post the initial contents of the
message pane.
Also, have you tried the 32-bit binaries instead?
> issue.
I presume that in this context you're talking about the Linux version?
Did you use the beta.6 source code there?
Date: 8 May 2017 07:05:00
Message: <web.591050a1e4817c0b883fb31c0@news.povray.org>
> Happy testing!
Some questions before I install this (on Windows)...
Is this a 'full' install like 3.7.1-beta 5?
If so, will it overwrite that previous beta? (I.e., should I temporarily rename
or move that previous beta's folder, if I want to keep it?)
Or will this new one reside safely alongside beta 5, in its own folder?
OR, is this install only the pvengine file, to replace another one somewhere?
I just want to make sure, before I do something dumb or irreversible...
Date: 8 May 2017 07:35:00
Message: <web.591056e1e4817c0b5149095f0@news.povray.org>
> > Happy testing!
> issue.
I also have the same error, the x86 and sse2 binaries also crash at different
addresses, my system is Windows XP64, Intel QX9650.
Beta 5 run flawlessly.
Date: 8 May 2017 09:05:48
Message: <59106d2c@news.povray.org>
Am 08.05.2017 um 13:04 schrieb Kenneth:
All the betas are full installation packages (as opposed to the "raw"
binaries of the 3.7.1-alpha series of releases); they are designed to
live happily alongside a "stable" 3.7.x installation (i.e. 3.7.0 in this
case), but no deliberate attempt is made whatsoever to let multiple
betas co-exist.
Some degree of separation between different betas may be achieved by
installing in a different folder, but a certain level of interference is
inevitable. Having two betas installed might also cause other problems
further down the road, e.g. the editor DLL installer may not be able to
identify the location of the new beta, and/or it may become difficult to
properly uninstall the older beta later. So it is generally not recommended.
If you want to keep beta.5 around, I would recommend backing up the
executables, then installing beta.6, and copying the beta.5 executables
back in under a different name. That way you'll normally run POV-Ray
3.7.1-beta.6, but will still be able to run beta.5 manually.
Date: 8 May 2017 09:15:06
Message: <59106f5a$1@news.povray.org>
Am 08.05.2017 um 13:30 schrieb LucasGrijander:
Such a difference in the crash addresses is to be expected.
Can you confirm that this is a 64-bit CPU without AVX support?
Also, can one of you guys send a dump file to christoph at the domain
lipka-koeln.de? Thanks.
Date: 8 May 2017 10:10:00
Message: <web.59107b8ae4817c0b540f0de50@news.povray.org>
> >> Happy testing!
yes, immediately, instantly, without any discernible delay.
> binaries on?
old server mash-up.  cpus are two xeon e5450 harpertown.
> message pane.
i tried the other two included binaries at your suggestion, exact same result.
> > issue.
yes, of course.
i just now made a winconsole version.  it ran fine, like the linux.
Date: 8 May 2017 11:38:39
Message: <591090ff$1@news.povray.org>
FYI, the issue seems to be specific to CPUs without AVX support.
Something seems to be going wrong with the optimized noise
implementation there (or, more specifically, with the function intended
to determine the CPU type and come to the conclusion that no optimized
noise implementation is available for those CPUs).
Date: 8 May 2017 11:52:32
Message: <59109440$1@news.povray.org>
Am 08.05.2017 um 17:38 schrieb clipka:
Kudos in this context to the folks at AMD who are currently trying to
figure out how I managed to goof up the optimizations-related code they
had provided us with.
