POV-Ray : Newsgroups : povray.beta-test : RC5 32 bit, not releasing memory on failure to load a large file. Server Time
26 Oct 2025 05:44:54 EDT (-0400)
  RC5 32 bit, not releasing memory on failure to load a large file. (Message 1 to 10 of 11)
Subject: RC5 32 bit, not releasing memory on failure to load a large file.
Date: 24 Apr 2012 05:56:22
Message: <4f9678c6@news.povray.org>
I tried to load a large (>800 Meg) inc file into the editor and got this
error:
Failed to open file:
Not enough storage is available to process this command.
OS Win7, 8 Gigs Ram
Regards
Subject: Re: RC5 32 bit, not releasing memory on failure to load a large file.
Date: 24 Apr 2012 11:01:27
Message: <4f96c047$1@news.povray.org>
On 24.04.12 11:56, Stephen wrote:
> I tried to load a large (>800 Meg) inc file into the editor and got this error:
How did you determine that the memory wasn't released?
> OS Win7, 8 Gigs Ram
32 or 64?
	Thorsten
Date: 24 Apr 2012 11:24:30
Message: <4f96c5ae@news.povray.org>
>> this error:
Task manager showed the memory usage going up when I tried to open the
file then stabilising. When I exited PovRay the memory usage went back
down to what it was before.
>> OS Win7, 8 Gigs Ram
> 32 or 64?
Win 7 64 bit but running pvengine-sse2 at the time
Regards
Date: 24 Apr 2012 11:32:24
Message: <4f96c788$1@news.povray.org>
This isn't unusual for windows programs. When POV-Ray requests memory,
in some cases the request goes through the Visual C++ run-time
library, which then requests memory from Windows. If POV-Ray later
releases that memory, there is no guarantee that the RTL will then
hand it back to windows; there is a performance penalty to asking the
OS for memory so it is common for it to be retained in the heap
managed by the RTL.
This shouldn't be a problem as windows manages virtual memory
automatically and will page out RAM that the program has allocated but
isn't actively using (i.e. spare memory in the RTL's heap) if it needs
memory for something else.
That's not to say that the problem you observed isn't a bug; it could
very well be that the editor code didn't release the allocated memory
when it failed to load the file. I'd have to look further.
-- Chris
Date: 24 Apr 2012 14:00:15
Message: <4f96ea2f@news.povray.org>
> managed by the RTL.
Thanks Chris.
Just one other symptom. After the file fails to load and Process
Explorer records PovRay having 2.8 Gigs of private memory. I tried to
render another file and got the message:
Possible Parse Error: Insufficient memory to allocate intermediate image
storage.
Fatal error in parser: Out of memory.
Render failed
Regards
Date: 24 Apr 2012 14:01:41
Message: <4f96ea85$1@news.povray.org>
the possible memory release problem aside, I think most text
editors are not designed to handle such files gracefully. Your
chances will be better with the x64 version but I'd still be
wary about things like syntax highlighting ;)
Date: 24 Apr 2012 14:10:23
Message: <4f96ec8f@news.povray.org>
> storage.
> Render failed
That certainly does sound like the memory wasn't released back to the
heap. Thanks for the heads-up, I'll try to duplicate it.
-- Chris
Date: 24 Apr 2012 14:37:42
Message: <4f96f2f6@news.povray.org>
Although the file is 840 MB it compresses to 169 MB so I could always
split it and send it via Big File Transfer, or the like.
Regards
Date: 24 Apr 2012 14:41:49
Message: <4f96f3ed$1@news.povray.org>
Thanks for the offer, I don't expect that's needed though - I would
suspect the issue isn't related to the content. You could try a
different (but similarly large) file to see if it happens with that too.
-- Chris
Date: 24 Apr 2012 14:44:54
Message: <4f96f4a6@news.povray.org>
So true. I just wanted the name of a group inside it. I ended up using
the Hex editor XVI32. Then Pov 64 bit for rendering.
A waste of time, really. An isosurface did the trick.
Regards
