POV-Ray : Newsgroups : povray.beta-test : master branch issue 29 linux compilation errors Server Time
25 Oct 2025 15:51:05 EDT (-0400)
  master branch issue 29 linux compilation errors (Message 1 to 10 of 41)
Subject: master branch issue 29 linux compilation errors
Date: 29 Jun 2014 05:52:20
Message: <53afe1d4@news.povray.org>
Because I cannot attach a text file in github.
The file error.txt is from clang (it stopped before going to far)
icerror.txt is from Intel compiler.
gcc_error.txt is from g++ 4.8
All of them when trying the branch hotfix/github_issue_29
IQ of crossposters with FU: 100 / (number of groups)
IQ of crossposters without FU: 100 / (1 + number of groups)
IQ of multiposters: 100 / ( (number of groups) * (number of groups))
Download 'gcc_error.txt' (390 KB) Download 'icerror.txt' (179 KB) Download 'error.txt' (81 KB)
Subject: Re: master branch issue 29 linux compilation errors
Date: 30 Jun 2014 08:26:08
Message: <53b15760$1@news.povray.org>
Am 29.06.2014 11:52, schrieb Le_Forgeron:
./base/colour.h: In instantiation of ‘T
pov_base::GenericColour<T>::MaxAbs() const [with T = float]’:
./base/colour.h:1422:27:   required from ‘T
pov_base::GenericColour<T>::WeightMaxAbs() const [with T = float]’
backend/render/trace.cpp:999:34:   required from here
./base/colour.h:1456:54: error: no matching function for call to
‘max(float&, double)’
                  result = max(result, fabs(mColour[i]));
That's a quite interesting error we have here: With T=float, mColour is
defined as "float mColour[3]", so the compiler should pick "float
fabs(float)", but the max() signature it is trying to find a match for
indicates that the compiler rather chooses "double fabs(double)".
So either...:
(A) The compiler is buggy, or
(B) The header files are buggy, declaring "fabs(float)" as returning a
double instead, in obvious violation of the C++03 standard, or
(C) The header files are buggy, failing to declare "fabs(float)" at all,
again in obvious violation of the C++03 standard.
So we should probably contact the authors of g++ to fix this...
... or should we? Having had a quick glance at the C++03 standard,
thruth gave me a roundhouse kick right in the face:
(D) We're not including the right header in the first place.
Just a few weeks ago, I had done some work on work coding style; one
thing I addressed was the order in which header files should be
included, as well as which names should be used for C standard headers.
One thing that had been bugging me most was the inconsistenty in using
the old C standard header file names vs. the new C++ names (e.g.
<stdlib.h> vs. <cstdlib>), and I went for the C++ names for the coding
rules; it had been bugging me to the degree that in all the files I have
been touching ever since, I replaced all the C header names with the C++
names.
Well, it should probably have bugged me even more.
 From ISO-IEC 14882-2003 (aka C++03):
26 Numerics library
26.5 C Library
Tables 80 and 81 describe headers <cmath> and <cstdlib> [...], respectively.
The contents of these headers are the same as the Standard C library
headers <math.h> and <stdlib.h> respectively, with the following additions:
     float fabs (float);
Read this again, and let it sink in: <cmath> is /not/ a C++ canonical
name for <math.h>. It is an entirely different library, with /added/
functionality over <math.h>.
Guess which version of <math.h> / <cmath.h> we've been including in
POV-Ray all the time...
I think it's time to kick out all the C standard header files for good. Now.
Date: 30 Jun 2014 10:19:51
Message: <53b17207@news.povray.org>
Le 30/06/2014 14:25, clipka a écrit :
> Having had a quick glance at the C++03 standard, thruth gave me a
I hope you are not too much injured.
Nicely spotted, btw.
Just because nobody complains does not mean all parachutes are perfect.
Date: 30 Jun 2014 12:07:07
Message: <53b18b2b@news.povray.org>
Second round, on f42a95b668458bfd8bf626519669b3cdc36f0d3c
* still std::numeric_limits<> but now in base/types.h (nned <limits>)
* texture.cpp, 1266 : default shared_ptr is to nullptr, not worth setting ?
* same for normal.cpp, 593.
