using POV-Ray 3.7 RC6 64bit for Windows
I have problems in the POV-Ray editor with 'backspace':
When using backspace at the beginning of a line
it does not only kill the return/line feed but also
everything of the line what's beneath the upper line.
Sample: (here '|' is used for the current cursor position!)
texture { pigment{ Red }
| normal { bumps 0.5 scale 0.1 }
hitting backspace results in:
texture { pigment{ Red }| 0.5 scale 0.1 }
and not as expected:
texture { pigment{ Red }| normal { bumps 0.5 scale 0.1 }
with 3.6.2 and with RC3 (latest old beta I found on my computers)
this was no problem!
Can anybody confirm this strange behavior or
help me, if I'm too stupid for resolving this problem?
Friedrich
homepage: http://www.f-lohmueller.de/
I confirm this, but only when line above contains text. If the line
above is an empty line, backspace seems to work correctly.
Am 17.09.2012 13:23, schrieb Thomas de Groot:
Can't confirm this here; can you two please post your editor preferences
settings?
Am 17.09.2012 14:00, schrieb clipka:
> settings?
Note: behavior does not change by reinstalling the program.
My settings from
Options->Editor window->editor preferences settings:
>Language/Tabs_:
auto indent: Off,
tabs: 4, convert to spaces,
language,: POV-Ray
>Keybord:
all key assignments are
unchanged since installation!
The only items containing 'Backspace' are:
DeletBack Backspace
Shift Backspace
Undo Alt + Backspace
Ctrl + Z
WordDeleteToStart Ctrl + Backspace
>Misc: off: 1. Smooth scrolling
off: 6. Confine caret to text
on: all others.
Friedrich
> Friedrich
I do *not* confirm this.
What I get when I follow Friedrich's instructions is:
texture { pigment{ Red }0.5 scale 0.1 }
My editor preferences setting are virginal, untouched from installation
of 3.6 maybe 3.5.
Regards
Le 17/09/2012 19:45, Stephen nous fit lire :
> of 3.6 maybe 3.5.
Please remember the "|" was used as the "flashing cursor" (well, the
editing cursor)
So, it seems that the problem is at least real for you too, Stephen.
(the catch is "normal { bumps" get deleted )
Could you please also states your Windows version ?
(32/64 bits, XP/2008/Vista/7/8, or other)
Le 17/09/2012 20:22, Le_Forgeron nous fit lire :
I can even confirm it under Wine (Ubuntu 12.04, fresh povray-for-windows
install, in a new document)
> editing cursor)
Indeed, you are right. It has been a long day. I misread the text.
Win 7 home premium 64 bit PovRay RC6 32 bit
Regards
> settings?
Confirmed here, too; I hadn't actually run the official POV-Ray 3.7 RC6
binary, but my own compile, and apparently hadn't re-built the editor
DLL for quite a while.
I'm investigating.
> settings?
Identical to Friedrich, with the exception that auto indent is set to
copy from previous line.
