On 3/25/2012 8:50 AM, clipka wrote:
> Am 25.03.2012 10:58, schrieb FlyerX:
>> I have been having some issues with the new Subsurface Light Transport.
>> If the mesh is made up of several sub-meshes the seams between them are
>> darkened.
> I've never seen anything like this before with PoseRay output. (I very
> much presume you're using PoseRay for generating the POV-Ray mesh2
> objects yourself, right?)
Yes, this is a PoseRay output scene. The issue happens with all the
models that have several materials on the same mesh. PoseRay breaks the
model mesh by materials.
>> If I merge the mesh outside of POV-Ray into a single mesh with a single
>> material for the complete head skin then the dark seams disappear. But I
>> cannot merge the mesh outside POV-Ray since that would destroy the
>> separate UV mapping that each mesh uses.
> Theoretically it should be possible to merge into a mesh2 with multiple
> textures without loss.
>> Also the edges of the polygons are slightly visible on the forehead.
>> That was easily fixed by subdividing the mesh before rendering.
> That's a known problem, and difficult to fix without some significant
> internal changes to surface normal handling. At present, subdividing is
> indeed the only known workaround.
>> darkened.
Here is the material I used on the skin:
#declare PR_DIFFUSE=pigment {color srgb <0.93,0.71,0.54> }
#declare F1=finish{specular 0 //Max highlight intensity: 0 -> 1
roughness 0.02203444 //surface roughness: 0.0005 -> 1
phong 0 phong_size 0 //Phong specular disabled
ambient rgb <0.00,0.00,0.00>
diffuse 0.6
reflection{0 } conserve_energy
subsurface {translucency 0.8}
material{
texture{uv_mapping
pigment{PR_DIFFUSE }
finish{F1}
interior{ior 1}
***and here are the global settings
global_settings {
subsurface {}
mm_per_unit 25
Am 25.03.2012 22:19, schrieb FlyerX:
> interior{ior 1}
Not that I think it matters, but why ior 1? That would be air. Realistic
skin should be something around 1.3.
> diffuse 0.6
> material{
> texture{uv_mapping
> finish{F1}
> interior{ior 1}
OK, here's the deal: To avoid SSLT seams between multiple objects, they
currently must /share/ a common interior - it's not sufficient to have
interiors with identical parameters, or even instances of the same
#define'd interior. The only way to achieve this is to specify the
interior in the parent CSG rather than the individual primitives.
Thus, to get the desired results, you need to:
- REMOVE any interior statements from the material.
- ADD the interior statement to the union or merge.
- For each part that needs a different ior (e.g. eyelashes or teeth) add
an individual interior statement.
>> diffuse 0.6
>> material{
>> texture{uv_mapping
>> finish{F1}
>> interior{ior 1}
Thanks. It works now. I just added a material{interior{ior 1.3}} at the
end of the grouped skin meshes. Is union or merge better for SSLT? What
about translucency color? is there a range that gives better results for
human skin?
I used ior of 1 just to make sure that no other effects were giving me
the dark edges.
FlyerX
Am 26.03.2012 05:40, schrieb FlyerX:
When using mesh2 objects, it shouldn't make any difference
> What
> human skin?
I'm currently using translucency <2.0,1.5,0.8>; if I got the math right,
that's somewhere in between the two measured "skin" data sets listed in
That Original SSLT Paper. I do like the effect, at least with the
high-quality DAZ texture I'm currently using.
Make sure to use the right mm_per_unit setting. I'm using 1000 mm per
unit, and scaling the PoseRay output by an empiric factor of 1.8/78.
>> What
>> human skin?
Now with a texture, specular and a bump:
http://imgur.com/wkmWc
Seems to work well. I get some bright dots around the ear shadow. I am
using +am2 +a0.1 +r3.
clipka, I checked the paper you refer to and I still uncertain about the
translucency values. Is the value you are using the reduced scattering
vector in Fig. 5?
regards,
FlyerX
Seems to me the above might make an excellent addition to the
documentation ... whata ya think?
Am 26.03.2012 20:31, schrieb James Holsenback:
I expect to lift this limitation some time in the future, but yes -
until then it's probably a good idea to officially document this
restriction.
> restriction.
done:
http://wiki.povray.org/content/Reference:Finish#Subsurface_Light_Transport
