POV-Ray : Newsgroups : povray.beta-test : Requesting user feedback: POV-Ray v3.7 scenes/includes Server Time
25 Apr 2026 20:03:33 EDT (-0400)
  Requesting user feedback: POV-Ray v3.7 scenes/includes (Message 8 to 17 of 47)
<<< Previous 7 Messages Goto Latest 10 Messages Next 10 Messages >>>
Subject: Re: Requesting user feedback: POV-Ray v3.7 scenes/includes
Date: 21 Feb 2013 02:50:01
Message: <web.5125d11b823c8519c2d977c20@news.povray.org>
> Let's see... integrate a bunch of features that have accumulated during
> 3.7.0 feature freeze; redesign radiosity pretrace to work with
> distributed rendering; contribute to...
Great! Shouldn't be too hard! Keep working those late hours, the deadline's
approaching! We'll supply the coffee and doughnuts!  ;-) ;-)
Date: 21 Feb 2013 03:43:50
Message: <5125de46$1@news.povray.org>
Am 21.02.2013 08:14, schrieb Kenneth:
> In lieu of that, maybe a (*gulp!*) feature request along the same lines:
> possibly as the so-far-unused map_type 4. Rune's code *seems* to be an SDL
> method for simply eliminating/reversing part of the 'transform' that POV-Ray
> internally applies to an image_map to project it onto objects in
> space--'eliminating' the z-distance/perspective pixel transformation. (Turning
> it back into solely an affine transform? Sorry, my knowledge of this is
> sketchy.) ANYWAY, just an idea.
Ah yes, forgot to mention that on my list:
"... add support for all camera types as map types, ..."
Would be fun if you could just use
     #declare MyCam = camera { ... }
     image_map { png "foo.png" map_type MyCam }
or something along those lines.
Date: 21 Feb 2013 04:01:31
Message: <5125e26b$1@news.povray.org>
> In addition to considering what we might want to remove, we need to
> consider what we might add. I don't think it's as critical to keep the
> install as small as it can be (as was the case years ago when modems
> were the common means of getting POV). So I think we have some scope
> to add extra megabytes if required.
I would suggest landscape and cities generators (as well as planets
generators).
The idea of an on-line repository is interesting, but I've always
appreciated the off-line examples included in the setup package (even
the off-line help): the network is not always available everywhere.
Thank you for your work,
    Paolo
Date: 21 Feb 2013 07:11:27
Message: <51260eef$1@news.povray.org>
> generators).
That's a thought indeed. Comes to my mind: John Van Sickle's
height_field mosaic macro for instance.
Better a good off-line than an unreliable online ;-)
I second that indeed.
Date: 21 Feb 2013 09:15:18
Message: <51262bf6$1@news.povray.org>
>> generators).
Or a Gancaloon cityscape generator ;-)
Paolo
Date: 21 Feb 2013 09:22:23
Message: <51262d9f@news.povray.org>
Lol! That means digitizing my brain ;-)
Date: 21 Feb 2013 09:27:03
Message: <51262eb7$1@news.povray.org>
Mmm. How much disk space is estimated for an off-line version of such a
data?
:-P
Paolo
Date: 21 Feb 2013 13:21:23
Message: <512665a3$1@news.povray.org>
Am 21.02.2013 15:27, schrieb Paolo Gibellini:
> data?
Well, it can't be /that/ much...
(ducks & runs)
Date: 22 Feb 2013 02:59:17
Message: <51272555@news.povray.org>
>> data?
> (ducks & runs)
Right. I shall keep the floppy disk to myself...
Date: 22 Feb 2013 03:15:03
Message: <web.512727c6823c8519c2d977c20@news.povray.org>
Chris Cason <del### [at] deletethistoopovrayorg> wrote:
> ...it seems that it may be prudent to sort through them
> and determine, for each, if it's suitable as a standard scene for
> today's POV-Ray.
> Mostly this applies, I think, to samples in the advanced folder,
> rather than the demos of various features.
I've just methodically rendered all the demo scenes in the advanced folder (only
in v3.62, sorry) and, honestly, I think all of them are still 'useful' in one
way or another, if only for coding examples. Maybe CATS (povcatray.pov) looks a
bit out of date visually (an understatement!); but even that might have nuggets
of code that beginners would still find useful.
The DRUMS2 scene has some extraneous old text that could be removed.
The only scene that seems to have an actual problem is DESK. It's an animation
file, but I can't get it to animate using only the included desk.ini file (which
contains the animation parameters.) Perhaps I'm doing something wrong; someone
else needs to give that scene a try.
A more 'global' thing concerning the various scenes is that they have different
assumed_gamma settings (or none at all.) No doubt a result of their age; but
that might be a source of confusion with v3.7. Of course, that's the way they
were set up, so I wouldn't know what to recommend (if anything.)
Also, some of the scenes have an explicit #version 3.5 directive. Just wondering
if those should be changed to at least 3.6.
The day before Chris posted this message, I also happened to go through all of
the  various 'cameras' in the SCENES/CAMERA folder, and found a few minor things
that need attention. In many of the files, there is a 'boilerplate' text
section...
"don't forget to render this with the image ratio equal to 1 (height = width),
or, instead of being framed in a half-circle, the upper part of the image will
be "squished" into a half-ellipse."
In more than a few cases this is wrong, on two counts: The 'fisheye' and
omnimax' cameras need a 4:3-ratio render, not 1:1; and the stuff about being
"squished into a half-elipse" is a mystery altogether. (I can't honestly say if
this text section is right *or* wrong in the four 'cylinder' cameras, but it's
there too.) BTW, the text section in the 'spherical' camera is correct AFAIK.
