POV-Ray : Newsgroups : povray.beta-test : New black_hole type of 1 proposed as github pull request #86. Server Time
24 Jun 2026 05:48:41 EDT (-0400)
  New black_hole type of 1 proposed as github pull request #86. (Message 1 to 8 of 8)
Subject: New black_hole type of 1 proposed as github pull request #86.
Date: 9 Sep 2016 18:12:50
Message: <57d333e2$1@news.povray.org>
Notice & image for those following here. Violet spheres mark the center
of the inward pulling black holes. Orange marks the inverse, outward
pushing black holes. One orange is below the plane in the lowest center
case.
Original github checks clean, but fail after manually bumping up the
version numbers in the branch. Unsure why.
Bill P.
Download 'newblack_hole_type1.jpg' (122 KB)
Preview of image 'newblack_hole_type1.jpg'
Subject: Re: New black_hole type of 1 proposed as github pull request #86.
Date: 10 Sep 2016 06:45:05
Message: <57d3e431@news.povray.org>
Am 10.09.2016 um 00:12 schrieb William F Pokorny:
> case.
It is quite obvious that your contributions are currently focused on
isosurfaces; but since warps are pattern features, which are first and
foremost texture tools, maybe an illustration of the new warps' effect
on textures would also be of interest ;)
It conflicts with changes made to the master branch after you branched
off (the version numbers, evidently).
I must confess that version number handling is something that seriously
bothers me, with a good solution still waiting to be found.
Date: 10 Sep 2016 08:47:18
Message: <57d400d6@news.povray.org>
>> case.
Attached is the same sequence of warps applied to a checker pattern on a
plane. No doubt I am interested in isosurfaces, but I also find it
easier to understand what a 3D pattern is really doing by creating
various shapes from the pattern.
As for version number handling I too am finding it awkward. I found
github wouldn't let me create a second fork for the base uberpov. I did
it the recommended way as another branch under my current fork. Because
the two git commit hook scripts are different I symbolically linked the
commit script into my repository, but the execute bits need to be
twiddled with on switching branches if I want it to run. Of course once
a branch has different version numbers these collide with the master
branch numbers on pull / merge. If you find - or figure out - a cleaner
method, please let us know.
Bill P.
Download 'newblack_hole_type1aspat.jpg' (936 KB)
Preview of image 'newblack_hole_type1aspat.jpg'
Date: 11 Sep 2016 07:49:35
Message: <57d544cf$1@news.povray.org>
Woke up this morning wondering if due your request for an example
"texture" I should remark it looks like there is no normal support
within the warp code. I am ignorant of the history here and I am not
really sure of the implications...
Does the lack of warp.cpp nomral support mean if warp {} gets used in
say a texture map the normals within any given texture in the map won't
get transformed properly?
If so, or similar, should we document this?
I did another texture on a plane where I applied the old and new types
to a traditional wood pattern but used in the textures normal and not
the pigment. The pigment is Orange, the apparent grain is due the shadows.
Bill P.
Download 'newblack_hole_type1asnrm.jpg' (501 KB)
Preview of image 'newblack_hole_type1asnrm.jpg'
Date: 11 Sep 2016 08:30:00
Message: <web.57d54e22da74579b5e7df57c0@news.povray.org>
This would make a great "rain" animation - and it would be interesting to use
_both_ the positive and negative black hole warps!
Date: 11 Sep 2016 09:27:41
Message: <57d55bcd$1@news.povray.org>
Am 11.09.2016 um 13:49 schrieb William F Pokorny:
I must confess that I have no bloody freakin' idea :)
I do know that some things in normal handling are broken at a very
fundamental level, but when I turned my attention to trying to fix it
some years ago, I found that the topic can acommodate quite a lot of
brain-wrapping, took a step back, and haven't found the time yet to
tackle this issue again.
Date: 30 Sep 2016 15:33:07
Message: <57eebdf3$1@news.povray.org>
Am 10.09.2016 um 14:47 schrieb William F Pokorny:
FYI, I've just ditched the running version number from the master
branch, as it turns out to really come crashing down with any reasonable
number of open pull requests around. Once you strip any trailing numbers
after the "alpha" from your pending pull requests, things should run a
good deal more smoothly from now on. (The pre-commit hook should be fine
with this new mode of operation, though it becomes less relevant anyway.)
I've instead added an advice to README.md to not build from the master
branch, but from tagged version only. Tagged versions will continue to
have trailing numbers after the "alpha" so that they can be uniquely
identified for the sake of providing support, but they will be managed
in a dedicated branch, to be updated from time to time from the master
branch.
Date: 1 Oct 2016 05:59:24
Message: <57ef88fc$1@news.povray.org>
> branch.
OK. Thanks. I'll update my remaining pull requests to this new approach.
Bill P.
