POV-Ray : Newsgroups : povray.beta-test : Sven’s Bug Server Time
29 Apr 2024 00:56:47 EDT (-0400)
  Sven’s Bug (Message 11 to 20 of 26)
<<< Previous 10 Messages Goto Latest 10 Messages Next 6 Messages >>>
Subject: Re:_Sven’s_Bug
Date: 18 Feb 2016 22:47:45
Message: <56c69061$1@news.povray.org>
Am 18.02.2016 um 23:55 schrieb Alain:
> Is it possible that using antialiasing method 2 could reduce that kind
> of artefacts?
> With method 1, you sample the center of each pixel, and compare that
> with the neibors. With method 2, you start with samples at each corners
> that are then compared.
That may well be.
Note that even anti-aliasing mode 1 already does some extra work to try
to prevent such aliasing artifacts, by silently rendering the pixels
immediately to the top and left of each block again to check if
oversampling is necessary. This way, the same comparisons normally done
for pixels in the bulk of the block can also be applied to the pixels at
the boundary. But in the bulk the neighboring pixels would also have
been subject to potential oversampling already, while the extra pixels
at the boundary will never be oversampled. This /can/ lead to aliasing
artefacts at the boundaries that wouldn't be there in the bulk.
In mode 2, this difference can't happen because the oversampling
decision is based on original trace results, not on oversampled pixels.
Date: 19 Feb 2016 02:30:05
Message: <56c6c47d$1@news.povray.org>
Le 18/02/2016 22:15, clipka a écrit :
> Am 18.02.2016 um 21:40 schrieb Sven Littkowski:
>> Yes, this is truly a good idea to use my name as identifier for this
>> bug, this way CLipka will enjoy much more having to think about it, and
>> to work with it. Full support from my side. Now we have implanted my
>> name even in his mind. Cool! :-D
> Someone hand me the Brain Bleach, please...
Hi, please look at my raised hand, with the metal rod  and its tiny red
light at the end of it.
*** Flash ***
You are a good programmer coding days and nights to make povray better.
you aim at releasing a major version soon and won't let you disturbed by
small hindrance like hunger or need of sleep.
Have a good day.
Date: 19 Feb 2016 02:54:46
Message: <56c6ca46@news.povray.org>
> *** Flash ***
> Have a good day.
[at least he can have sex]
Date: 19 Feb 2016 03:41:27
Message: <56c6d537$1@news.povray.org>
> *** Flash ***
Nah. It didn't work. :)
Regards
Date: 19 Feb 2016 04:13:33
Message: <56c6dcbd$1@news.povray.org>
Am 19.02.2016 um 08:30 schrieb Le_Forgeron:
> *** Flash ***
> Have a good day.
In other words: Back to normal mode of operation.
Date: 19 Feb 2016 20:16:03
Message: <56c7be53$1@news.povray.org>
Can he..? POV-Ray's more important.
Date: 19 Feb 2016 20:21:45
Message: <56c7bfa9$1@news.povray.org>
And we all are waiting now like the vultures for the new major bugs of
the new major release...
But seriously, I wished I could assist in programming. I have so many
ideas about editor and other things, and little improvements (-e2), that
it is sad I use a different programming language than C++.
Yes, indeed, CLipka is doing some kinda good job. Big thanks to him and
all the other developers of this magnificent software!!!!!!!
Date: 20 Feb 2016 14:49:00
Message: <56c8c32c@news.povray.org>
Le 16-02-18 14:29, Stephen a écrit :
> I’ve named this Sven’s Bug because I noticed it running his code posted
> in “15 Shapes Taking Forever” in povray.general
> And so he gets his name on something. :-P
> There is a difference between renders with and without using Render
> Block Size.
> The images are with the windows QUICKRES.INI [800x600, AA 0.3] with and
> without +BS8
> I compared them in PaintShop Pro (XOR shows it best)
> Ver 3.7.0.msvc10.win64
> On Win7
After Clipka's answer to my comment, I'd recomend using antialiasing
method 2, +am2, to reduce or elliminate those artefacts.
With method 1, the already rendered pixels on the top and left may, or
may not, already be supersampled compared to the retraced ones from the
current block.
With method 2, that start with the NON supersampled corners, you always
start with fresh samples that are in a known, consistant, state. It
don't mather if the current pixel is at the edge of the block or not,
all pixels are treated the same with original data obtained the same way.
If using method 3, you are possibly in a similar situation as with
method 2. Given the inherent random noise associated with method 3, it
may not mather at all.
Date: 21 Feb 2016 02:23:53
Message: <56c96609$1@news.povray.org>
Am 20.02.2016 um 02:15 schrieb Sven Littkowski:
A good and healthy sex life is... well, good and healthy ;)
Scientific studies have shown that frequent -- shall we say, exercise?
-- reduces the risk of prostate cancer and cardiovascular issues.
And you surely want POV-Ray development to continue for a while, don't
you? ;)
Date: 21 Feb 2016 02:25:58
Message: <56c96686$1@news.povray.org>
Am 20.02.2016 um 02:21 schrieb Sven Littkowski:
"Kinda" good, huh?
I'll remember that next time you want something fixed ;)
