POV-Ray : Newsgroups : povray.beta-test : Syntax error message? Server Time
16 Feb 2026 04:55:42 EST (-0500)
  Syntax error message? (Message 1 to 3 of 3)
Subject: Syntax error message?
Date: 7 Dec 2012 03:47:24
Message: <50c1ad1c$1@news.povray.org>
In an external .inc file I have the following line:
#declare srgbLightTanned1 = srgb <226, 167, 135>/255;
In my material definition I have written, using Poseray's macros:
#declare SkinColor = srgbLightTanned2;
#declare PP_Head = pigment {pigment_multiply(p_map7,pigment {srgb
SkinColor})}
...which should be written without the /srgb/ code to be correct:
#declare PP_Head = pigment {pigment_multiply(p_map7,pigment {SkinColor})}
Both lines render without a glitch but give very different render results.
Should there not be a warning message telling about the extra and
unwanted srgb code?
Subject: Re: Syntax error message?
Date: 7 Dec 2012 07:21:14
Message: <50c1df3a@news.povray.org>
Am 07.12.2012 09:47, schrieb Thomas de Groot:
> SkinColor})}
> ....which should be written without the /srgb/ code to be correct:
> unwanted srgb code?
Not really; for instance, you might be using a legacy 3rd-party include
file, designed for a "assumed_gamma 2.2" scene, specifying
     #declare SkinColor = rgb <226, 167, 135>/255;
In that case, you'd very likely want to convert that to whatever
assumed_gamma you're using; that's where specifying
     srgb SkinColor
does makes sense.
Note that colors specified with the "srgb" keyword are not a different
flavor of color - they're converted "on the spot" into regular rgb
colors. So the parser cannot catch a double application of the srgb keyword.
Date: 7 Dec 2012 08:24:41
Message: <50c1ee19@news.povray.org>
>      srgb SkinColor
> does makes sense.
> keyword.
OK. Understood and makes sense. I have to watch my own code corrections
while writing and editing ;-)
Thanks Christoph!
