POV-Ray : Newsgroups : povray.beta-test : RC6 win: backspace problem Server Time
15 May 2026 17:33:47 EDT (-0400)
  RC6 win: backspace problem (Message 1 to 10 of 10)
Subject: RC6 win: backspace problem
Date: 17 Sep 2012 05:58:42
Message: <5056f452$1@news.povray.org>
using POV-Ray 3.7 RC6 64bit for Windows
I have problems in the POV-Ray editor with 'backspace':
When using backspace at the beginning of a line
it does not only kill the return/line feed but also
everything of the line what's beneath the upper line.
Sample: (here '|' is used for the current cursor position!)
texture { pigment{ Red }
|         normal { bumps 0.5 scale 0.1 }
hitting backspace results in:
texture { pigment{ Red }| 0.5 scale 0.1 }
and not as expected:
texture { pigment{ Red }|         normal { bumps 0.5 scale 0.1 }
with 3.6.2 and with RC3 (latest old beta I found on my computers)
this was no problem!
Can anybody confirm this strange behavior or
help me, if I'm too stupid for resolving this problem?
Friedrich
homepage: http://www.f-lohmueller.de/
Subject: Re: RC6 win: backspace problem
Date: 17 Sep 2012 07:23:50
Message: <50570846@news.povray.org>
I confirm this, but only when line above contains text. If the line
above is an empty line, backspace seems to work correctly.
Date: 17 Sep 2012 08:00:41
Message: <505710e9$1@news.povray.org>
Am 17.09.2012 13:23, schrieb Thomas de Groot:
Can't confirm this here; can you two please post your editor preferences
settings?
Date: 17 Sep 2012 10:47:47
Message: <50573813$1@news.povray.org>
Am 17.09.2012 14:00, schrieb clipka:
> settings?
Note: behavior does not change by reinstalling the program.
My settings from
  Options->Editor window->editor preferences settings:
 >Language/Tabs_:
   auto indent: Off,
   tabs: 4, convert to spaces,
   language,: POV-Ray
 >Keybord:
   all key assignments are
   unchanged since installation!
   The only items containing 'Backspace' are:
    DeletBack   Backspace
                Shift Backspace
    Undo        Alt + Backspace
                Ctrl + Z
    WordDeleteToStart Ctrl + Backspace
 >Misc: off:  1. Smooth scrolling
        off:  6. Confine caret to text
        on:   all others.
Friedrich
Date: 17 Sep 2012 13:45:37
Message: <505761c1$1@news.povray.org>
> Friedrich
I do *not* confirm this.
What I get when I follow Friedrich's instructions is:
texture { pigment{ Red }0.5 scale 0.1 }
My editor preferences setting are virginal, untouched from installation
of 3.6 maybe 3.5.
Regards
Date: 17 Sep 2012 14:22:51
Message: <50576a7b$1@news.povray.org>
Le 17/09/2012 19:45, Stephen nous fit lire :
> of 3.6 maybe 3.5.
Please remember the "|" was used as the "flashing cursor" (well, the
editing cursor)
So, it seems that the problem is at least real for you too, Stephen.
(the catch is "normal { bumps" get deleted )
Could you please also states your Windows version ?
(32/64 bits, XP/2008/Vista/7/8, or other)
Date: 17 Sep 2012 14:31:32
Message: <50576c84$1@news.povray.org>
Le 17/09/2012 20:22, Le_Forgeron nous fit lire :
I can even confirm it under Wine (Ubuntu 12.04, fresh povray-for-windows
install, in a new document)
Date: 17 Sep 2012 15:22:27
Message: <50577873$1@news.povray.org>
> editing cursor)
Indeed, you are right. It has been a long day. I misread the text.
Win 7 home premium 64 bit PovRay RC6 32 bit
Regards
Date: 17 Sep 2012 16:37:06
Message: <505789f2$1@news.povray.org>
> settings?
Confirmed here, too; I hadn't actually run the official POV-Ray 3.7 RC6
binary, but my own compile, and apparently hadn't re-built the editor
DLL for quite a while.
I'm investigating.
Date: 18 Sep 2012 03:31:15
Message: <50582343$1@news.povray.org>
> settings?
Identical to Friedrich, with the exception that auto indent is set to
copy from previous line.
