POV-Ray : Newsgroups : povray.beta-test : crash in origin/master Server Time
25 Apr 2026 06:54:53 EDT (-0400)
  crash in origin/master (Message 1 to 10 of 17)
Subject: crash in origin/master
Date: 12 Feb 2017 04:43:07
Message: <58a02e2b$1@news.povray.org>
I wrote that I was trying the origin/master branch.  It ran my credits
scene just fine, but it tips over often in unix, rendering my first
scene.  It usually parses the whole scene before crashing.
Here's a stack trace:
[Switching to Thread 0x7ffff7ff7700 (LWP 4719)]
0x000000000047bbab in shared_ptr<pov::BackendSceneData> (r=...,
this=0x7ffff7fe7440) at /usr/include/boost/smart_ptr/shared_ptr.hpp:432
432         BOOST_NOEXCEPT : px( r.px ), pn( r.pn )
(gdb) back
#0  0x000000000047bbab in shared_ptr<pov::BackendSceneData> (r=...,
#1  pov::View::CheckCameraHollowObject (this=this@entry=0x7fffe40035c0,
point=..., node=0x7fffd8097c40) at backend/scene/view.cpp:619
#2  0x000000000047bc52 in pov::View::CheckCameraHollowObject
(this=this@entry=0x7fffe40035c0, point=..., node=0x7fffd86b4430) at
backend/scene/view.cpp:613
#3  0x000000000047bc52 in pov::View::CheckCameraHollowObject
(this=this@entry=0x7fffe40035c0, point=..., node=0x7fffd8025b50) at
#4  0x000000000047bc52 in pov::View::CheckCameraHollowObject
(this=this@entry=0x7fffe40035c0, point=..., node=0x7fffd8004aa0) at
#5  0x000000000047bc52 in pov::View::CheckCameraHollowObject
(this=this@entry=0x7fffe40035c0, point=..., node=0x7fffd80085f0) at
#6  0x000000000047bc52 in pov::View::CheckCameraHollowObject
(this=this@entry=0x7fffe40035c0, point=..., node=0x7fffd80095f0) at
#7  0x000000000047bc52 in pov::View::CheckCameraHollowObject
(this=this@entry=0x7fffe40035c0, point=..., node=0x7fffd8009aa0) at
#8  0x000000000047bc52 in pov::View::CheckCameraHollowObject
(this=this@entry=0x7fffe40035c0, point=..., node=0x7fffd8009c50) at
#9  0x000000000047bc52 in pov::View::CheckCameraHollowObject
(this=0x7fffe40035c0, point=..., node=0x7fffd8009d00) at
#10 0x000000000047bdb5 in pov::View::CheckCameraHollowObject
(this=this@entry=0x7fffe40035c0, point=...) at backend/scene/view.cpp:658
#11 0x000000000047ca1e in pov::View::StartRender (this=0x7fffe40035c0,
renderOptions=...) at backend/scene/view.cpp:939
#12 0x0000000000470512 in pov::RenderBackend::StartRender
(this=0x7ffff7ff6d80, msg=...) at backend/control/renderbackend.cpp:611
#13 0x00000000004de0e6 in POVMS_MessageReceiver::ReceiveHandler
(msg=0x7ffff7ff6ca0, result=0x7ffff7ff6cc0, mode=1,
privatedataptr=<optimized out>) at povms/povmscpp.cpp:1715
#14 0x00000000004d8cd7 in POVMS_Receive
(contextref=contextref@entry=0x7fffe40008c0,
msg=msg@entry=0x7ffff7ff6ca0, result=result@entry=0x7ffff7ff6cc0,
mode=1) at povms/povms.c:880
#15 0x00000000004dc8d0 in POVMS_ProcessMessages
(contextref=0x7fffe40008c0, blocking=blocking@entry=true,
yielding=yielding@entry=true) at povms/povms.c:610
#16 0x000000000046dede in (anonymous namespace)::MainThreadFunction
(threadExit=...) at backend/povray.cpp:551
#17 0x00007ffff671ba4a in boost::(anonymous namespace)::thread_proxy
(param=<optimized out>) at libs/thread/src/pthread/thread.cpp:164
#18 0x00007ffff5ad6184 in start_thread (arg=0x7ffff7ff7700) at
pthread_create.c:312
#19 0x00007ffff580337d in clone () at
../sysdeps/unix/sysv/linux/x86_64/clone.S:111
dik
Subject: Re: crash in origin/master
Date: 12 Feb 2017 05:53:30
Message: <58a03eaa$1@news.povray.org>
Am 12.02.2017 um 10:43 schrieb dick balaska:
Hmmm... doesn't tell me much.
You might want to try the master branch up /now/. It reduces the
probability of /some/ type of crash.
Date: 12 Feb 2017 07:30:18
Message: <58a0555a$1@news.povray.org>
Am 2017-02-12 05:53, also sprach clipka:
Bummer, I was hoping there would be a recursive CheckCameraHollowObject
lightbulb.
Not so good.
Interestingly, it doesn't build with --disable-optimiz
$ ./configure --enable-debug --disable-optimiz COMPILED_BY="me"
../source/libpovray.a(metadata.o): In function
`boost::date_time::month_formatter<boost::gregorian::greg_month,
boost::date_time::iso_extended_format<char>,
char>::format_month(boost::gregorian::greg_month const&, std::ostream&)':
/usr/include/boost/date_time/date_formatting.hpp:44: undefined reference
to `boost::gregorian::greg_month::as_short_string() const'
/usr/include/boost/date_time/date_formatting.hpp:49: undefined reference
to `boost::gregorian::greg_month::as_long_string() const'
collect2: error: ld returned 1 exit status
But it builds with default optimiz (-O3)
It's the same crash again.
