POV-Ray : Newsgroups : povray.beta-test : Test of RC5 Windows installer Server Time
25 Apr 2026 18:09:28 EDT (-0400)
  Test of RC5 Windows installer (Message 4 to 13 of 23)
<<< Previous 3 Messages Goto Latest 10 Messages Next 10 Messages >>>
Subject: Re: Test of RC5 Windows installer
Date: 9 Mar 2012 15:40:01
Message: <web.4f5a69bca0f59aa451f818f50@news.povray.org>
No comments after a successful installation on my
laptor Acer (Pentium Dual Core T4400) running w7-64bits)
regards
B. Gimeno
Date: 9 Mar 2012 18:35:00
Message: <web.4f5a92dea0f59aa4ba98f290@news.povray.org>
Chris Cason <del### [at] deletethistoopovrayorg> wrote:
> Folks,
> I would appreciate it if some of you could sanity-check the RC5
> windows installer, which may be found here:
>   http://www.povray.org/beta/povwin-3.7.RC5-setup.exe
> Please advise if you have any installation issues.
> -- Chris
No problem for me.
Bruno
Date: 10 Mar 2012 05:45:00
Message: <web.4f5b2f8aa0f59aa4d25d21bf0@news.povray.org>
Chris
Same issue with installing as RC4 on XP64 sp2 (no sp3 available).
Probally to do with the certification
greetings
Bert
Date: 10 Mar 2012 18:48:38
Message: <4f5be856@news.povray.org>
Installed successfully on Windows 7 x64.
Note that I tried running it without elevation to see what
would happen and got the elevation dialog. Does this mean a
per-user install is no longer supported? Personally I don't
mind but based on previous posts some people do.
Two minor issues:
- The name of the desktop icon is quite long and the version number
   got truncated (...). As the "for Windows" part is rather redundant
   on a Windows desktop I'd suggest to just use "POV-Ray v3.7 RC5".
- It seems the help index has been fixed, but by chance the first
   item I tried was "pigment_pattern" (with underscore), and this mapped
   to the documentation for "pavement".
   Christian
Date: 11 Mar 2012 13:36:50
Message: <4f5ce2b2$1@news.povray.org>
> Two minor issues:
> Regards,
> Christian
For the name of the icon, I think that only "POV-Ray v3.7 RC" would be
enough.
A test should be made for the partial name "POV-Ray v3.7", and if found,
only update that shortcut, or replace it. I have the habit of shortening
and simplifying to long icon's names, and get duplicates.
Date: 14 Mar 2012 10:45:00
Message: <web.4f60acfca0f59aa499ed429f0@news.povray.org>
Chris Cason wrote:
> Folks,
> -- Chris
Hello,
I have a problem with registering .pov-files to the right POV-Ray application.
Namely, when I double-click on a .pov-file, it opens in the 32-bit POV-Ray
application (pvengine.exe). My operating system is Windows 7 Home premium
64-bit. I cannot change that association to the 64-bit application
(pvengine64.exe) because my Windows doesn't accept opening the file in that when
I use the command "Open with..". Only pvengine.exe becomes an application in the
list of suitable applications.
I can drag and drop .pov-files to the editor if it's already open, but not if
only the Messages-tab is open.
RC4 registered the file types correctly. I uninstalled that before installing
RC5.
-Mika
Date: 14 Mar 2012 17:20:00
Message: <web.4f610a6fa0f59aa499ed429f0@news.povray.org>
> Folks,
> -- Chris
Hello,
RC5.
-Mika
Date: 14 Mar 2012 20:11:15
Message: <4f6133a3$1@news.povray.org>
> RC5.
Thanks for pointing this out. It will be fixed.
-- Chris
Date: 14 Mar 2012 23:09:26
Message: <4f615d66$1@news.povray.org>
I now tried this too and found that in my case, the POV files
were still associated with my 3.6 installation. Associating it
with pvengine64.exe did not work, associating it with pvengine.exe
worked but connect to the render command instead of open (???).
The command under
HKEY_CLASSES_ROOT\povfile\shell\Open\command
appeared to be correct. After deleting
HKEY_CURRENT_USER\Software\Microsoft\Windows\CurrentVersion\Explorer\FileExts\.pov\UserChoice
everything worked fine (Windows 7 x64). So possibly Windows got confused
with an earlier manual association, but the behavior was still strange.
Date: 15 Mar 2012 09:31:45
Message: <4f61ef41$1@news.povray.org>
I am not getting any file association with .pov files with both RC4 and RC5.
RC3 and earlier did this okay.
If I open a .pov file I get the windows pop-up asking me to pick a program
or search for one and have to do it manually.
I thought it was perhaps my windows installation causing this but maybe its
not?
"Chris Cason"  wrote in message news:4f59d1d0$1@news.povray.org...
Folks,
-- Chris