* base/colour.cpp:53:22: error: specializing member
‘pov_base::GenericColour<float>::mkDefaultWavelengths’ requires
‘template<>’ syntax
     const MathColour MathColour::mkDefaultWavelengths =
MathColour(RGBColour(0.70, 0.52, 0.48));
* "return GenericPigmentBlendMapPtr(NULL);" might compile better as
"return GenericPigmentBlendMapPtr()" (calling the constructor of
shared_ptr without argument, making a shared_ptr to nullptr.
(otherwise, IIRC, NULL is taken as the argument for the constructor of T
in shared_ptr<T>)
(I'm more familiar with C++11 std::shared_ptr<T>, so I might be wrong
when applied to C++03 & boost . when I need fresh instanced value,
std::make_shared<T>(params for T's constructor...) is my friend)
Thanks for your update.
Download 'errorgcc.txt' (428 KB) Download 'erroricpc.txt' (175 KB)
Date: 30 Jun 2014 13:20:32
Message: <53b19c60$1@news.povray.org>
Am 30.06.2014 18:06, schrieb Le_Forgeron:
> in shared_ptr<T>)
Technically you're right in that the NULL is not required, but you're
wrong on the details: The shared_ptr<T> constructor does /not/ pass its
arguments to a constructor of T; in fact, it never even constructs an
instance of T at all. Instead, it takes a /pointer/ to an
already-created instance of T as an argument (with NULL being a valid
parameter as well). To construct a T without make_shared (which is not
available in TR1), you have to invoke:
     shared_ptr<T>(new T(params for T's constructor...));
As for using "return shared_ptr<T>()" instead of "return
shared_ptr<T>(NULL)", note that those pieces of code should never be
called in the first place anyway (they all follow either an
"assert(false)" or an "Error(...)"), and the only reason they even exist
is to satisfy compilers ("all control paths must return a value"). I
prefer to go for code clarity there and leave the "NULL" parameter in.
Date: 30 Jun 2014 16:03:17
Message: <53b1c285$1@news.povray.org>
Le 30/06/2014 19:20, clipka nous fit lire :
>> in shared_ptr<T>)
But it won't compile on gcc with NULL. :-/
(it's a reported error, not just a warning)
(as NULL is long int 0... and that's not transformable into a
shared_ptr<T>.) (nullptr seems fine for C++0x, but it's not in C++03;
does boost have it ?)
I stand corrected about the constructor syntax.
Date: 30 Jun 2014 16:26:52
Message: <53b1c80c@news.povray.org>
I've seen the new commit (583d4c85e9357f06b02af41b41973a46f315fe3c)
It's better, half size of gcc complains, but does not compile yet.
* <limits> needed in safemath.h (for numeric_limits).. it crawls
* New->Blend_Map = NULL; ... same empty shared_ptr story (with
variations about return)
* base/colour.h , still the max() vs fabs() as double and float.
Download 'errorgcc3.txt' (196 KB)
Date: 30 Jun 2014 17:34:00
Message: <53b1d7c8@news.povray.org>
Am 30.06.2014 22:26, schrieb Le_Forgeron:
Uh... no, it's not missing <limits>; that file has been included there
for ages; it's missing the std:: namespace descriptor...
Heh, that surplus piece of code is even in there twice... whoops.
Now this starts getting me puzzled. Can you double-check whether we
still have any reference to math.h in our code?
Date: 30 Jun 2014 19:44:06
Message: <53b1f646$1@news.povray.org>
Am 30.06.2014 23:33, schrieb clipka:
I /think/ I can solve this riddle now:
While the C++03 standard is very ambiguous (at least to me) about
whether the functions provided by <cmath> should live in the global or
std:: namespace, the C++11 standard clarifies this, indicating that
<cmath> /must/ provide the functions in the std:: namespace, and /may/
also provide them in the global namespace.
It appears to me that the GCC <cmath> header does the most confusing
thing, by providing only /some/ functions in the global namespace -
namely those for the "double" data type.
Ready for the next round.
Date: 1 Jul 2014 03:41:26
Message: <53b26626$1@news.povray.org>
Keep it going!
While this is all gobbledegook to me, I love to read your exchange of
thoughts :-) It shows the brain at work... or is this play for you guys?