Program received signal SIGSEGV, Segmentation fault.
[Switching to Thread 0x7ffff7ff7700 (LWP 27541)]
(gdb) back
point=..., node=0x7fffd8097e80) at backend/scene/view.cpp:619
(this=this@entry=0x7fffe40035c0, point=..., node=0x7fffd86b4620) at
(this=this@entry=0x7fffe40035c0, point=..., node=0x7fffd8025d40) at
(this=this@entry=0x7fffe40035c0, point=..., node=0x7fffd8004c90) at
(this=this@entry=0x7fffe40035c0, point=..., node=0x7fffd80087e0) at
(this=this@entry=0x7fffe40035c0, point=..., node=0x7fffd80097e0) at
(this=this@entry=0x7fffe40035c0, point=..., node=0x7fffd8009c90) at
(this=this@entry=0x7fffe40035c0, point=..., node=0x7fffd8009e40) at
(this=0x7fffe40035c0, point=..., node=0x7fffd8009ef0) at
(gdb)
I ran it several times and it always crashed with that trace.
The good news is, it is something specific in my code that I should be
able to narrow down to at least give you an sdl sample. It ran my
credits scene fine. So it dies once I populate that room with my
objects. I'll play with what object does it. (The picture of my naked
wife on the wall?)
dik
Date: 12 Feb 2017 08:54:26
Message: <58a06912$1@news.povray.org>
> lightbulb.
> Not so good.
In my experience, it has been necessary for a long while to run
configure for debug compiles adding: LIBS="-lboost_date_time"
Does this addition to ./configure fix your debug configure/compile?
Bill P.
Date: 12 Feb 2017 10:09:26
Message: <58a07aa6$1@news.povray.org>
Am 12.02.2017 um 13:30 schrieb dick balaska:
> lightbulb.
Nope; that's just traversal of a bounding box tree. Nothing strange there.
> Not so good.
To quote from `unix/install.txt` (which `unix/prebuild.sh` will copy to
`./INSTALL`), section 2.3 "Compatibility issues":
When configured with "--disable-optimiz", linkage may fail in some
cases, reporting undefined references related to
"boost::gregorian::greg_month". To work around this issue, use the
configure option "LDFLAGS=-lboost_date_time".
> wife on the wall?)
Providing me with a minimal test scene for further analysis is certainly
a good idea. (By all means try to replace that picture with something
less private though ;)
Date: 12 Feb 2017 16:42:04
Message: <58a0d6ac$1@news.povray.org>
Am 2017-02-12 10:09, also sprach clipka:
> To quote
What is with you people and the RTFM?
dik
Date: 12 Feb 2017 18:51:34
Message: <58a0f506$1@news.povray.org>
>> To quote
That's nothing. When I first wandered here about 15 years ago. It was
RTFM here, RTFM there.
I think the above was helpfulness.
Regards
Date: 12 Feb 2017 19:14:18
Message: <58a0fa5a$1@news.povray.org>
Am 12.02.2017 um 22:42 schrieb dick balaska:
>> To quote
You mean the old-school "I know the answer but the only thing I'll tell
you is that it's documented /somewhere/" flavour of RTFM?
We don't do that anymore.
Why do you ask? ;)
Date: 13 Feb 2017 05:35:02
Message: <58a18bd6$1@news.povray.org>
You get a povray'd arrow instead of a naked wife. (I was hoping that
would tip something, actually) but that "fireplace" object has to stay
for the crash. (I was able to eliminate 2 other image_maps, but this one
stays.)
http://www.buckosoft.com/tteoac/video/ttcrash.bz2
(It's not a video, I just had to put it somewhere...)
I've reduced it to 47K and just a handful of files.
I hope this is somewhat useful. Any more reducing gets to be painful.
$ tar -xvjf ttcrash.bz2
$ cd ttcrash/tteo
$ povray tteo.ini
boom.
The main file is tteo.pov.
If you look at the bottom of that file, there are 5 included objects.
If you comment out any one of those, it doesn't crash.
It doesn't crash at all on Windows. It crashes 100% on my Ubuntu 14 and
Ubuntu 16 boxes.
My art does nothing fancy. There is the image_map but other than that,
it's all sliced and diced spheres, boxes, cones, cylinders, and torii;
basically povray 3.1g compatible.
dik
Date: 13 Feb 2017 06:35:58
Message: <58a19a1e$1@news.povray.org>
> stays.)
> $ cd ttcrash/tteo
> $ povray tteo.ini
> boom.
> Ubuntu 16 boxes.
FYI.
Took an initial look and at, at least for the Ubuntu gnu debug compiles
I have handy and current, I do not get the seg fault where the
equivalent normal compile fails... Maybe an optimization tangled issue?
I had a few existing normally compiled binaries handy from previous
specific commits. The last that worked for me was commit 7d06e7f, Fri
Sep 9 09:50:47 2016 +0200. The first that failed was commit c6a6e98, Dec
20 13:55:46 2016 +0100.
I'll have to step out for a while, but I'll plan to pick this up later
this morning after checking in here.
Bill P.
